Caffe on Xavier : NVCC cannot locate any architecture codes.
Hi, I’m trying to install Caffe on Xavier, following a post from https://devtalk.nvidia.com/default/topic/1044473/jetson-agx-xavier/caffe-installation-on-xavier/
However, I’m suffering from weird behavior of NVCC in xavier.
I am sure that I correctly followed patching Makefile. I editted the arch line as below.
CUDA_ARCH := -gencode arch=compute_72, code=sm_72
-gencode arch=compute_72, code=compute_72
However, after I type in make -j8, the error code says that There’s no such code.
nvcc fatal : Option ‘–generate-code arch=compute_72’, missing code
Makefile:604: recipe for target ‘.build_release/cuda/src/caffe/layers/deconv_layer.o’ failed
I would like to know what library should I fix(is it CMAKE? CUDA?), and why NVCC does not find any arch codes…
Solved myself
Removed pre-downloaded caffe folder completely, and get fresh files from Caffe git, and start over same process.
also, added one more path on Makefile.config
-LIBRARY_DIRS := (PYTHON_LIB) /usr/local/lib /usr/lib +LIBRARY_DIRS := (PYTHON_LIB) /usr/local/lib /usr/lib /usr/lib/aarch64-linux-gnu/hdf5/serial/
Not sure what I did wrong, but problem fixed.
