When compiling the MWE
#include <iostream>
#include "cuda.h"
struct Foo{
Foo( ){
std::cout << "Construct" << std::endl;
Foo( const Foo & that ){
std::cout << "Copy construct" << std::endl;
__host__ __device__
int bar( ) const {
return 0;
template<typename CopyBody>
__global__
void kernel( CopyBody cBody ){
cBody( );
template <typename CopyBody>
void wrapper( CopyBody && cBody ){
std::cout << "enquing kernel" << std::endl;
kernel<<<1,32>>>( cBody );
std::cout << "kernel enqued" << std::endl;
int main(int argc, char** argv) {
Foo foo;
kernel<<<1,32>>>( [=] __device__ ( ) { foo.bar( ); } );
cudaDeviceSynchronize( );
wrapper( [=] __device__ ( ) { foo.bar( ); } );
return 0;
with CUDA 10.1 ( nvcc --expt-extended-lambda test.cu -o test
) the compiler warns about test.cu(16): warning: calling a __host__ function("Foo::Foo") from a __host__ __device__ function("") is not allowed
. However, the copy constructor is never called on the device. CUDA 9.1 does not produce this warning.
- What is the difference between the direct call to
kernel
(not producing the warning) and thewrapper
version? - Is is safe to ignore this warning?
- Where to put
#pragma hd_warning_disable
or#pragma nv_exec_check_disable
to get rid of it?
The given MWE is a based on a larger project, where the wrapper
decides whether to use a __device__
or __host__
lambda. The constructors/destructors cannot be marked as __host__ __device__
since they need to be called on CPU only ((de)allocating CUDA memory) - this or deleting the constructors/destructor (and letting the compilers to create the default __host__
and __device__
versions) would otherwise help.
