Calling a kernel function from an OpenMP loop
Hello everyone,
I am new to parallel programming and I am more theoretician than programmer, so please apologize for any obvious mistakes!
My goal : I want to call a kernel function inside an OpenMP loop.
My problem is that even when my kernel function kernel_normalization_voxels is empty, and even for a same number of threads sometimes the code continues to the end sometimes not.
Here is my code :
#pragma omp parallel num_threads(num_slices_to_reconstruct)
int current_slice = omp_get_thread_num();
memset(normalization_voxels, 0, sizeof(float) * current_slice * (*NB_VOXELS) * nb_OS);
int numero_subset, num_projection;
for (numero_subset = 0; numero_subset < nb_OS; numero_subset++)
    for (int i = 0; i < NB_PROJECTIONS / nb_OS; i++)
        num_projection = Table_OS[numero_subset * NB_PROJECTIONS / nb_OS + i];
        kernel_normalization_voxels << <nb_cuda_cores, 32 >> > (...);
        cudaDeviceSynchronize();
  • normalization_voxels, NB_VOXELS are defined with a cudaMallocManged ;
  • nb_OS, nb_cuda_cores and num_slices_to_reconstruct and the table Table_OS are defined on the CPU ;
  • NB_PROJECTIONS is #define in a .h file.
Even with an empty kernel kernel_normalization_voxels
global void kernel_projection(…)
my program does not go all the time through all the code to the end.
Does anyone have an idea where the problem might come from?
Thank you a lot for your help!
You might try compiling the CUDA code with --default-stream and use
cudaStreamSynchronize(CU_STREAM_PER_THREAD);
https://docs.nvidia.com/cuda/cuda-runtime-api/stream-sync-behavior.html
Then you don’t synchronize the entire device, but spearately per thread.
I am not sure if this will fix the problem, but at least each OpenMP thread will then act more independently from the others.
Thank you very much for your response!
I have been working on it since tuesday… I encounter different issues that do not facilitate the resolution of my OpenMP - CUDA problem. First I failed to solve my problem with the launch of my .cu in console mode. I get this error message which I did not succeed to resolve
error: asm operand type size(8) does not match type/size implied by constraint ‘r’
Here is what I tried, I followed your link and this one GPU Pro Tip: CUDA 7 Streams Simplify Concurrency | NVIDIA Developer Blog. I added #define CUDA_API_PER_THREAD_DEFAULT_STREAM at the top of my programm and added the option -default-stream per-thread in kernel.cu -> properties -> CUDA C/C++ -> Command Line. Can this work ?
Then I modified my code into
  • Creation of the streams
  • the OpenMP loop with four calls to kernel functions on a precise stream
cudaStream_t* streams = (cudaStream_t*)calloc(omp_get_max_threads(), sizeof(cudaStream_t) );
for (int i = 0; i < omp_get_max_threads(); i++)
cudaStreamCreate(&streams[i]);
#pragma omp for
for (int current_slice = 0; current_slice < total_cuts; current_slice++)
    for (1)
        for (2)
            for (3)
                kernel_projection << <nb_cuda_cores, 32, 0, streams[index_thread] >> > (...);
            for (4)
                kernel_retroprojection << <nb_cuda_cores, 32, 0, streams[index_thread] >> > (...);
            kernel_object_update << <nb_cuda_cores, 32, 0, streams[index_thread] >> > (...);
            kernel_tab_to_redistribute<< <nb_cuda_cores, 32, 0, streams[index_thread] >> > (...);
kernel_retroprojection constructs a table that kernel_object_update uses. Then, kernel_tab_to_redistribute sets the values of the table to 0.
I need to set those values to 0 for each course of the loop (3).
Does someone see something obviously false ? Because with the call of kernel_tab_to_redistribute, the result of my program is false. Without kernel_tab_to_redistribute, the result is still false but a little closer to the right result.
