I am trying to receive video through CSI and output it with gstreamer.
I tested it on Jetpack 5.0.1 and Jetpack 5.0.2 and confirmed that the video is output well at 1920x720 and 1024x1920.
However, when I receive a 1924x720 video, the output comes out strangely.
We used yuv_uyvy16 as the pixel format.
The gstreamer command we used is shown below.
gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY,width=1924,height=720" ! videoconvert ! gtksink sync=false
full output video
Original Image
Output Image
kernel log is below.
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.107613] ds90ub940n 8-002c: ds90ub940n_set_mode: mode_prop_idx=0
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.111228] ko_frmfmt = (1924,720)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.121267] ds90ub940n 8-002c: ds90ub940n_start_streaming: mode_prop_idx=0
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134350] [RCE] VM0 deactivating.VM0 activating.NVCSILP clock rate = 408000000 Hz.
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134354] [RCE] VI5: tegra_vi_channel_alloc()
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134356] [RCE] VI5: unit 0 stream ID table:
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134357] [RCE] VI5: unit 0 stream ID table from THI:
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134358] [RCE] VI5: FALCON_CSB_AFBIF_STREAMID_CTL = 0x00
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134360] [RCE] VI5: vi5_trace_enable: configuring trace buffer at iova=0x8375dda00 size=32768
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134361] [RCE] VI5: tegra_vi_channel_alloc: ch=35
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134363] [RCE] VI5: PFSD enabled for channel: NO, expected_count. 0
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134364] [RCE] VI5: channel_submit(35, bfebf000)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134366] [RCE] VI5: completion_actions[8] size = 30, next offset = 314
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134367] [RCE] VI5: completion_actions[0] size = 31, next offset = 345
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134369] [RCE] VI5: completion_actions[2] size = 14, next offset = 359
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134370] [RCE] VI5: completion_actions[1] size = 30, next offset = 389
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134372] [RCE] VI5: completion_actions[4] size = 14, next offset = 403
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134373] [RCE] VI5: completion_actions[3] size = 14, next offset = 417
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134375] [RCE] VI5: completion_actions[5] size = 2, next offset = 419
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134376] [RCE] VI5: vi5_update_streams: ch=35 stream_mask=0x01
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134377] [RCE] VI5: enabling stream 0
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134379] [RCE] VI5: PFSD enabled for channel: NO, expected_count. 0
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134380] [RCE] VI5: channel_submit(35, bfebf180)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134382] [RCE] VI5: completion_actions[8] size = 30, next offset = 314
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134383] [RCE] VI5: completion_actions[0] size = 31, next offset = 345
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134385] [RCE] VI5: completion_actions[2] size = 14, next offset = 359
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134386] [RCE] VI5: completion_actions[1] size = 30, next offset = 389
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134388] [RCE] VI5: completion_actions[4] size = 14, next offset = 403
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134390] [RCE] VI5: completion_actions[3] size = 14, next offset = 417
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134391] [RCE] VI5: completion_actions[5] size = 2, next offset = 419
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134392] [RCE] VI5: vi5_update_streams: ch=35 stream_mask=0x01
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134394] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=0, csi=0)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134395] [RCE] MIPI clock = 188540 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134397] [RCE] tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134399] [RCE] nvcsi_calc_ths_settle ths_settle 80
