My goal is to figure out how to do fast screen capture. One way to do that is utilize the GPU to grab the frame (and then later encode it quickly on the GPU).
I am trying to do this on Linux and using low-level APIs like DRM/KMS to achieve this.
Currently, I am not getting back any connectors.
Running: Ubuntu 18.04.2 LTS (GNU/Linux 4.15.0-1044-aws x86_64)
Bug report log: Dropbox - File Deleted
C++ Code:
#include <stdio.h>
#include <fcntl.h>
#include <drm/drm.h>
#include <drm/drm_mode.h>
#include <sys/ioctl.h>
#include <cstdint>
#include <stdint.h>
using namespace std;
int main() {
int dri_fd = open("/dev/dri/card0", O_RDWR);
printf("fd: %d\n", dri_fd);
if (dri_fd == -1) {
printf("Could not open card0\n");
return -1;
ioctl(dri_fd, DRM_IOCTL_SET_MASTER, 0); // We only need to be "master" to do the actual KMS mode setting
drm_mode_card_res res = {0};
ioctl(dri_fd, DRM_IOCTL_MODE_GETRESOURCES, &res);
printf("FB Count: %d\n", res.count_fbs);
printf("Connector Count: %d\n", res.count_connectors);
printf("CRTC Count: %d\n", res.count_crtcs);
printf("Encoder Count: %d\n", res.count_encoders);
uint64_t fb_buf[10] = {0};
uint64_t crtc_buf[10] = {0};
uint64_t conn_buf[10] = {0};
uint64_t enc_buf[10] = {0};
res.fb_id_ptr = (uint64_t)fb_buf; // Frame buffer
res.crtc_id_ptr = (uint64_t)crtc_buf; // A CRTC represents the overall display pipeline.
res.connector_id_ptr = (uint64_t)conn_buf; // In DRM connectors are the general abstraction for display sinks, and include als fixed panels or anything else that can display pixels in some form.
res.encoder_id_ptr = (uint64_t)enc_buf; // An encoder takes pixel data from a CRTC and converts it to a format suitable for any attached connector.
// Get resource IDs
return 0;
Output:
:~$ sudo ./capture
fd: 3
FB Count: 0
Connector Count: 0
CRTC Count: 0
Encoder Count: 0
My expectation would be that Connector count or FB count would return something non-zero since my M60 NVIDIA GPU appears connected to X11/Gnome:
ubuntu:~$ nvidia-smi
Fri Aug 2 00:59:01 2019
| NVIDIA-SMI 430.30 Driver Version: 430.30 CUDA Version: 10.2 |
| 0 Tesla M60 Off | 00000000:00:1E.0 Off | 0 |
| N/A 28C P8 14W / 150W | 141MiB / 7618MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 3255 G /usr/lib/xorg/Xorg 57MiB |
| 0 3286 G /usr/bin/gnome-shell 82MiB |
Other relevant diagnostic information:
