Camera IPs are Going Back and Forth
When we connect the cameras to the gig on a xavier nx computer with Linux Arm operating system, the cameras go back and forth in the pylon. They come and go as IP. I have 4 lan ports in total. The log file of the ETH1 port to which we connected the camera is attached.
boxer_eth1_log.txt (24.5 KB)
Would like to get more detail of the setup. So one PoE router is connected to ethernet port of Xavier NV developer kit, and 4 IP cameras are connected to the router. Is this correct? And please share which Jetpack release you are using. Latest versions are 4.6.4 and 5.1.3.