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134400] [RCE] nvcsi_calc_ths_settle ths_settle 80
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134402] [RCE] nvcsi_calc_ths_settle ths_settle 80
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134403] [RCE] nvcsi_calc_tclk_settle tclk_settle 75
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134407] [RCE] VI5: vi5_process_error_fifo: tag=0x03 ch=0 frame=0 ts=1740177401792 data=0x00000001 ext_data=0x00000000
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134408] [RCE] VI5: error_to_notify_bits CSIMUX_STREAM error detected
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134410] [RCE] VI5: vi5_notify_error(35) status 0x3 tag 0x3, data 0x1
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134411] [RCE] VI5: vi5_irq_process_channel_event invoked: CH35_INT_STATUS = 0x1
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134412] [RCE] VI5: vi5_handle_sof(35)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134417] [RCE] VI5: vi5_irq_process_channel_event invoked: CH35_INT_STATUS = 0x2
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134418] [RCE] VI5: vi5_handle_eof(35)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134420] [RCE] VI5: vi5_irq_process_channel_event invoked: CH35_INT_STATUS = 0x1
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.134421] [RCE] VI5: vi5_handle_sof(35)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194342] [RCE] VI5: vi5_irq_process_channel_event invoked: CH35_INT_STATUS = 0x2
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194345] [RCE] VI5: vi5_handle_eof(35)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194347] [RCE] VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame=0 ts=1740218579040 data=0x000003c9 ext_data=0x00000000
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194349] [RCE] VI5: error_to_notify_bits CHANSEL_NOMATCH identified
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194350] [RCE] VI5: vi5_notify_error(35) status 0xf tag 0xb, data 0x3c9
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194353] [RCE] VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame=0 ts=1740235288576 data=0x000003c9 ext_data=0x00000000
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194356] [RCE] VI5: error_to_notify_bits CHANSEL_NOMATCH identified
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194358] [RCE] VI5: vi5_notify_error(35) status 0xf tag 0xb, data 0x3c9
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194360] [RCE] VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame=0 ts=1740251998176 data=0x000003c9 ext_data=0x00000000
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194362] [RCE] VI5: error_to_notify_bits CHANSEL_NOMATCH identified
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194364] [RCE] VI5: vi5_notify_error(35) status 0xf tag 0xb, data 0x3c9
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194365] [RCE] VI5: PFSD enabled for channel: NO, expected_count. 0
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194366] [RCE] VI5: channel_submit(35, bfebf000)
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194367] [RCE] VI5: completion_actions[8] size = 30, next offset = 314
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194369] [RCE] VI5: completion_actions[0] size = 31, next offset = 345
Jan 3 15:40:26 nvidia-desktop kernel: [ 1717.194370] [RCE] VI5: completion_actions[2] size = 14, next offset = 359
trace log is below.
# tracer: nop
# entries-in-buffer/entries-written: 43009/43009 #P:12
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/5:1-2349 [005] .... 1031.293544: rtcpu_string: tstamp:32947568462 id:0x04010000 str:"NVCSILP clock rate = 408000000 Hz.
kworker/5:1-2349 [005] .... 1031.293574: rtcpu_dbg_set_loglevel: tstamp:32947714157 old:0 new:2
kworker/5:1-2349 [005] .... 1037.241146: rtcpu_string: tstamp:33134217417 id:0x04010000 str:"VM0 deactivating."
kworker/5:1-2349 [005] .... 1717.134344: rtcpu_string: tstamp:54380351320 id:0x04010000 str:"VM0 activating."
kworker/5:1-2349 [005] .... 1717.134346: rtcpu_string: tstamp:54380423865 id:0x04010000 str:"NVCSILP clock rate = 408000000 Hz.
