Hi Experts,
In most of the SDK files, kernels are called from host functions in .cu files.
Is it possible to call kernels from host functions in .cpp files…!..? External Image
Thanks in Advance,
karguvel
Hi Experts,
Thanks in Advance,
karguvel
Using the runtime API, it is not possible. If you want to launch kernels from plain C or C++ code, you will need to write a wrapper function inside the .cu file which other code can call.
Thank you External Media
you cannot call directly kernel function in *.cpp file because the calling instruction must be compiled by nvcc (nvcc use for compiling *.cu file) so you have to
create a function (in *.cu file) to call the kernel function (let say that is buffer function). In this way, you can call this buffer function as a normal function.
