Hello
I am facing a linking issue with a codebase compiled with PGI compilers
to a library built with Microsoft cl compiler using Visual Studio.
I am getting the following error:
io_h5file_interface.o : error LNK2019: unresolved external symbol H5check_version referenced in function io_h5init_file_
When I do:
$dumpbin.exe /SYMBOLS io_h5file_interface.o
I see the following in the output:
020 00000000 SECT1 notype () External | io_h5init_file_
021 00000000 UNDEF notype External | H5check_version
And when I check for the symbols in the library that I am trying to link to using:
$dumpbin.exe /SYMBOLS vtkhdf5.lib, I see the following in the output:
322 00001CE0 SECT6 notype () External | _H5check_version
The library has been built through CMAKE using Visual Studio 9 2008 as the generator and it uses the Microsoft cl.exe C compiler to compile.
The codebase that I am trying to link to this library has been compiled using pgcc and pgf90 PGI compilers. I think there is some name decoration problem and there is that leading underscore with the symbol in the library which is not there in the object file of the codebase.
I was looking for some ways (trying the -Miface=cref flags ) to resolve it but haven’t found it yet. Can you please suggest something to resolve this naming convention issue ?
Thanks & Regards,
Kunal
