nvidia-bug-report.log.gz (386.8 KB)
Hello, newbie here, I came from CachyOS forum to try and find a solution to this issue of power limit missing or set to 5W, resulting in the GPU only able to use 5W of power. This issue happens randomly whether it’s as fast as an hour or takes an entire day to finally trigger, but once triggered the power usage stays at 5W and doesn’t go any higher.
The only fix is putting it to sleep and waking it up but that is only temporary since it happens again very quickly, or do a reboot. The nvidia-powerd.service is turned off since my GPU does not support it. And no I could not change the power limit as it shows me this message instead:
sudo nvidia-smi -pl 45
Changing power management limit is not supported for GPU: 00000000:01:00.0.
Treating as warning and moving on.
All done.
Here are my specs:
Intel i5 10300H
16GB RAM
GTX 1650 Ti
Nvidia Driver version 565.57.01 (Open)
Here are some logs from the previous forum if it helps any
powerprofilesctl
powerprofilesctl
* performance:
CpuDriver: intel_pstate
Degraded: no
balanced:
PlatformDriver: placeholder
power-saver:
systemctl status nvidia-powerd
○ nvidia-powerd.service - nvidia-powerd service
Loaded: loaded (/usr/lib/systemd/system/nvidia-powerd.service; disabled; preset: disabled)
Active: inactive (dead)
nvidia-smi -d -q POWER
nvidia-smi -q -d POWER
==============NVSMI LOG==============
Timestamp : Thu Dec 5 17:30:38 2024
Driver Version : 565.57.01
CUDA Version : 12.7
Attached GPUs : 1
GPU 00000000:01:00.0
GPU Power Readings
Power Draw : 3.92 W
Current Power Limit : 5.00 W
Requested Power Limit : 50.00 W
Default Power Limit : 50.00 W
Min Power Limit : 1.00 W
Max Power Limit : 50.00 W
Power Samples
Duration : Not Found
Number of Samples : Not Found
Max : Not Found
Min : Not Found
Avg : Not Found
GPU Memory Power Readings
Power Draw : N/A
