Calculating fps of sample object detector tracker
Hi team,
I am working on Nvidia drive Orin. I executed a sample object detector tracker module. I have provided a video as a input. I want to calculate its fps. I know how to calculate fps. But my doubt is, in the source code,in onProcess() function, getNextFrame() is called where camera is capturing frames, so where do i start the timer and end the timer?I am getting confused in where to start and end the timer to get accurate fps.I am attaching the source code for reference
new_sample_object_detector_code.txt (46.4 KB)
Dear @akshay.tupkar ,
Are you feeding live camera or video?
Dear @SivaRamaKrishnaNV
It is video feed
The sample video feed is recorded at 30FPS speed.
