Camera fuse_id value does not refreshing
I am reading fuse id from the camera after in set mode function. It works fine, but when I connect different camera with different fuse id and run argus_camera app again, control is not updated of the new value. Controls value remains with the value from the first camera. After a reset of Jetson Xavier and run argus_camera app, controls value is updated and has fuse_id value from the second camera. Why?
Should I add fuse_id control in override section in camera framework to be able to update it without reseting the Xavier kit ?
BR
Marcin
Suppose don’t support hot plug.
Hi ShaneCCC,
I found the root cause of my problem. When I use register_map() for reading sensor registers, values I got the same values each time.
I have the same issue described in this topic:
