Camera not streaming but when I probed the csi_lane I was able to see MIPI signal
I used this command “gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! xvimagesink”
When I tried dmesg I got the following
[ 4943.568936] [RCE] WARNING: t194/isp5.c:901 [config_channel] "All error notifications not enabled: correctable=0x00 uncorrectable=0x00"
[ 4943.897850] imx219 9-0010: imx219_power_on: power on
[ 4943.921118] imx219 9-0010: imx219_power_off: power off
[ 4943.922277] imx219 10-0010: imx219_power_on: power on
[ 4943.945580] imx219 10-0010: imx219_power_off: power off
[ 4943.949165] imx219 9-0010: imx219_power_on: power on
[ 4943.972509] imx219 9-0010: imx219_power_off: power off
[ 4943.973936] imx219 10-0010: imx219_power_on: power on
[ 4943.997223] imx219 10-0010: imx219_power_off: power off
[ 4944.043323] imx219 10-0010: imx219_power_on: power on
[ 4944.066522] imx219 10-0010: imx219_power_off: power off
[ 4944.067612] imx219 9-0010: imx219_power_on: power on
[ 4944.090823] imx219 9-0010: imx219_power_off: power off
[ 4944.094394] imx219 9-0010: imx219_power_on: power on
[ 4944.117697] imx219 9-0010: imx219_power_off: power off
[ 4944.118786] imx219 9-0010: imx219_power_on: power on
[ 4944.142159] imx219 9-0010: imx219_power_off: power off
[ 4944.208688] imx219 10-0010: imx219_power_on: power on
[ 4944.231893] imx219 10-0010: imx219_power_off: power off
[ 4944.233247] imx219 10-0010: imx219_power_on: power on
[ 4944.256527] imx219 10-0010: imx219_power_off: power off
[ 4944.258372] imx219 10-0010: imx219_power_on: power on
[ 4944.281707] imx219 10-0010: imx219_power_off: power off
[ 4944.364917] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 4944.760170] imx219 9-0010: imx219_power_on: power on
[ 4944.783432] imx219_set_exposure
[ 4944.783504] imx219_set_group_hold
[ 4944.783515] imx219_set_frame_rate
[ 4944.783524] imx219_set_group_hold
[ 4944.787046] imx219_set_group_hold
[ 4944.787061] imx219_set_frame_rate
[ 4944.787071] imx219_set_exposure
[ 4944.787080] imx219_set_group_hold
[ 4944.789514] imx219_set_mode
[ 4944.789520] imx219_write_table
[ 4944.811007] imx219_set_gain
[ 4944.811015] imx219_set_exposure
[ 4944.811021] imx219_set_frame_rate
[ 4944.811027] imx219_start_streaming
when I tried this command “v4l2-ctl --device /dev/video0 --stream-mmap --stream-to=frame.raw --stream-count=1 --set-ctrl bypass_mode=0”
I got the below in dmesg
Is there anyway to fix it?
[ 95.663960] imx219 9-0010: imx219_power_on: power on
[ 95.706580] imx219_set_mode
[ 95.706591] imx219_write_table
[ 95.728961] imx219_start_streaming
[ 95.728967] imx219_write_table
[ 95.739732] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 95.788167] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 131072
[ 98.343807] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 98.343962] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 98.344139] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 98.347056] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 98.389531] tegra194-vi5 15c10000.vi: corr_err: discarding frame 88, flags: 0, err_data 131072
[ 100.903926] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 100.904077] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 100.904221] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 100.904401] tegra194-vi5 15c10000.vi: unexpected response from camera processor
[ 100.904530] video4linux video0: vi capture release failed
[ 100.904629] tegra194-vi5 15c10000.vi: fatal: error recovery failed
