Camera device tree overlay never takes effect on stock AGX Thor Developer Kit (JetPack 7.x) — all camera tooling reports zero devices
Platform: Jetson AGX Thor Developer Kit (stock, unmodified — no custom carrier board)
BIOS: 39.2.1-gcid-46758480
Kernel: 6.8.12-1021-tegra
Goal: Trying to get any camera path registered (real sensor or even just a Test Pattern Generator) purely to exercise the VI/ISP pipeline for driver-level testing. No physical camera is attached yet — currently trying to determine whether that’s even possible given the tooling issues below.
What I’ve found so far, across three independent layers of the stack:
  1. dmesg | grep -iE "isp|vi|nvcsi|rtcpu" shows the camera RTCPU boots successfully (firmware cpu=rce cmd=6, confirmed via SHA1), but both ISP instances and both VI instances report driver not enabled, cannot register any devices. All five camera-devices[0] through [4] device-tree slots report node has no device.
  2. media-ctl -p confirms this — the media controller device exists (tegra-camrtc-ca, bus platform:tegra-capture-vi) but “Device topology” is completely empty: zero entities, zero pads, zero links.
  3. sudo python3 /opt/nvidia/jetson-io/jetson-io.py produces no output and exits with code 1. The scriptable backend confirms why: sudo python3 /opt/nvidia/jetson-io/config-by-hardware.py -l throws RuntimeError: Platform not supported, no headers found! — this board isn’t recognized by jetson-io’s tooling at all yet.
  4. I looked into applying one of the stock camera overlays already present in /boot (e.g. tegra264-p3971-camera-eCAM130A-overlay.dtbo) via the documented OVERLAY_DTB_FILE + reflash procedure, but found two existing threads describing this exact procedure failing to take effect even when followed correctly:
  5. For completeness, nvargus_nvraw --lps (Argus’s own sensor enumeration) also fails, with getCameraDevices() failed — consistent with the same empty device-tree state.
    Followings are my questions
    1.Is there a confirmed, working procedure for applying a camera overlay via OVERLAY_DTB_FILE + reflash on the current Thor JetPack 7.x release? Are the two threads above the same root cause as what I’m hitting, and has either been resolved internally even if not reflected in the thread?
    2.Is jetson-io/config-by-hardware.py expected to support the stock AGX Thor Developer Kit soon, or is there a different officially recommended workflow for the stock devkit specifically (versus custom carrier boards)?
    3.Is there a way to enable the VI/NVCSI Test Pattern Generator on the stock devkit without needing a specific vendor camera module, purely to validate the capture/ISP pipeline independent of camera hardware?
Hi!
Hope you’re doing well. As for your first question, I’d take the approach mentioned by NVIDIA’s Develop Guide using the l4t_initrd_flash.sh script and the board.conf file to override variables, it could be worth to take a shot. Regarding your third question, there is a SIPL RAW-file simulator input throught nvispl_camera --input-raw-files. This could be a useful option to investigate and the SIPL Documentation mentions that the RAW frames can be processed through the ISP pipeline, but I’m not certain that the simulator exercises this same path. Hopefully you’ll find this information useful.
Best regards,
Fabian Munoz
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Disclaimer: Technical breakdown synthesized with AI support for JetPack 7.x / AGX Thor camera pipeline diagnostics).
  1. OVERLAY_DTB_FILE & Jetson-IO on Thor: jetson-io.py fails on the AGX Thor Dev Kit because header mapping definitions under /opt/nvidia/jetson-io/ are not yet populated for the Thor carrier layout in JetPack 7.x. For custom camera bring-up on JP 7.x, standard practice is to compile the custom nodes directly into the main kernel DTB (DTB_FILE) or build tree rather than relying on dynamic runtime DTBO loading.
  2. Pipeline Testing Without Hardware: Because the RTCPU/VI driver (tegra-camrtc-ca) requires an active, registered sensor subdevice node to build the media controller topology (media-ctl), you cannot generate a live /dev/mediaX topology purely in software without a bound sensor driver.
    • To validate the downstream ISP/SIPL processing path independent of CSI physical links, use the SIPL RAW file simulator (nvsipl_camera --input-raw-files <raw_file>).
