I have attached 4 camera and I am capturing and transferring writing them to Nvbuffer. I am encoding them afterwards using H265. But I am seeing these errors after running it for few seconds.
NvCaptureStatusErrorDecode Capture-Error: CSIMUX_FRAME (0x00000002)
CsimuxFrameError_Regular : 0x000000a2
Stream ID [ 2: 0]: 2
VPR state from fuse block [ 3]: 0
Frame end (FE) [ 5]: 1
A frame end has been found on a regular mode stream.
FS_FAULT [ 7]: 1
A FS packet was found for a virtual channel that was already in frame.An errored FE packet was injected before FS was allowed through.
Binary VC number [3:2] [27:26]: 0
To get full binary VC number, user need to concatenate VC[3:2] and VC[1:0] together.
SCF: Error InvalidState: Capture error with status 2 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 880)
NvCaptureStatusErrorDecode Stream 2.0 failed: sof_ts 2295162956672 eof_ts 2295197262784 frame 1 error 2 data 0x000000a2
FS_FAULT [ 7]: 1
NvCaptureStatusErrorDecode Stream 2.0 failed: sof_ts 2295197431584 eof_ts 2295231737696 frame 2 error 2 data 0x000000a2
FS_FAULT [ 7]: 1