kworker/5:1-2349 [005] .... 1717.134354: rtcpu_string: tstamp:54380462386 id:0x04010000 str:"VI5: tegra_vi_channel_alloc()
kworker/5:1-2349 [005] .... 1717.134355: rtcpu_string: tstamp:54380467772 id:0x04010000 str:"VI5: unit 0 stream ID table:
kworker/5:1-2349 [005] .... 1717.134357: rtcpu_string: tstamp:54380468015 id:0x04010000 str:"VI5: unit 0 stream ID table from THI:
kworker/5:1-2349 [005] .... 1717.134358: rtcpu_string: tstamp:54380468296 id:0x04010000 str:"VI5: FALCON_CSB_AFBIF_STREAMID_CTL = 0x00
kworker/5:1-2349 [005] .... 1717.134359: rtcpu_string: tstamp:54380473746 id:0x04010000 str:"VI5: vi5_trace_enable: configuring trace buffer "
kworker/5:1-2349 [005] .... 1717.134360: rtcpu_string: tstamp:54380473849 id:0x04010000 str:"at iova=0x8375dda00 size=32768
kworker/5:1-2349 [005] .... 1717.134361: rtcpu_string: tstamp:54380475048 id:0x04010000 str:"VI5: tegra_vi_channel_alloc: ch=35
kworker/5:1-2349 [005] .... 1717.134362: rtcpu_string: tstamp:54380479239 id:0x04010000 str:"VI5: PFSD enabled for channel: NO, expected_coun"
kworker/5:1-2349 [005] .... 1717.134363: rtcpu_string: tstamp:54380479341 id:0x04010000 str:"t. 0
kworker/5:1-2349 [005] .... 1717.134364: rtcpu_string: tstamp:54380479577 id:0x04010000 str:"VI5: channel_submit(35, bfebf000)
kworker/5:1-2349 [005] .... 1717.134365: rtcpu_string: tstamp:54380480070 id:0x04010000 str:"VI5: completion_actions[8] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.134366: rtcpu_string: tstamp:54380480171 id:0x04010000 str:"t = 314
kworker/5:1-2349 [005] .... 1717.134367: rtcpu_string: tstamp:54380480476 id:0x04010000 str:"VI5: completion_actions[0] size = 31, next offse"
kworker/5:1-2349 [005] .... 1717.134367: rtcpu_string: tstamp:54380480577 id:0x04010000 str:"t = 345
kworker/5:1-2349 [005] .... 1717.134368: rtcpu_string: tstamp:54380480874 id:0x04010000 str:"VI5: completion_actions[2] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.134369: rtcpu_string: tstamp:54380480974 id:0x04010000 str:"t = 359
kworker/5:1-2349 [005] .... 1717.134370: rtcpu_string: tstamp:54380481272 id:0x04010000 str:"VI5: completion_actions[1] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.134370: rtcpu_string: tstamp:54380481373 id:0x04010000 str:"t = 389
kworker/5:1-2349 [005] .... 1717.134371: rtcpu_string: tstamp:54380481670 id:0x04010000 str:"VI5: completion_actions[4] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.134371: rtcpu_string: tstamp:54380481771 id:0x04010000 str:"t = 403
kworker/5:1-2349 [005] .... 1717.134373: rtcpu_string: tstamp:54380482068 id:0x04010000 str:"VI5: completion_actions[3] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.134373: rtcpu_string: tstamp:54380482168 id:0x04010000 str:"t = 417
kworker/5:1-2349 [005] .... 1717.134374: rtcpu_string: tstamp:54380482460 id:0x04010000 str:"VI5: completion_actions[5] size = 2, next offset"
kworker/5:1-2349 [005] .... 1717.134375: rtcpu_string: tstamp:54380482558 id:0x04010000 str:" = 419
kworker/5:1-2349 [005] .... 1717.134376: rtcpu_string: tstamp:54380482929 id:0x04010000 str:"VI5: vi5_update_streams: ch=35 stream_mask=0x01
kworker/5:1-2349 [005] .... 1717.134377: rtcpu_string: tstamp:54380483124 id:0x04010000 str:"VI5: enabling stream 0
kworker/5:1-2349 [005] .... 1717.134378: rtcpu_string: tstamp:54380484793 id:0x04010000 str:"VI5: PFSD enabled for channel: NO, expected_coun"
kworker/5:1-2349 [005] .... 1717.134379: rtcpu_string: tstamp:54380484895 id:0x04010000 str:"t. 0
kworker/5:1-2349 [005] .... 1717.134380: rtcpu_string: tstamp:54380485130 id:0x04010000 str:"VI5: channel_submit(35, bfebf180)
kworker/5:1-2349 [005] .... 1717.134381: rtcpu_string: tstamp:54380485525 id:0x04010000 str:"VI5: completion_actions[8] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.134381: rtcpu_string: tstamp:54380485626 id:0x04010000 str:"t = 314
kworker/5:1-2349 [005] .... 1717.134383: rtcpu_string: tstamp:54380485932 id:0x04010000 str:"VI5: completion_actions[0] size = 31, next offse"
kworker/5:1-2349 [005] .... 1717.134383: rtcpu_string: tstamp:54380486033 id:0x04010000 str:"t = 345
kworker/5:1-2349 [005] .... 1717.134385: rtcpu_string: tstamp:54380486333 id:0x04010000 str:"VI5: completion_actions[2] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.134385: rtcpu_string: tstamp:54380486434 id:0x04010000 str:"t = 359
