Calling vector-valued function from subroutine triggers bounds error
Hello -
I have a function that returns a vector of reals that I would like to call from within a subroutine; both function and subroutine are CONTAINed within a program. Calling the function from within the subroutine triggers an out-of-bounds runtime error (the upper bound of the array tau is reported to be 0) while calling the function from the main program works just fine. A minimal reproducer is:
program crash_reproducer
  use, intrinsic :: iso_c_binding, only: c_float, c_double, c_long, c_int, c_bool
  implicit none
  integer, parameter :: wp = c_double
  integer,  parameter :: ncol = 8, nlay=16
  integer             :: icol
  real(wp), parameter :: sigma = 5.670374419e-8_wp, & ! Stefan-Boltzmann constant
                         D     = 1.66_wp              ! Diffusivity angle, from single-angle RRTMGP solver
  real(wp), dimension(  ncol), parameter :: sfc_t     = [(285._wp, icol = 1,ncol/2), &
                                                         (310._wp, icol = 1,ncol/2)]
  real(wp), dimension(  ncol), parameter :: lw_total_tau = [0.1_wp, 1._wp, 10._wp, 50._wp, &
                                                            0.1_wp, 1._wp, 10._wp, 50._wp] ! Would be nice to parameterize
  ! Problem demonstration - the vector-valued function gray_rad_equil_olr works when called directly...
  print '("Return vector-valued function: ", 8(f6.2, 2x))', gray_rad_equil_olr(sfc_t, lw_total_tau)
  ! ... but not when called from within a subroutine, returning instead a bounds error
  call gray_rad_equil(sfc_t, lw_total_tau, nlay, .true.)
contains
  ! Function version
  function gray_rad_equil_olr(T, tau)
    real(wp), dimension(:), intent(in) :: T, tau
    real(wp), dimension(size(T))       :: gray_rad_equil_olr
    gray_rad_equil_olr(:) = (2._wp * sigma * T(:)**4)/(2 + D * tau(:))
  end function gray_rad_equil_olr
  ! Subroutine version
  subroutine gray_rad_equil(sfc_t, total_tau, nlay, top_at_1)
    real(wp), dimension(:), intent(in) :: sfc_t, total_tau
    integer,                intent(in) :: nlay
    logical,                intent(in) :: top_at_1
    ! Longwave sources - for broadband these are sigma/pi T^4
    !   (isotropic radiation)
    print '("Called from within subroutine: ", 8(f6.2, 2x))', gray_rad_equil_olr(sfc_t, lw_total_tau)
  end subroutine gray_rad_equil
end program crash_reproducer
The code is compiled with debugging flags: -Mallocatable=03 -Mstandard -Mbounds -Mchkptr -Kieee -Mchkstk The failure occurs at least in nvfortran 23.9
If you change to use the name you are actually passing to the routine, it seems to work:
!print ‘("Called from within subroutine: ", 8(f6.2, 2x))’, gray_rad_equil_olr(sfc_t, lw_total_tau)
print ‘("Called from within subroutine: ", 8(f6.2, 2x))’, gray_rad_equil_olr(sfc_t, total_tau)
nvfortran -Mstandard -Mbounds -Mchkptr -Kieee -Mchkstk forum4.f90
$ ./a.out
8 8
Return vector-valued function: 345.43 204.43 40.23 8.80 483.54 286.16 56.31 12.32
8 8
Called from within subroutine: 345.43 204.43 40.23 8.80 483.54 286.16 56.31 12.32
Thanks kindly for the prompt response. Indeed this was a programming error on my part! Scope is a bear…
