Hi all. I’m trying to use a pair of raspberry pi v2 cameras with IMX219 sensors on a Jetson Orin Nano 8GB running JetPack 6.2, but I’ve encountered problems using the CAM0 CSI port. CAM1 works perfectly fine, but nothing I’ve tried makes CAM0 work. I’m using the following gstreamer pipeline to view camera feeds:
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e
When I do so with the CAM0 port, the viewing window opens, remains black, and closes itself after a few seconds claiming it received an EOS. The terminal output is identical to the output when using CAM1, just without the duration indicator.
Running “ls /dev | grep “video”” always shows all the cameras I have plugged in regardless of port. "sudo dmesg | grep “imx219"” shows the same lines regardless of which port I’m using, though sometimes with a different order.
I have tried the following to fix the error, to no avail:
- Replacing the camera and ribbon cable
- Removing the CSI port itself from the board and soldering a new one on
- Checking all 22 pins and the cable ends with a multimeter
- Using all imx219 versions (i.e. dual, A, B, etc.) available with the jetson-io.py tool
- Recompiling the IMX219 Dual dtbo
- Setting the lane_polarity in the IMX219 Dual dtbo to 0, 1, 6, and 9
- Using alternate gstreamer pipelines to view feed
I’ve seen other forum posts with a similar problem but they all ended up having a hardware issue solved by replacing various parts. Given that I’ve swapped out every piece of hardware short of the entire Jetson board (which I cannot do), I doubt this is my issue. Does anyone know what might be causing this?
Thanks in advance.