kworker/5:1-2349 [005] .... 1717.134386: rtcpu_string: tstamp:54380486731 id:0x04010000 str:"VI5: completion_actions[1] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.134386: rtcpu_string: tstamp:54380486832 id:0x04010000 str:"t = 389
kworker/5:1-2349 [005] .... 1717.134387: rtcpu_string: tstamp:54380487129 id:0x04010000 str:"VI5: completion_actions[4] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.134388: rtcpu_string: tstamp:54380487230 id:0x04010000 str:"t = 403
kworker/5:1-2349 [005] .... 1717.134389: rtcpu_string: tstamp:54380487526 id:0x04010000 str:"VI5: completion_actions[3] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.134389: rtcpu_string: tstamp:54380487627 id:0x04010000 str:"t = 417
kworker/5:1-2349 [005] .... 1717.134391: rtcpu_string: tstamp:54380487921 id:0x04010000 str:"VI5: completion_actions[5] size = 2, next offset"
kworker/5:1-2349 [005] .... 1717.134391: rtcpu_string: tstamp:54380488021 id:0x04010000 str:" = 419
kworker/5:1-2349 [005] .... 1717.134392: rtcpu_string: tstamp:54380488390 id:0x04010000 str:"VI5: vi5_update_streams: ch=35 stream_mask=0x01
kworker/5:1-2349 [005] .... 1717.134393: rtcpu_string: tstamp:54380533107 id:0x04010000 str:"tegra_nvcsi_stream_set_config(vm0, stream=0, csi"
kworker/5:1-2349 [005] .... 1717.134394: rtcpu_string: tstamp:54380533208 id:0x04010000 str:"=0)
kworker/5:1-2349 [005] .... 1717.134395: rtcpu_string: tstamp:54380533576 id:0x04010000 str:"MIPI clock = 188540 kHz, tHS-SETTLE = 0, tCLK-SE"
kworker/5:1-2349 [005] .... 1717.134395: rtcpu_string: tstamp:54380533677 id:0x04010000 str:"TTLE = 0
kworker/5:1-2349 [005] .... 1717.134397: rtcpu_string: tstamp:54380535318 id:0x04010000 str:"tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
kworker/5:1-2349 [005] .... 1717.134399: rtcpu_string: tstamp:54380542175 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 80
kworker/5:1-2349 [005] .... 1717.134400: rtcpu_string: tstamp:54380542439 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 80
kworker/5:1-2349 [005] .... 1717.134402: rtcpu_string: tstamp:54380542697 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 80
kworker/5:1-2349 [005] .... 1717.134403: rtcpu_string: tstamp:54380542950 id:0x04010000 str:"nvcsi_calc_tclk_settle tclk_settle 75
kworker/5:1-2349 [005] .... 1717.134405: rtcpu_vinotify_error: tstamp:54380544458 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1740177401792 data:0x0000000000000001
kworker/5:1-2349 [005] .... 1717.134406: rtcpu_string: tstamp:54380544973 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x03 ch=0 frame"
kworker/5:1-2349 [005] .... 1717.134406: rtcpu_string: tstamp:54380545074 id:0x04010000 str:"=0 ts=1740177401792 data=0x00000001 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.134406: rtcpu_string: tstamp:54380545175 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.134408: rtcpu_string: tstamp:54380545525 id:0x04010000 str:"VI5: error_to_notify_bits CSIMUX_STREAM error de"
kworker/5:1-2349 [005] .... 1717.134408: rtcpu_string: tstamp:54380545626 id:0x04010000 str:"tected
kworker/5:1-2349 [005] .... 1717.134409: rtcpu_string: tstamp:54380545953 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0x3 tag 0x3, da"
kworker/5:1-2349 [005] .... 1717.134409: rtcpu_string: tstamp:54380546054 id:0x04010000 str:"ta 0x1
kworker/5:1-2349 [005] .... 1717.134411: rtcpu_string: tstamp:54380787182 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.134411: rtcpu_string: tstamp:54380787286 id:0x04010000 str:"_INT_STATUS = 0x1
kworker/5:1-2349 [005] .... 1717.134412: rtcpu_string: tstamp:54380787540 id:0x04010000 str:"VI5: vi5_handle_sof(35)
kworker/5:1-2349 [005] .... 1717.134414: rtcpu_vinotify_event: tstamp:54380806301 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740175482464 data:0x375cff0010000000
kworker/5:1-2349 [005] .... 1717.134415: rtcpu_vinotify_event: tstamp:54380806438 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740175489056 data:0x0000000031000001
kworker/5:1-2349 [005] .... 1717.134415: rtcpu_vinotify_event: tstamp:54380806591 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740175647872 data:0x375cfc0010000000
kworker/5:1-2349 [005] .... 1717.134415: rtcpu_vinotify_event: tstamp:54380806723 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740175654528 data:0x0000000031000002
kworker/5:1-2349 [005] .... 1717.134415: rtcpu_vinotify_event: tstamp:54380806879 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1740177401792 data:0x0000000000000001
