Is there any way to call the strchr function from the kernal because I really have to make use of that function in my kernal ?
I’m getting the error message
Calling a host function
The problem is that you’re trying to call a compiled library call. If you copied the source code for strchr into your kernel, it might work.
You’ll basically have to port strchr to CUDA :)
Thanks for the response… :)
