Hi I am running nVidia Caffe on Ubuntu 14.04 LTS and i see the following error messages in terminal window:
: Invalid http version: ‘OPTIONS / RTSP/1.0\r\n’
File “/usr/local/lib/python2.7/dist-packages/gevent/greenlet.py”, line 327, in run
result = self._run(*self.args, **self.kwargs)
File “/usr/local/lib/python2.7/dist-packages/socketio/server.py”, line 124, in handle
handler.handle()
File “/usr/local/lib/python2.7/dist-packages/gevent/pywsgi.py”, line 193, in handle
self.log_request()
File “/usr/local/lib/python2.7/dist-packages/gunicorn/workers/ggevent.py”, line 152, in log_request
resp = GeventResponse(self.status, self.response_headers,
AttributeError: ‘GunicornWSGIHandler’ object has no attribute ‘response_headers’
<Greenlet at 0x7f481fdccf50: <bound method SocketIOServer.handle of <SocketIOServer at 0x7f481fd8ef90 fileno=19 address=0.0.0.0:8080>>(<socket at 0x7f482067e050 fileno=[Errno 9] Bad fil, (’ xxx.xxx.xxx.xxx ', 64463))> failed with AttributeError
: Invalid HTTP method: ‘\x05\x04\x00\x01\x02\x80\x05\x01\x00\x03\n’
handler.handle()
self.log_request()
<Greenlet at 0x7f481fdccf50: <bound method SocketIOServer.handle of <SocketIOServer at 0x7f481fd8ef90 fileno=19 address=0.0.0.0:8080>>(<socket at 0x7f485a9808d0 fileno=[Errno 9] Bad fil, (’ xxx.xxx.xxx.xxx ', 42165))> failed with AttributeError
: Invalid HTTP method: ‘\x04\x01\x00\x16\x7f\x00\x00\x01root\x00’
handler.handle()
self.log_request()
<Greenlet at 0x7f481fdccf50: <bound method SocketIOServer.handle of <SocketIOServer at 0x7f481fd8ef90 fileno=19 address=0.0.0.0:8080>>(<socket at 0x7f482067e050 fileno=[Errno 9] Bad fil, (’ xxx.xxx.xxx.xxx ', 18194))> failed with AttributeError
: Invalid HTTP method: ‘\r\n’
handler.handle()
self.log_request()
<Greenlet at 0x7f481fdccf50: <bound method SocketIOServer.handle of <SocketIOServer at 0x7f481fd8ef90 fileno=19 address=0.0.0.0:8080>>(<socket at 0x7f485a9808d0 fileno=[Errno 9] Bad fil, (xxx.xxx.xxx.xxx, 37079))> failed with AttributeError
: Invalid HTTP method: ‘username=admin&passwd=wdlinux.cn&Submit_login=test’
I have replaced IP addresses with “xxx.xxx.xxx.xxx” for security reasons. I am not sure what is going on at the moment. The web page access is running fine. Need to know if this is something I should be w worried about and if there is a fix. Any help is appreciated.