kworker/5:1-2349 [005] .... 1717.134415: rtcpu_vinotify_event: tstamp:54380807011 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740185035296 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.134415: rtcpu_vinotify_event: tstamp:54380807164 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1740185035328 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.134416: rtcpu_vinotify_event: tstamp:54380807296 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1740185159808 data:0x0000000000000001
kworker/5:1-2349 [005] .... 1717.134416: rtcpu_vinotify_event: tstamp:54380807452 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740185161056 data:0x0000000008020001
kworker/5:1-2349 [005] .... 1717.134416: rtcpu_string: tstamp:54381305808 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.134416: rtcpu_string: tstamp:54381305910 id:0x04010000 str:"_INT_STATUS = 0x2
kworker/5:1-2349 [005] .... 1717.134418: rtcpu_string: tstamp:54381306180 id:0x04010000 str:"VI5: vi5_handle_eof(35)
kworker/5:1-2349 [005] .... 1717.134419: rtcpu_vinotify_event: tstamp:54381307103 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:1740201675104 data:0x0000000002cf0002
kworker/5:1-2349 [005] .... 1717.134419: rtcpu_vinotify_event: tstamp:54381307256 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1740201675680 data:0x0000000000000000
kworker/5:1-2349 [005] .... 1717.134419: rtcpu_vinotify_event: tstamp:54381307388 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740201677504 data:0x0000000002020001
kworker/5:1-2349 [005] .... 1717.134419: rtcpu_vinotify_event: tstamp:54381307540 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740201744064 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.134420: rtcpu_vinotify_event: tstamp:54381307679 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1740201744064 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.134420: rtcpu_vinotify_event: tstamp:54381307828 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740201748544 data:0x0000000000020001
kworker/5:1-2349 [005] .... 1717.134420: rtcpu_vinotify_event: tstamp:54381307959 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740201744896 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.134420: rtcpu_string: tstamp:54381309354 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.134420: rtcpu_string: tstamp:54381309457 id:0x04010000 str:"_INT_STATUS = 0x1
kworker/5:1-2349 [005] .... 1717.134421: rtcpu_string: tstamp:54381309721 id:0x04010000 str:"VI5: vi5_handle_sof(35)
kworker/5:1-2349 [005] .... 1717.194337: rtcpu_vinotify_event: tstamp:54381617626 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1740201744928 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.194339: rtcpu_vinotify_event: tstamp:54381617763 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1740201869376 data:0x0000000000000001
kworker/5:1-2349 [005] .... 1717.194339: rtcpu_vinotify_event: tstamp:54381617915 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740201870656 data:0x0000000008020002
kworker/5:1-2349 [005] .... 1717.194340: rtcpu_string: tstamp:54381827732 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.194340: rtcpu_string: tstamp:54381827835 id:0x04010000 str:"_INT_STATUS = 0x2
kworker/5:1-2349 [005] .... 1717.194345: rtcpu_string: tstamp:54381828108 id:0x04010000 str:"VI5: vi5_handle_eof(35)
kworker/5:1-2349 [005] .... 1717.194346: rtcpu_vinotify_error: tstamp:54381831316 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740218579040 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.194346: rtcpu_string: tstamp:54381831831 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.194347: rtcpu_string: tstamp:54381831935 id:0x04010000 str:"=0 ts=1740218579040 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.194347: rtcpu_string: tstamp:54381832040 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.194348: rtcpu_string: tstamp:54381832378 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.194349: rtcpu_string: tstamp:54381832479 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.194350: rtcpu_string: tstamp:54381832811 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.194350: rtcpu_string: tstamp:54381832914 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.194352: rtcpu_vinotify_event: tstamp:54381955705 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:1740218384704 data:0x0000000002cf0002
