This issue has already been solved by View 2022.1.4 but we are worried about
the same kind of things occur by View 2022.1.4 or later version.
Also we confirmed this issue by several environments and they are completely
different PCs and environment.
CAD Converter is available from 2022.1.3 and we can import native CAD files like Solid Works.
When 2022.1.3 was released, we can convert CAD files correctly.
We confirmed on 21st of July.
But reccently we failed to convert in case of View 2022.1.3.
Log file shows only info “[Info] [omni.kit.converter.cad.cad_converter_delegate] IMPORT FAILED”.
We can convert in case of View 2022.1.4 but we are unclear why 2022.1.3
suddenly failed to convert. We worried about the same issue occurs.
We cannot find release not of 2022.1.4 so we do not know what issues are solved.
What is the root cause?
[Environment]
OS : Windows 10 Pro
GPU Driver : 516.94
RTX 3070 Laptop GPU
[Confirmed Data]
We confirmed by several Solid Works data and all are the same results.
[Attached]
kit_20220826_191122.log : Contains Import OK log
kit_20220826_191508.log : Contains Import Filed log
View 2022.1.3 / confirmed on 21st of July.
View 2022.1.3 / Failed
View 2022.1.4 / Succeed
Logs
View_Logs.zip (121.6 KB)
Masahiro Suzuoki
