Camera not work correctly
Jetson Linux r35.4.1
I have two I2C buses, each connected to one MAX9296A deserializer, with each deserializer supporting two cameras for a total of four cameras. I’m only connecting one camera for testing
gst-launch-1.0 v4l2src device=/dev/video0 ! xvimagesink -ev
I got
[ 3631.630044] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 3631.639194] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 3631.649721] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3631.657437] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 3631.668098] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3631.675813] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 3631.686885] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
trace log is attached, what is the problem and how can I figure out this?
trace.txt (4.2 KB)
Hi @lzyu1110,
The Null VI channel error suggests that no valid frame data is being captured. Just a few questions to better understand your issue:
  • Are you using a devkit or a custom board?
  • Are you using any custom drivers?
  • Could you share dmesg logs and device tree?
Regards,
Francis Guindon
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: http://www.ridgerun.com/
I use a custom board and a custom camera driver provided by the camera vendor.
dmesg.txt (111.2 KB)
sgx-yuv-gmsl.txt (32.3 KB)
tegra234-p3768-sg6c-orin-gmsl2-m.txt (4.0 KB)
You may need to probe the MIPI signal to confirm output data due to didn’t receive any validate data from the trace log.
When I reduced my configuration to 2 channels, both 2 cameras using cam-i2c worked well.
sgx-yuv-gmsl.dtsi.txt (17.0 KB)
tegra234-p3768-sg6c-orin-gmsl2-m.dtsi.txt (3.2 KB)
What’s do you mean 2 channels?
I have a total of 4 cameras. 2 of them are connected to the cam-i2c bus, and the other 2 to i2c7. In the tegra-capture-vi node, num-channels is set to 4. For now, I’ve temporarily disabled the devices under i2c7 and the other 2 work well. Since each camera corresponds to one channel, I modified the related channel configurations accordingly.
Now I want to rule out any driver-related issues. I’m attempting to disable the cameras connected to cam-i2c, and enable the two cameras mounted under i2c-7 instead. These two cameras are using CSI-2 and CSI-3, and I have set port-index = <2>. However, my test failed. Could there be an issue with how the device tree is configured or bound?
tegra234-p3768-sg6c-orin-gmsl2-m (2).dtsi.txt (3.2 KB)
sgx-yuv-gmsl (2).dtsi.txt (17.0 KB)
What are these 4 cameras connect to? Which one is working which one is failed?
They both connect to 9296A (actually I have two 9296A chips).
The first pair of cameras, which are connected as shown in the diagram below, use CSI-0 and CSI-1, and they are working properly.
The second pair of cameras, connected as shown in the diagram below, use CSI-2 and CSI-3, but they fail to work.
Why CKAP/CKAN connect to CSI1_CLKP/CSI1_CLKN?
So should csi2_clk be the correct clock to use in this case?
Yes, should be CSI2_clk
I wired it now and measured the CSI_CLK and CSI_DATA signals on the MAX9296 chip under i2c-7.They both appear to be fine. But there is no video output like before.
proc-device-tree.dts.txt (422.1 KB)
Get the trace log to check.
no it still works failed.
~0730
Can you refer to previous comments to get the trace log?