kworker/5:1-2349 [005] .... 1717.194352: rtcpu_vinotify_event: tstamp:54381955865 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1740218385280 data:0x0000000000000000
kworker/5:1-2349 [005] .... 1717.194352: rtcpu_vinotify_event: tstamp:54381955997 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740218387072 data:0x0000000002020002
kworker/5:1-2349 [005] .... 1717.194352: rtcpu_vinotify_event: tstamp:54381956146 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740218453696 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.194352: rtcpu_vinotify_event: tstamp:54381956280 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1740218453728 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.194352: rtcpu_vinotify_event: tstamp:54381956433 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740218458176 data:0x0000000000020002
kworker/5:1-2349 [005] .... 1717.194352: rtcpu_vinotify_event: tstamp:54381956565 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740218454560 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.194352: rtcpu_vinotify_event: tstamp:54381956713 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740218579040 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.194353: rtcpu_vinotify_error: tstamp:54382353489 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740235288576 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.194353: rtcpu_string: tstamp:54382354000 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.194353: rtcpu_string: tstamp:54382354103 id:0x04010000 str:"=0 ts=1740235288576 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.194353: rtcpu_string: tstamp:54382354206 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.194356: rtcpu_string: tstamp:54382354542 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.194356: rtcpu_string: tstamp:54382354642 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.194357: rtcpu_string: tstamp:54382354974 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.194358: rtcpu_string: tstamp:54382355074 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.194359: rtcpu_vinotify_event: tstamp:54382631818 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740235163264 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.194359: rtcpu_vinotify_event: tstamp:54382631970 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740235164096 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.194359: rtcpu_vinotify_event: tstamp:54382632101 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740235288576 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.194359: rtcpu_vinotify_event: tstamp:54382871596 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740251872864 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.194359: rtcpu_vinotify_event: tstamp:54382871727 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740251873696 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.194360: rtcpu_vinotify_error: tstamp:54382875661 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740251998176 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.194360: rtcpu_string: tstamp:54382876173 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.194360: rtcpu_string: tstamp:54382876277 id:0x04010000 str:"=0 ts=1740251998176 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.194360: rtcpu_string: tstamp:54382876381 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.194362: rtcpu_string: tstamp:54382876715 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.194362: rtcpu_string: tstamp:54382876815 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.194363: rtcpu_string: tstamp:54382877149 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.194363: rtcpu_string: tstamp:54382877251 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.194364: rtcpu_string: tstamp:54383102278 id:0x04010000 str:"VI5: PFSD enabled for channel: NO, expected_coun"
kworker/5:1-2349 [005] .... 1717.194365: rtcpu_string: tstamp:54383102381 id:0x04010000 str:"t. 0
kworker/5:1-2349 [005] .... 1717.194366: rtcpu_string: tstamp:54383102618 id:0x04010000 str:"VI5: channel_submit(35, bfebf000)
kworker/5:1-2349 [005] .... 1717.194367: rtcpu_string: tstamp:54383103015 id:0x04010000 str:"VI5: completion_actions[8] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.194367: rtcpu_string: tstamp:54383103120 id:0x04010000 str:"t = 314
