C2075 out of memory error for matrixMul
For a test, I am trying to use C2075. The software versions are
Ubutnu 14.04
Cuda 7.5
When I run matrixMul with the default options (small input), I get out of memory error. Weird… The cuda-memcheck shows:
$ cuda-memcheck ./matrixMul
========= CUDA-MEMCHECK
[Matrix Multiply Using CUDA] - Starting...
GPU Device 0: "Tesla C2075" with compute capability 2.0
MatrixA(320,320), MatrixB(640,320)
cudaMalloc d_A returned error out of memory (code 2), line(164)
========= Program hit cudaErrorMemoryAllocation (error 2) due to "out of memory" on CUDA API call to cudaMalloc.
=========     Saved host backtrace up to driver entry point at error
=========     Host Frame:/usr/lib/x86_64-linux-gnu/libcuda.so.1 [0x2f31e3]
=========     Host Frame:./matrixMul [0x40de9]
=========     Host Frame:./matrixMul [0x2a48]
=========     Host Frame:./matrixMul [0x38a3]
=========     Host Frame:/lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main + 0xf5) [0x21f45]
=========     Host Frame:./matrixMul [0x2789]
========= ERROR SUMMARY: 1 error
But nvidia-smi and deviceQUery work
$ ./deviceQuery
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
  CUDA Driver Version / Runtime Version          7.5 / 7.5
  CUDA Capability Major/Minor version number:    2.0
  Total amount of global memory:                 5372 MBytes (5633277952 bytes)
  (14) Multiprocessors, ( 32) CUDA Cores/MP:     448 CUDA Cores
  GPU Max Clock rate:                            1147 MHz (1.15 GHz)
  Memory Clock rate:                             1566 Mhz
  Memory Bus Width:                              384-bit
  L2 Cache Size:                                 786432 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(65536), 2D=(65536, 65535), 3D=(2048, 2048, 2048)
  Maximum Layered 1D Texture Size, (num) layers  1D=(16384), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(16384, 16384), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 32768
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  1536
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (65535, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     Yes
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Enabled
  Device supports Unified Addressing (UVA):      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 38 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 7.5, CUDA Runtime Version = 7.5, NumDevs = 1, Device0 = Tesla C2075
Result = PASS
and
$ nvidia-smi
Wed Nov 27 23:14:54 2019
| NVIDIA-SMI 352.99     Driver Version: 352.99         |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  Tesla C2075         Off  | 0000:26:00.0      On |                  139 |
| 30%   54C   P12    33W / 225W |    274MiB /  5372MiB |      2%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID  Type  Process name                               Usage      |
|  No running processes found                                                 |
Is that a sign of hardware fault?
I don’t have any trouble with it:
$ nvcc --version
Copyright (c) 2005-2015 NVIDIA Corporation
Built on Tue_Aug_11_14:27:32_CDT_2015
Cuda compilation tools, release 7.5, V7.5.17
$ /usr/local/cuda/samples/bin/x86_64/linux/release/matrixMul
Computing result using CUDA Kernel...
done
Performance= 173.98 GFlop/s, Time= 0.753 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Checking computed result for correctness: Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
Yes, I know. I think there is another problem with the device.
May I know what is the system spec you test? I mean OS and GCC version.
CentOS 6.2, gcc 4.4.6:
$ uname -a
Linux dc20.dc.nvidia.com 2.6.32-220.el6.x86_64 #1 SMP Tue Dec 6 19:48:22 GMT 2011 x86_64 x86_64 x86_64 GNU/Linux
$ gcc --version
gcc (GCC) 4.4.6 20110731 (Red Hat 4.4.6-3)
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