ubuntu:~$ cat /etc/modprobe.d/nvidia.conf
options nvidia-drm modeset=1
ubuntu:~$ cat /etc/modprobe.d/blacklist.conf
# This file lists those modules which we don't want to be loaded by
# alias expansion, usually so some other driver will be loaded for the
# device instead.
# evbug is a debug tool that should be loaded explicitly
blacklist evbug
# these drivers are very simple, the HID drivers are usually preferred
blacklist usbmouse
blacklist usbkbd
# replaced by e100
blacklist eepro100
# replaced by tulip
blacklist de4x5
# causes no end of confusion by creating unexpected network interfaces
blacklist eth1394
# snd_intel8x0m can interfere with snd_intel8x0, doesn't seem to support much
# hardware on its own (Ubuntu bug #2011, #6810)
blacklist snd_intel8x0m
# Conflicts with dvb driver (which is better for handling this device)
blacklist snd_aw2
# Causes trackpads to stop working on Lenovo 11e 2nd gen (Ubuntu: #1802135)
# and Lenovo x240 to hang on boot (Ubuntu: #1802689)
blacklist i2c_i801
# replaced by p54pci
blacklist prism54
# replaced by b43 and ssb.
blacklist bcm43xx
# most apps now use garmin usb driver directly (Ubuntu: #114565)
blacklist garmin_gps
# replaced by asus-laptop (Ubuntu: #184721)
blacklist asus_acpi
# low-quality, just noise when being used for sound playback, causes
# hangs at desktop session start (Ubuntu: #246969)
blacklist snd_pcsp
# ugly and loud noise, getting on everyone's nerves; this should be done by a
# nice pulseaudio bing (Ubuntu: #77010)
blacklist pcspkr
# EDAC driver for amd76x clashes with the agp driver preventing the aperture
# from being initialised (Ubuntu: #297750). Blacklist so that the driver
# continues to build and is installable for the few cases where its
# really needed.
blacklist amd76x_edac
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
ubuntu:~$ lsmod
Module Size Used by
nvidia_drm 45056 3
nvidia_modeset 1110016 3 nvidia_drm
nvidia 18796544 218 nvidia_modeset
drm_kms_helper 167936 1 nvidia_drm
drm 393216 6 drm_kms_helper,nvidia_drm
i2c_core 73728 3 drm_kms_helper,nvidia,drm
fb_sys_fops 16384 1 drm_kms_helper
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
ipmi_devintf 20480 0
ipmi_msghandler 53248 2 ipmi_devintf,nvidia
serio_raw 16384 0
sch_fq_codel 20480 9
ib_iser 49152 0
rdma_cm 61440 1 ib_iser
iw_cm 45056 1 rdma_cm
ib_cm 53248 1 rdma_cm
ib_core 225280 4 rdma_cm,iw_cm,ib_iser,ib_cm
iscsi_tcp 20480 0
libiscsi_tcp 20480 1 iscsi_tcp
libiscsi 53248 3 libiscsi_tcp,iscsi_tcp,ib_iser
scsi_transport_iscsi 98304 3 iscsi_tcp,ib_iser,libiscsi
parport_pc 36864 0
ppdev 20480 0
lp 20480 0
parport 49152 3 parport_pc,lp,ppdev
ip_tables 28672 0
x_tables 40960 1 ip_tables
autofs4 40960 2
btrfs 1126400 0
zstd_compress 163840 1 btrfs
raid10 53248 0
raid456 143360 0
async_raid6_recov 20480 1 raid456
async_memcpy 16384 2 raid456,async_raid6_recov
async_pq 16384 2 raid456,async_raid6_recov
async_xor 16384 3 async_pq,raid456,async_raid6_recov
async_tx 16384 5 async_pq,async_memcpy,async_xor,raid456,async_raid6_recov
xor 24576 2 async_xor,btrfs
raid6_pq 114688 4 async_pq,btrfs,raid456,async_raid6_recov
libcrc32c 16384 1 raid456
raid1 40960 0
raid0 20480 0
multipath 16384 0
linear 16384 0
crct10dif_pclmul 16384 0
crc32_pclmul 16384 0
ghash_clmulni_intel 16384 0
pcbc 16384 0
aesni_intel 188416 0
aes_x86_64 20480 1 aesni_intel
crypto_simd 16384 1 aesni_intel
glue_helper 16384 1 aesni_intel
cryptd 24576 3 crypto_simd,ghash_clmulni_intel,aesni_intel
ena 94208 0
ubuntu:~$ dmesg | grep -i NV
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-1044-aws root=UUID=8abb4f2d-c7e0-4daf-80b5-24e1c814cf55 ro rdblacklist=nouveau console=tty1 console=ttyS0 nvme_core.io_timeout=4294967295
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-1044-aws root=UUID=8abb4f2d-c7e0-4daf-80b5-24e1c814cf55 ro rdblacklist=nouveau console=tty1 console=ttyS0 nvme_core.io_timeout=4294967295
[ 0.616004] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 2.324353] rtc_cmos 00:02: alarms up to one day, 114 bytes nvram, hpet irqs
[ 7.467294] nvidia: loading out-of-tree module taints kernel.
[ 7.467301] nvidia: module license 'NVIDIA' taints kernel.
[ 7.476833] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 7.488128] nvidia-nvlink: Nvlink Core is being initialized, major device number 243
[ 7.489962] nvidia 0000:00:1e.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 7.490503] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 430.30 Mon Jun 10 05:04:34 CDT 2019
[ 7.511462] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 430.30 Mon Jun 10 04:38:05 CDT 2019
[ 7.514021] [drm] [nvidia-drm] [GPU ID 0x0000001e] Loading driver
[ 8.790628] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:00:1e.0 on minor 0
[ 227.400569] [drm] [nvidia-drm] [GPU ID 0x0000001e] Unloading driver
[ 227.400786] NVRM: Persistence mode is deprecated and will be removed in a future release. Please use nvidia-persistenced instead.
[ 227.585668] nvidia-modeset: Unloading
[ 227.876830] nvidia-nvlink: Unregistered the Nvlink Core, major device number 243
[ 237.950918] nvidia-nvlink: Nvlink Core is being initialized, major device number 243
[ 237.952092] nvidia 0000:00:1e.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 237.952418] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 430.30 Mon Jun 10 05:04:34 CDT 2019
[ 237.955126] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 430.30 Mon Jun 10 04:38:05 CDT 2019
[ 237.956384] [drm] [nvidia-drm] [GPU ID 0x0000001e] Loading driver
[ 239.061266] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:00:1e.0 on minor 0
