I try to run Nano Production Module with custom carrier board with IMX477 camera.
Camera and the same driver works find on dev kit (4GB and 2GB).
On production module I got error:
[ 5809.155898] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 650
[ 5809.189275] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 651
[ 5809.222613] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 652
[ 5809.255870] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 653
[ 5809.289248] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 654
[ 5809.322257] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 655
I2C works fine, because:
[ 6.101700] vi 54080000.vi: vi_probe: ++
[ 6.108259] vi 54080000.vi: initialized
[ 6.114083] vi 54080000.vi: subdev nvcsi--1 bound
[ 6.118812] vi 54080000.vi: subdev imx477 6-001a bound
debug shows:
v4l2-ctl-17295 [003] .... 5786.595031: tegra_channel_open: vi-output, imx477 6-001a
v4l2-ctl-17295 [000] .... 5786.597989: camera_common_s_power: status : 0x1
v4l2-ctl-17295 [000] .... 5787.042148: camera_common_s_power: status : 0x0
v4l2-ctl-17295 [000] .... 5787.042272: tegra_channel_set_power: imx477 6-001a : 0x1
v4l2-ctl-17295 [000] .... 5787.042286: camera_common_s_power: status : 0x1
v4l2-ctl-17295 [000] .... 5787.342855: tegra_channel_set_power: nvcsi--1 : 0x1
v4l2-ctl-17295 [000] .... 5787.342873: csi_s_power: enable : 0x1
vi-output, imx4-17296 [002] .... 5787.392589: tegra_channel_set_stream: enable : 0x1
vi-output, imx4-17296 [002] .... 5787.392677: tegra_channel_set_stream: nvcsi--1 : 0x1
vi-output, imx4-17296 [002] .... 5787.392679: csi_s_stream: enable : 0x1
vi-output, imx4-17296 [002] .... 5787.392709: tegra_channel_set_stream: imx477 6-001a : 0x1
vi-output, imx4-17296 [000] .... 5809.330008: tegra_channel_capture_frame: sof:5809.167343617
vi-output, imx4-17296 [002] .... 5809.362554: tegra_channel_capture_frame: sof:5809.200379607
vi-output, imx4-17296 [002] .... 5809.396142: tegra_channel_capture_frame: sof:5809.233715700
vi-output, imx4-17296 [002] .... 5809.430091: tegra_channel_capture_frame: sof:5809.267659502
vi-output, imx4-17296 [002] .... 5809.463358: tegra_channel_capture_frame: sof:5809.300894919
vi-output, imx4-17296 [002] .... 5809.496777: tegra_channel_capture_frame: sof:5809.334367627
vi-output, imx4-17296 [002] .... 5809.529962: tegra_channel_capture_frame: sof:5809.367448461
vi-output, imx4-17296 [002] .... 5809.563389: tegra_channel_capture_frame: sof:5809.400883304
vi-output, imx4-17296 [002] .... 5809.596879: tegra_channel_capture_frame: sof:5809.434410127
vi-output, imx4-17296 [002] .... 5809.629957: tegra_channel_capture_frame: sof:5809.467440856
v4l2-ctl-17295 [003] .... 5809.655338: tegra_channel_close: vi-output, imx477 6-001a
vi-output, imx4-17296 [002] .... 5809.661764: tegra_channel_capture_frame: sof:5809.499800492
v4l2-ctl-17295 [001] .... 5809.661844: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-17295 [001] .... 5809.661846: tegra_channel_set_stream: imx477 6-001a : 0x0
v4l2-ctl-17295 [000] .... 5809.662125: tegra_channel_set_stream: nvcsi--1 : 0x0
v4l2-ctl-17295 [000] .... 5809.662128: csi_s_stream: enable : 0x0
v4l2-ctl-17295 [000] .... 5809.670019: tegra_channel_set_power: imx477 6-001a : 0x0
v4l2-ctl-17295 [000] .... 5809.670029: camera_common_s_power: status : 0x0
v4l2-ctl-17295 [000] .... 5809.670109: tegra_channel_set_power: nvcsi--1 : 0x0
v4l2-ctl-17295 [000] .... 5809.670111: csi_s_power: enable : 0x0
Where I have to look to?
