Calculation of pixel_clk_hz for device tree
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html#sensor-pixel-clock
This guide tells pixel_clk_hz can be calculated with
“pixel_clk_hz” = sensor data rate per lane (Mbps) * number of lanes / bits per pixel
When a mipi frame contains both RAW12(bpp=12, for active pixels) & EMB(bpp=8, for meta lines), which value can be used in the equation above?
Should use 12 for it.