kworker/5:1-2349 [005] .... 1717.194368: rtcpu_string: tstamp:54383103427 id:0x04010000 str:"VI5: completion_actions[0] size = 31, next offse"
kworker/5:1-2349 [005] .... 1717.194369: rtcpu_string: tstamp:54383103530 id:0x04010000 str:"t = 345
kworker/5:1-2349 [005] .... 1717.194370: rtcpu_string: tstamp:54383103830 id:0x04010000 str:"VI5: completion_actions[2] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.194370: rtcpu_string: tstamp:54383103939 id:0x04010000 str:"t = 359
kworker/5:1-2349 [005] .... 1717.194371: rtcpu_string: tstamp:54383104243 id:0x04010000 str:"VI5: completion_actions[1] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.194371: rtcpu_string: tstamp:54383104346 id:0x04010000 str:"t = 389
kworker/5:1-2349 [005] .... 1717.194372: rtcpu_string: tstamp:54383104646 id:0x04010000 str:"VI5: completion_actions[4] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.194373: rtcpu_string: tstamp:54383104747 id:0x04010000 str:"t = 403
kworker/5:1-2349 [005] .... 1717.194374: rtcpu_string: tstamp:54383105045 id:0x04010000 str:"VI5: completion_actions[3] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.194374: rtcpu_string: tstamp:54383105148 id:0x04010000 str:"t = 417
kworker/5:1-2349 [005] .... 1717.194375: rtcpu_string: tstamp:54383105443 id:0x04010000 str:"VI5: completion_actions[5] size = 2, next offset"
kworker/5:1-2349 [005] .... 1717.194375: rtcpu_string: tstamp:54383105547 id:0x04010000 str:" = 419
kworker/5:1-2349 [005] .... 1717.194376: rtcpu_string: tstamp:54383105918 id:0x04010000 str:"VI5: vi5_update_streams: ch=35 stream_mask=0x01
kworker/5:1-2349 [005] .... 1717.194377: rtcpu_vinotify_event: tstamp:54383206499 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740251998176 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.194378: rtcpu_vinotify_event: tstamp:54383206636 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740259409280 data:0x375cff0010000000
kworker/5:1-2349 [005] .... 1717.194378: rtcpu_vinotify_event: tstamp:54383206793 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740259415904 data:0x0000000031000003
kworker/5:1-2349 [005] .... 1717.254334: rtcpu_string: tstamp:54383398054 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.254335: rtcpu_string: tstamp:54383398157 id:0x04010000 str:"_INT_STATUS = 0x1
kworker/5:1-2349 [005] .... 1717.254339: rtcpu_string: tstamp:54383398410 id:0x04010000 str:"VI5: vi5_handle_sof(35)
kworker/5:1-2349 [005] .... 1717.254341: rtcpu_vinotify_event: tstamp:54383544497 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740268582432 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.254341: rtcpu_vinotify_event: tstamp:54383544647 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740268583264 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.254341: rtcpu_vinotify_event: tstamp:54383544782 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1740268583264 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.254342: rtcpu_vinotify_event: tstamp:54383544935 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1740268707744 data:0x0000000000000001
kworker/5:1-2349 [005] .... 1717.254342: rtcpu_vinotify_event: tstamp:54383545069 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740268708992 data:0x0000000008020003
kworker/5:1-2349 [005] .... 1717.254342: rtcpu_string: tstamp:54383916422 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.254342: rtcpu_string: tstamp:54383916526 id:0x04010000 str:"_INT_STATUS = 0x2
kworker/5:1-2349 [005] .... 1717.254343: rtcpu_string: tstamp:54383916801 id:0x04010000 str:"VI5: vi5_handle_eof(35)
kworker/5:1-2349 [005] .... 1717.254345: rtcpu_vinotify_error: tstamp:54383920005 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740285417344 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.254345: rtcpu_string: tstamp:54383920517 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.254345: rtcpu_string: tstamp:54383920625 id:0x04010000 str:"=0 ts=1740285417344 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.254345: rtcpu_string: tstamp:54383920731 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.254347: rtcpu_string: tstamp:54383921070 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.254347: rtcpu_string: tstamp:54383921172 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.254348: rtcpu_string: tstamp:54383921507 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.254349: rtcpu_string: tstamp:54383921609 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.254350: rtcpu_vinotify_event: tstamp:54383921959 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:1740285223072 data:0x0000000002cf0002
