Looking at the debugging console with an AGX devkit, I see these i2c print coming every few seconds
[ 654.998261] tegra-i2c c250000.i2c: pio timed out addr: 0x1a tlen:28 rlen:4
[ 654.998409] tegra-i2c c250000.i2c: --- register dump for debugging ----
[ 654.998516] tegra-i2c c250000.i2c: I2C_CNFG - 0x22c00
[ 654.998600] tegra-i2c c250000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 654.998713] tegra-i2c c250000.i2c: I2C_FIFO_CONTROL - 0x0
[ 654.998803] tegra-i2c c250000.i2c: I2C_FIFO_STATUS - 0x800080
[ 654.998894] tegra-i2c c250000.i2c: I2C_MST_FIFO_CONTROL - 0x70000
[ 654.998991] tegra-i2c c250000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 654.999089] tegra-i2c c250000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 654.999190] tegra-i2c c250000.i2c: I2C_INT_MASK - 0x7d
[ 654.999277] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 654.999362] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x1a
Could someone explain me which device is trying to be reached and how to possibly disable this prints.
I can find a section in tegra194-soc-i2c.dtsi
gen8_i2c: i2c@c250000 {
#address-cells = <1>;
#size-cells = <0>;
iommus = <&smmu TEGRA_SID_GPCDMA_0>;
dma-coherent;
compatible = "nvidia,tegra194-i2c";
reg = <0x0 0xc250000 0x0 0x100>;
nvidia,hw-instance-id = <0x7>;
interrupts = <0 TEGRA194_IRQ_I2C8 0x04>;
scl-gpio = <&tegra_aon_gpio TEGRA194_AON_GPIO(DD, 1) 0>;
sda-gpio = <&tegra_aon_gpio TEGRA194_AON_GPIO(DD, 2) 0>;
status = "disabled";
clock-frequency = <400000>;
clocks = <&bpmp_clks TEGRA194_CLK_I2C8
&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
clock-names = "div-clk", "parent";
resets = <&bpmp_resets TEGRA194_RESET_I2C8>;
reset-names = "i2c";
dmas = <&gpcdma 0>, <&gpcdma 0>;
dma-names = "rx", "tx";
For information, the devkit is only has an active network connection, no screen attached or anything.
Thanks,
