I am trying to get a simple ray tracer following Peter Shirley’s “Ray Tracing in One Weekend Series” running on CUDA, but I am running into, what I believe is, undefined behaviour using virtual functions in kernels.
I’ve made sure that the objects are instantiated and only ever used on the device side, which according to the CUDA Programming Guide should be enough to get virtual functions to run.
What is really odd is that the virtual functions work just fine inside one kernel (I call the hit
method inside of the render
kernel), but not the other, which leads me to believe that it might not necessarily be just a virtual functions problem, but maybe I am not allocating memory properly.
What the code should boil down to is
- instantiating a bunch of
sphere
objects on the device, which all inherit from a virtual base class calledhittable
and have just two functions -hit
andbounding_box
. - running through them and constructing a Bounding Volume Hierarchy (this is where I get the error)
- the render function checks for hits against the Bounding Volume Hierarchy (I’ve removed the code for that as even without it we get the error, so it should be irrelevant)
I am running this on a RTX 2070, with Cuda release 10.1.105.
One thing to note is that if I use the --relocatable-device-code (-rdc=true)
the code runs with no errors, but since that is bound to have performance overhead, I’d rather avoid it. If I must use rdc=true
in the end, that’s fine, but I’d like to understand why.
My question is why am I getting the errors from cuda-memcheck and cuda-gdb posted at the bottom?
Here’s what I’ve got, and at the bottom I’ll add the cuda-gdb and cuda-memcheck outputs
hittable.h
class hittable
public:
__device__ virtual bool hit(
const ray& r, float t_min,
float t_max, hit_record& rec) const = 0;
__device__ virtual bool bounding_box(float t0, float t1, aabb& box) const = 0;
aabb box;
sphere.h
class sphere: public hittable
public:
__device__ sphere() {}
__device__ sphere(vec3 cen, float r, material *m) :
center(cen), radius(r), mat_ptr(m) {}
__device__ virtual bool hit(const ray& r, float t_min,
float t_max, hit_record& rec) const;
__device__ virtual bool bounding_box(float t0, float t1, aabb& _box) const;
vec3 center;
float radius;
material *mat_ptr;
aabb box;
// Skipping hit implementation as it is irrelevant
__device__ bool sphere::bounding_box(float t0, float t1, aabb& _box) const
_box = aabb(center - vec3(radius, radius, radius),
center + vec3(radius, radius, radius));
return true;
Here are the construction kernels defined in main.cu
__global__ void create_world(hittable** d_list, hittable** d_world)
// The kernel that initializes the spheres on the device
if (threadIdx.x == 0 && blockIdx.x == 0)
*(d_list) = new sphere(vec3(-1,0,-1), .5, new dielectric(1.5));
*(d_list+1) = new sphere(vec3(-1,0,-1), -.45, new dielectric(1.5));
*(d_list+2) = new sphere(vec3(0,0,-1), .5, new lambertian(vec3(.1, .2, .5)));
*(d_list+3) = new sphere(vec3(0,-100.5,-1), 100, new lambertian(vec3(.8, .8, .0)));
*(d_list+4) = new sphere(vec3(1,0,-1), .5, new metal(vec3(.8, .6, .2), 0.3));
*d_world = new hittable_list(d_list, 5);
__global__ void generate_BVH_iterative(hittable** l, hittable** world, int n, float time0, float ime1, bvh_node** root_bvh, bvh_node** bvh_heap)
bvh_node* explore_list[1000];
bvh_node** explore_ptr = explore_list;
*explore_ptr++ = NULL;
bvh_node* node = new bvh_node();
int c = 0;
while(node != NULL)
c++;
printf("anything\n"); // Doing anything at all in here causes the error
// This is where I do my BVH construction implementation
// The reason I am including this loop is that without it, even,
// with the bounding_box call at the bottom, the code runs
