When calling function NvMediaImageGetBits, it takes about 10 milliseconds of time,but NvMediaImagePutBits only takes about 2 milliseconds of time. It seems that NvMediaImageGetBits take too much time,this is a little uncommon.
Could you tell me why NvMediaImageGetBits take so much time? Is there anyother function can replace the function NvMediaImageGetBits?
I’m facing a similar problem. I’m using NvMediaImageGetBits function to read NvMediaImage structure and write the content into buffer that I provide to this function. Final output is good, but it takes about 22 milliseconds. After I changed NVM_SURF_ATTR_CPU_ACCESS_UNCACHED to NVM_SURF_ATTR_CPU_ACCESS_CACHED processing time dropped to 14 milliseconds. Still, I need it faster. Can you please provide some useful information to me, or maybe give me source code of this function, or anything else that I could use in order to speed up my program.
Code is running on DRIVE AGX Developer Kit E3550 platform.
Image format is .jpeg with resoultion of 1280x720p.
I am using Drive SDK/PDK version 5.0.13. Cuda-Toolkit is 10.0.96. I work directly on Linux (Ubuntu 16.04), I don’t use any additional drive software components (e.g. DriveWorks).
