I’m bringing up the IMX485 image sensor driver with DOL HDR support. The sensor bayer pattern is RGGB, and I would like to use 12bits. But in code (sensor_common.c
file) there is no DOL RGGB 12bits supported, only DOL rggb10 available.
So, it is impossible for me to use 12bits on DOL mode? Thank you.
static int extract_pixel_format(
const char *pixel_t, u32 *format)
size_t size = strnlen(pixel_t, OF_MAX_STR_LEN);
if (strncmp(pixel_t, "bayer_bggr10", size) == 0)
*format = V4L2_PIX_FMT_SBGGR10;
else if (strncmp(pixel_t, "bayer_rggb10", size) == 0)
*format = V4L2_PIX_FMT_SRGGB10;
else if (strncmp(pixel_t, "bayer_grbg10", size) == 0)
*format = V4L2_PIX_FMT_SGRBG10;
else if (strncmp(pixel_t, "bayer_gbrg10", size) == 0)
*format = V4L2_PIX_FMT_SGBRG10;
else if (strncmp(pixel_t, "bayer_bggr12", size) == 0)
*format = V4L2_PIX_FMT_SBGGR12;
else if (strncmp(pixel_t, "bayer_rggb12", size) == 0)
*format = V4L2_PIX_FMT_SRGGB12;
else if (strncmp(pixel_t, "rgb_rgb88824", size) == 0)
*format = V4L2_PIX_FMT_RGB24;
else if (strncmp(pixel_t, "bayer_grbg12", size) == 0)
*format = V4L2_PIX_FMT_SGRBG12;
else if (strncmp(pixel_t, "bayer_gbrg12", size) == 0)
*format = V4L2_PIX_FMT_SGBRG12;
else if (strncmp(pixel_t, "bayer_gbrg8", size) == 0)
*format = V4L2_PIX_FMT_SGBRG8;
else if (strncmp(pixel_t, "bayer_rggb8", size) == 0)
*format = V4L2_PIX_FMT_SRGGB8;
else if (strncmp(pixel_t, "bayer_grbg8", size) == 0)
*format = V4L2_PIX_FMT_SGRBG8;
else if (strncmp(pixel_t, "bayer_wdr_pwl_rggb12", size) == 0)
else if (strncmp(pixel_t, "bayer_wdr_dol_rggb10", size) == 0)
else if (strncmp(pixel_t, "bayer_xbggr10p", size) == 0)
*format = V4L2_PIX_FMT_XBGGR10P;
else if (strncmp(pixel_t, "bayer_xrggb10p", size) == 0)
*format = V4L2_PIX_FMT_XRGGB10P;
else if (strncmp(pixel_t, "yuv_yuyv16", size) == 0)
*format = V4L2_PIX_FMT_YUYV;
else if (strncmp(pixel_t, "yuv_yvyu16", size) == 0)
*format = V4L2_PIX_FMT_YVYU;
else if (strncmp(pixel_t, "yuv_uyvy16", size) == 0)
*format = V4L2_PIX_FMT_UYVY;
else if (strncmp(pixel_t, "yuv_vyuy16", size) == 0)
*format = V4L2_PIX_FMT_VYUY;
else {
pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
return -EINVAL;
return 0;
