After Xavier system is started, Camera is abnormal when it is opened for the first time;
but the second time turn it on, it's fine;
And then it keeps going ,keep normal 。
When the camera is first turned on, the kernel prints as follows
[ 77.762137] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 77.762306] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500
0 ms
[ 77.762495] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capturr
e channel
[ 77.764881] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capturee
channel
these failure messages shown VI engine complain about waiting timeout for the MIPI signaling.
assume your 2nd trial works due to VI driver’s error recovery mechanism.
since this failure only occurred for the 1st access,
suggest you review your sensor driver power-on/off sequence.
please also probe the MIPI signaling to check the THS settle time, you may tune cil_settletime within the range of acceptable values.
thanks
