[Camera][JP 7.2.1/R39.2.1] nvgstacpture-1.0 failed to capture image
Hi NVIDIA TEAMS:
We have customized boards based on AGX Orin,Connect max96712 through CSI0 and CSI1, and connect one max96717 camera to each of the four links of max96712.
v4l2-ctl is ok
ubuntu@tegra:~$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1536 --stream-mmap -c bypass_mode=0
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
but, nvgstacpture-1.0 is failed
bitrate = 4000000
Encoder Profile = High
Encoder control-rate = 1
libEGL warning: DRI3 error: Could not get DRI3 device
libEGL warning: Ensure your X server supports DRI3 to get accelerated rendering
Using winsys: x11
Opening in BLOCKING MODE
** Message: 01:41:10.578: main:4753 iterating capture loop …
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:945 No cameras available
NvMMLiteOpen : Block : BlockType = 4
===== NvVideo: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
I can’t login througt the monitor, so execute nvgstcapture-1.0 --sensor-id=0 through ssh login. how to fix this issue.
Below error could be incorrect context of tegra-camera-platform{}
Dump the device tree to confirm.
Need login and connect display monitor to have GPU driver launch. Otherwise reference to below to enable headless mode.
Using winsys: x11
camera.txt (56.3 KB)
the device tree config.
we used camera build-in ISP,use nvgstcapture-1.0 or Argus framework need to add isp json config?How to add relevant configurations
You may like to try streaming via standard V4L2 GStreamer elements instead of Argus:
gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw(memory:NVMM), format=YUY2, width=1920, height=1536, framerate=30/1" ! nvvidconv ! nveglglessink
v4l2src**does** support CSI/GMSL camera nodes (it is not restricted to USB cameras). That is why yourv4l2-ctltest successfully streamed 30 fps directly from/dev/video0.
The reason your test with nvarguscamerasrc failed with No cameras available is that Argus relies on the proprietary nvargus-daemon and proper camera module profile/badge registration files under /var/nvidia/nvcam/settings/. Because your custom GMSL board doesn’t have matching Argus override profiles configured yet, Argus cannot initialize the stream.
If you want to stream and display your GMSL cameras right now without setting up Argus override files, use the standard V4L2 GStreamer pipeline (allowing nvvidconv to handle the conversion from system memory to NVMM memory):
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=1920, height=1536, framerate=30/1 ! nvvidconv ! video/x-raw(memory:NVMM), format=NV12 ! nveglglessink
