Camera error on Gstreamer python bind
Hello, I’m trying to run a simple python script with a gstreamer query on it.
#!/usr/bin/env python3
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
from gi.repository import GLib
GObject.threads_init()
Gst.init(None)
class Sender:
    def __init__(self):
        # Create GStreamer pipeline
        self.pipeline = Gst.Pipeline()
        # Create bus to get events from GStreamer pipeline
        self.bus = self.pipeline.get_bus()
        self.bus.add_signal_watch()
        self.bus.connect('message::error', self.on_error)
# Create GStreamer elements
        # Video source device
        self.src = Gst.ElementFactory.make('nvcamerasrc', None)
        # conversion pipeline
        self.srccaps = Gst.Caps.from_string("video/x-raw, format=(string)I420")
        self.nvoverlaysink = Gst.ElementFactory.make('nvoverlaysink', None)
        # Add elements to the pipeline
        self.pipeline.add(self.src)
        self.pipeline.add(self.nvoverlaysink)
self.src.link_filtered(self.nvoverlaysink, self.srccaps)
# run the program
    def run(self):
        self.pipeline.set_state(Gst.State.PLAYING)
        GLib.MainLoop().run()
    def on_error(self, bus, msg):
        print('on_error():', msg.parse_error())
## START EVERYTHING
if __name__ == '__main__':
    sender = Sender()
    sender.run()
which is equivalent to :
gst-launch-1.0  nvcamerasrc ! 'video/x-raw(memory:NVMM), format=(string)I420'  !  nvoverlaysink
When I try to run the command in terminal it works without problems.
But when i try to run it through the python script it gives this error:
on_error(): (gerror=GLib.Error('Internal data flow error.', 'gst-stream-error-quark', 1), debug='gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvCameraSrc:nvcamerasrc0:\nstreaming task paused, reason not-linked (-1)')
And cannot understand why.
Can someone help me on this topic?
I also must add that when I change the
nvcamerasrc
to
videotestsrc
it works without problem.
Thank you in advance for your help!
You could try changing:
to
self.srccaps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=(string)I420")
Hey bud, I changed the code to as proposed above by Honey, and it works.
import gi
from gi.repository import GObject, Gst, GLib
Gst.init(None)
class Sender:
	def __init__(self):
	# run the program
	def run(self):
## START EVERYTHING
	sender = Sender()
	sender.run()
To be honest, Its actually quiet annoying with those () in the stream parameters with python, as you need to add ‘’ when launching the same command in gst-launcher.
What Im most annoyed is that the nvcamera-daemon dont stop when the gst-launcher process stops. I have to kill the process all the time.
also when my python script crashes, the nvcamera-daemon still runs, and has to be killed like this;
sudo killall nvcamera-daemon
sudo service nvcamera-daemon stop
sudo /usr/sbin/nvcamera-daemon &
I made a bash script and can call it from my udp control application to restart the camera daemon.
But it should be completely unnecessary.
NVIDIA… please read this
Thank you! That actually solved it :)
