Hello.
We attached ov491(isp included, and yuyv format) camera module succesfully.
We could capture using below gstreamer command
v4l2-ctl --set-fmt-video=width=1824,height=940,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100 -d /dev/video0 --stream-to=ov491.raw
But nvidia sample application was not work.
/proc/device-tree/tegra-camera-platform looks correct and I can see /proc/device-tree/i2c@3180000/ov491_a@24
below is error log when excute camera_jpeg_capture sample application
nvidia@tegra-ubuntu:~/tegra_multimedia_api/samples/09_camera_jpeg_capture$ ./camera_jpeg_capture
[INFO] (NvEglRenderer.cpp:109) Setting Screen width 640 height 480
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/e3327_front_P5V27C.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/e3327_front_P5V27C.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/e3327_front_P5V27C.isp] 8/16---- imager: No override file found. ----
NvCameraIspConfigFileLoad: Config file “isp4.cfg” Line 19: Error: Invalid isp config attribute: “opticalBlack.manualBiasR=0”
NvCameraIspConfigFileLoad: Config file “isp4.cfg” Line 20: Error: Invalid isp config attribute: “opticalBlack.manualBiasGR=0”
NvCameraIspConfigFileLoad: Config file “isp4.cfg” Line 21: Error: Invalid isp config attribute: “opticalBlack.manualBiasGB=0”
NvCameraIspConfigFileLoad: Config file “isp4.cfg” Line 22: Error: Invalid isp config attribute: “opticalBlack.manualBiasB=0”
NvCameraIspConfigFileLoad: Config file “isp4.cfg” Line 23: Error: Invalid isp config attribute: “opticalBlack.mode=0”
NvCameraIspConfigFileLoad: Config file “isp4.cfg” Line 322: Error: Invalid isp config attribute: “tnr.v1.maxRealtimePps=265420800”
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
CONSUMER: Waiting until producer is connected…
PRODUCER: Available Sensor modes :
PRODUCER: [0] W=1824 H=940
PRODUCER: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
(NvOdmDevice) Error NotInitialized: V4L2Device not powered on (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function setControlValMultiple(), line 673)
(NvOdmDevice) Error NotInitialized: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function setDeviceControls(), line 1618)
updateOutputSettings: Set Control failed. Use cached values
(NvOdmDevice) Error NotInitialized: V4L2Device not powered on (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function getControlValMultiple(), line 521)
(NvOdmDevice) Error NotInitialized: V4L2Device not powered on (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function streamControl(), line 1633)
(NvOdmDevice) Error NotInitialized: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 202)
SCF: Error MetadataFailure: AutoControl output not found (in src/services/autocontrol/NvCameraIspDriver.cpp, function extractPclSettingsFromCC(), line 816)
SCF: Error MetadataFailure: (propagating from src/services/autocontrol/NvCameraIspDriver.cpp, function generate(), line 1104)
SCF: Error MetadataFailure: (propagating from src/components/ac_stages/AcMergeStage.cpp, function doHandleRequest(), line 84)
SCF: Error MetadataFailure: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error MetadataFailure: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 992)
SCF: Error InvalidState: Session has suffered a critical failure (in src/api/Session.cpp, function capture(), line 689)
(Argus) Error InvalidState: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
