Camera Integrationn issues with Jetson AGX Xavier
I am trying to connect a camera sensor to Xavier AGX.
Single camera sensor is connected which uses 4 lanes.
I used command -
v4l2-ctl -d /dev/video2 --verbose --set-fmt-video=width=3840,height=2160,pixelformat=BA12 --set-ctrl bypass_mode=0 --stream-to=/tmp/ba12.raw --stream-count=1 --stream-poll --stream-mmapp
got the following error message -
tegra194-vi5 15c10000.vi: no reply from camera processor
tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
Probed on deserializer and observed clock at data at CSI lanes
Get the trace log to check if any clue for it.
https://elinux.org/Jetson/l4t/Camera_BringUp
