hello, I met segmentation fault when I trans. to rt model with caffe model. caffe model is resnet18.can you give me some advise.
model link: reId_免费高速下载|百度网盘-分享无限制
prototxt:
input: “data”
input_dim: 1
input_dim: 3
input_dim: 256
input_dim: 128
layer {
type: “Convolution”
bottom: “data”
top: “conv_blob1”
convolution_param {
num_output: 64
bias_term: false
pad: 3
kernel_size: 7
group: 1
stride: 2
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob1”
top: “batch_norm_blob1”
batch_norm_param {
use_global_stats: true
eps: 9.999999747378752e-06
layer {
type: “Scale”
bottom: “batch_norm_blob1”
scale_param {
bias_term: true
layer {
type: “Pooling”
top: “max_pool_blob1”
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
pad: 1
layer {
type: “Convolution”
bottom: “max_pool_blob1”
top: “conv_blob2”
convolution_param {
num_output: 64
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob2”
top: “batch_norm_blob2”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob2”
scale_param {
bias_term: true
layer {
type: “ReLU”
top: “relu_blob1”
layer {
type: “Convolution”
bottom: “relu_blob1”
top: “conv_blob3”
convolution_param {
num_output: 64
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob3”
top: “batch_norm_blob3”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob3”
scale_param {
bias_term: true
layer {
type: “Eltwise”
top: “add_blob1”
eltwise_param {
operation: SUM
layer {
type: “ReLU”
bottom: “add_blob1”
top: “relu_blob2”
layer {
type: “Convolution”
bottom: “relu_blob2”
top: “conv_blob4”
convolution_param {
num_output: 64
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob4”
top: “batch_norm_blob4”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob4”
scale_param {
bias_term: true
layer {
type: “ReLU”
top: “relu_blob3”
layer {
type: “Convolution”
bottom: “relu_blob3”
top: “conv_blob5”
convolution_param {
num_output: 64
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob5”
top: “batch_norm_blob5”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob5”
scale_param {
bias_term: true
layer {
type: “Eltwise”
top: “add_blob2”
eltwise_param {
operation: SUM
layer {
type: “ReLU”
bottom: “add_blob2”
top: “relu_blob4”
layer {
type: “Convolution”
bottom: “relu_blob4”
top: “conv_blob6”
convolution_param {
num_output: 128
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 2
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob6”
top: “batch_norm_blob6”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob6”
scale_param {
bias_term: true
layer {
type: “ReLU”
top: “relu_blob5”
layer {
type: “Convolution”
bottom: “relu_blob5”
top: “conv_blob7”
convolution_param {
num_output: 128
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob7”
top: “batch_norm_blob7”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob7”
scale_param {
bias_term: true
layer {
type: “Convolution”
top: “conv_blob8”
convolution_param {
num_output: 128
bias_term: false
pad: 0
kernel_size: 1
group: 1
stride: 2
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob8”
top: “batch_norm_blob8”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob8”
scale_param {
bias_term: true
layer {
type: “Eltwise”
top: “add_blob3”
eltwise_param {
operation: SUM
layer {
type: “ReLU”
bottom: “add_blob3”
top: “relu_blob6”
layer {
type: “Convolution”
bottom: “relu_blob6”
top: “conv_blob9”
convolution_param {
num_output: 128
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob9”
top: “batch_norm_blob9”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob9”
scale_param {
bias_term: true
layer {
type: “ReLU”
top: “relu_blob7”
layer {
type: “Convolution”
bottom: “relu_blob7”
top: “conv_blob10”
convolution_param {
num_output: 128
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob10”
top: “batch_norm_blob10”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob10”
scale_param {
bias_term: true
layer {
type: “Eltwise”
top: “add_blob4”
eltwise_param {
operation: SUM
layer {
type: “ReLU”
bottom: “add_blob4”
top: “relu_blob8”
layer {
type: “Convolution”
bottom: “relu_blob8”
