Hi I’m trying to estimate how much memory I need to store data on the device. Something I thought would be pretty straightforward and I wrote the following code.
[codebox]cout<<“Memory status before allocation”<<endl;
uint freeB, freeA;
uint total;
getMemoryStatus(&freeB, &total, true);
unsigned int memSizePFloat4 = sizeof(float) * 4 * m_params->noOfParticles;
unsigned int memSizePFloat = sizeof(float) * m_params->noOfParticles;
unsigned int memSizePUInt = sizeof(uint) * m_params->noOfParticles;
unsigned int memSizeGUInt = sizeof(uint) * m_params->noOfGrids;
allocateArray((void**)&m_dPos, memSizePFloat4);
allocateArray((void**)&m_dSortedPos,memSizePFloat4 );
allocateArray((void**)&m_dVel, memSizePFloat4);
allocateArray((void**)&m_dSortedVel, memSizePFloat4);
allocateArray((void**)&m_dAcceleration, memSizePFloat4);
allocateArray((void**)&m_dDensity, memSizePFloat);
allocateArray((void**)&m_dPressure, memSizePFloat);
allocateArray((void**)&m_dGridParticleHash, memSizePUInt);
allocateArray((void**)&m_dGridParticleIndex, memSizePUInt);
cout<<“Memory status after allocation”<<endl;
getMemoryStatus(&freeA, &total, true);
uint eMemoryUsage=(5memSizePFloat+2memSizePFloat+2*memSizePUInt
cout<<"Memory used: "<<freeB-freeA<<endl;
cout<<"Estemated memory use: "<<eMemoryUsage<<endl;
cout<<“--------------”<<endl;
cout<<"Diff: "<<freeB-freeA -eMemoryUsage<<endl;[/codebox]
Here is the output:
[indent]
Free : 95158272 bytes (92928 KB) (90 MB)
Total : 536150016 bytes (523584 KB) (511 MB)
17.748441510817748679% free, 82.251558489182258427% used
Free : 82903040 bytes (80960 KB) (79 MB)
15.46265737684879582% free, 84.53734262315120418% used
Memory used: 12255232
Estemated memory use: 4532472
Diff: 7722760[/indent]
(I’m pretty certain that the code to get the available memory is correct)
As you can see, the memory I estimated I would use is way of. It seams to me that there is more going on during the memory allocation than I first though. Can it have something to do about how different data types are aligned in device memory? I don’t know. Does anyone know where it goes wrong? Any solutions? I appreciate any kind of help.
Cheers,