node = *--explore_ptr;
aabb* box = &((*l)->box);
(*l)->bounding_box(.0f, 1.0f, *box); // If I comment this out, and use the cached box, it all works,
//even with the full BVH construction in the while loop above
return;
And finally, here is the stripped down int main()
// Allocate world pointers
hittable **d_list;
hittable **d_world;
cudaMalloc((void**)&d_list, 5 * sizeof(hittable*));
cudaMalloc((void**)&d_world, sizeof(hittable*));
// use world pointers to create world
create_world<<<1, 1>>>(d_list, d_world);
CudaCheckError();
// Allocate bvh data
bvh_node **bvh_heap;
bvh_node **bvh_root;
cudaMalloc((void**)&bvh_heap, 1000 * sizeof(bvh_node*));
cudaMalloc((void**)&bvh_root, 1 * sizeof(bvh_node*));
// Create bvh
generate_BVH_iterative<<<1, 1>>>(d_list, d_world, 5, .0f, 1.0f, bvh_root, bvh_heap);
CudaCheckError(); // This prints the error
// I am including the call to render, just to make sure I am not missing something in terms
// of there being difference between the 2 kernels. 'd_pixels', 'd_rand_state' and 'cam' are
// properly defined above, and they work fine when not using BVH, but I've trimmed down the code
render<<<blocks, threads>>>(nx, ny, d_pixels, bvh_root, d_world, d_rand_state, cam);
// Even though in the above render kernel I use the hit method, which is also a virtual function
// it works just fine
free_world<<<1,1>>>(d_list, d_world);
Here is the cuda-memcheck output (it reports the error in material.h:81
which has no relation at all to the BVH construction, which leads me to believe it’s just accessing the wrong memory address)
========= CUDA-MEMCHECK
========= Invalid __local__ write of size 4
========= at 0x000037f0 in /home/vshotarov/Projects/death-star-gpu/material.h:81:generate_BVH_iterative(hittable**, hittable**, int, float, float, bvh_node**, bvh_node**)
========= by thread (0,0,0) in block (0,0,0)
========= Address 0x00ffdc2c is out of bounds
========= Device Frame:/home/vshotarov/Projects/death-star-gpu/material.h:81:generate_BVH_iterative(hittable**, hittable**, int, float, float, bvh_node**, bvh_node**) ($_Z22generate_BVH_iterativePP8hittableS1_iffPP8bvh_nodeS4_$_ZNK6sphere12bounding_boxEffR4aabb : 0x20)
========= Saved host backtrace up to driver entry point at kernel launch time
========= Host Frame:/lib64/libcuda.so.1 (cuLaunchKernel + 0x2fe) [0x28ccce]
========= Host Frame:./a.out [0x11a19]
========= Host Frame:./a.out [0x11aa7]
========= Host Frame:./a.out [0x47df5]
========= Host Frame:./a.out [0x49f5]
========= Host Frame:./a.out [0x4661]
========= Host Frame:./a.out [0x46be]
========= Host Frame:./a.out [0x3fa5]
========= Host Frame:/lib64/libc.so.6 (__libc_start_main + 0xf3) [0x24413]
========= Host Frame:./a.out [0x39ce]
========= Program hit cudaErrorLaunchFailure (error 719) due to "unspecified launch failure" on CUDA API call to cudaDeviceSynchronize.
========= Saved host backtrace up to driver entry point at error
========= Host Frame:/lib64/libcuda.so.1 [0x3a0403]
========= Host Frame:./a.out [0x2fdb6]
========= Host Frame:./a.out [0x4b53]
========= Host Frame:./a.out [0x3fb4]
========= ERROR SUMMARY: 2 errors
And lastly, here is the cuda-gdb output
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
[New Thread 0x7fffdffff700 (LWP 8972)]
[New Thread 0x7fffdf7fe700 (LWP 8973)]
[New Thread 0x7fffdeffd700 (LWP 8974)]
CUDA Exception: Warp Out-of-range Address
The exception was triggered at PC 0xba5ff0
Thread 1 "a.out" received signal CUDA_EXCEPTION_5, Warp Out-of-range Address.
[Switching focus to CUDA kernel 0, grid 3, block (0,0,0), thread (0,0,0), device 0, sm 0, warp 3, lane 0]
0x0000000000ba6060 in generate_BVH_iterative(hittable**, hittable**, int, float, float, bvh_node**, bvh_node**)<<<(1,1,1),(1,1,1)>>> ()