top: “conv_blob11”
convolution_param {
num_output: 256
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 2
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob11”
top: “batch_norm_blob11”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob11”
scale_param {
bias_term: true
layer {
type: “ReLU”
top: “relu_blob9”
layer {
type: “Convolution”
bottom: “relu_blob9”
top: “conv_blob12”
convolution_param {
num_output: 256
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob12”
top: “batch_norm_blob12”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob12”
scale_param {
bias_term: true
layer {
type: “Convolution”
top: “conv_blob13”
convolution_param {
num_output: 256
bias_term: false
pad: 0
kernel_size: 1
group: 1
stride: 2
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob13”
top: “batch_norm_blob13”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob13”
scale_param {
bias_term: true
layer {
type: “Eltwise”
top: “add_blob5”
eltwise_param {
operation: SUM
layer {
type: “ReLU”
bottom: “add_blob5”
top: “relu_blob10”
layer {
type: “Convolution”
bottom: “relu_blob10”
top: “conv_blob14”
convolution_param {
num_output: 256
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob14”
top: “batch_norm_blob14”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob14”
scale_param {
bias_term: true
layer {
type: “ReLU”
top: “relu_blob11”
layer {
type: “Convolution”
bottom: “relu_blob11”
top: “conv_blob15”
convolution_param {
num_output: 256
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob15”
top: “batch_norm_blob15”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob15”
scale_param {
bias_term: true
layer {
type: “Eltwise”
top: “add_blob6”
eltwise_param {
operation: SUM
layer {
type: “ReLU”
bottom: “add_blob6”
top: “relu_blob12”
layer {
type: “Convolution”
bottom: “relu_blob12”
top: “conv_blob16”
convolution_param {
num_output: 512
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob16”
top: “batch_norm_blob16”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob16”
scale_param {
bias_term: true
layer {
type: “ReLU”
top: “relu_blob13”
layer {
type: “Convolution”
bottom: “relu_blob13”
top: “conv_blob17”
convolution_param {
num_output: 512
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob17”
top: “batch_norm_blob17”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob17”
scale_param {
bias_term: true
layer {
type: “Convolution”
top: “conv_blob18”
convolution_param {
num_output: 512
bias_term: false
pad: 0
kernel_size: 1
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob18”
top: “batch_norm_blob18”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob18”
scale_param {
bias_term: true
layer {
type: “Eltwise”
top: “add_blob7”
eltwise_param {
operation: SUM
layer {
type: “ReLU”
bottom: “add_blob7”
top: “relu_blob14”
layer {
type: “Convolution”
bottom: “relu_blob14”
top: “conv_blob19”
convolution_param {
num_output: 512
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob19”
top: “batch_norm_blob19”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob19”
scale_param {
bias_term: true
layer {
type: “ReLU”
top: “relu_blob15”
layer {
type: “Convolution”
bottom: “relu_blob15”
top: “conv_blob20”
convolution_param {
num_output: 512
bias_term: false
pad: 1
kernel_size: 3
group: 1
stride: 1
weight_filler {
type: “xavier”
dilation: 1
layer {
type: “BatchNorm”
bottom: “conv_blob20”
top: “batch_norm_blob20”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob20”
scale_param {
bias_term: true
layer {
type: “Eltwise”
top: “add_blob8”
eltwise_param {
operation: SUM
layer {
type: “ReLU”
bottom: “add_blob8”
top: “relu_blob16”
layer {
type: “Pooling”
bottom: “relu_blob16”
top: “ave_pool_blob1”
pooling_param {
pool: AVE
global_pooling: true
#kernel_size: 17
#stride: 17
layer {
type: “Reshape”
bottom: “ave_pool_blob1”
top: “view_blob1”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “BatchNorm”
bottom: “view_blob1”
top: “batch_norm_blob21”
batch_norm_param {
layer {
type: “Scale”
bottom: “batch_norm_blob21”
scale_param {
bias_term: true