kworker/5:1-2349 [005] .... 1717.254350: rtcpu_vinotify_event: tstamp:54383922095 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1740285223616 data:0x0000000000000000
kworker/5:1-2349 [005] .... 1717.254351: rtcpu_vinotify_event: tstamp:54383922252 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740285225440 data:0x0000000002020003
kworker/5:1-2349 [005] .... 1717.254351: rtcpu_vinotify_event: tstamp:54383922383 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740285292000 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.254351: rtcpu_vinotify_event: tstamp:54383922539 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1740285292032 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.254351: rtcpu_vinotify_event: tstamp:54383922671 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740285296480 data:0x0000000000020003
kworker/5:1-2349 [005] .... 1717.254351: rtcpu_vinotify_event: tstamp:54383922823 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740285292832 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.254352: rtcpu_vinotify_event: tstamp:54383922955 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740285417344 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.254352: rtcpu_vinotify_error: tstamp:54384442189 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740302126976 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.254352: rtcpu_string: tstamp:54384442704 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.254352: rtcpu_string: tstamp:54384442818 id:0x04010000 str:"=0 ts=1740302126976 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.254353: rtcpu_string: tstamp:54384442920 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.254354: rtcpu_string: tstamp:54384443253 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.254354: rtcpu_string: tstamp:54384443353 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.254355: rtcpu_string: tstamp:54384443685 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.254356: rtcpu_string: tstamp:54384443785 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.254357: rtcpu_vinotify_event: tstamp:54384457226 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740302001632 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.254357: rtcpu_vinotify_event: tstamp:54384457361 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740302002496 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.254357: rtcpu_vinotify_event: tstamp:54384457509 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740302126976 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.254357: rtcpu_string: tstamp:54384864707 id:0x04010000 str:"VI5: PFSD enabled for channel: NO, expected_coun"
kworker/5:1-2349 [005] .... 1717.254358: rtcpu_string: tstamp:54384864813 id:0x04010000 str:"t. 0
kworker/5:1-2349 [005] .... 1717.254359: rtcpu_string: tstamp:54384865053 id:0x04010000 str:"VI5: channel_submit(35, bfebf180)
kworker/5:1-2349 [005] .... 1717.254360: rtcpu_string: tstamp:54384865450 id:0x04010000 str:"VI5: completion_actions[8] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.254360: rtcpu_string: tstamp:54384865551 id:0x04010000 str:"t = 314
kworker/5:1-2349 [005] .... 1717.254362: rtcpu_string: tstamp:54384865860 id:0x04010000 str:"VI5: completion_actions[0] size = 31, next offse"
kworker/5:1-2349 [005] .... 1717.254362: rtcpu_string: tstamp:54384865984 id:0x04010000 str:"t = 345
kworker/5:1-2349 [005] .... 1717.254363: rtcpu_string: tstamp:54384866285 id:0x04010000 str:"VI5: completion_actions[2] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.254364: rtcpu_string: tstamp:54384866385 id:0x04010000 str:"t = 359
kworker/5:1-2349 [005] .... 1717.254365: rtcpu_string: tstamp:54384866683 id:0x04010000 str:"VI5: completion_actions[1] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.254365: rtcpu_string: tstamp:54384866783 id:0x04010000 str:"t = 389
kworker/5:1-2349 [005] .... 1717.254366: rtcpu_string: tstamp:54384867079 id:0x04010000 str:"VI5: completion_actions[4] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.254366: rtcpu_string: tstamp:54384867180 id:0x04010000 str:"t = 403
kworker/5:1-2349 [005] .... 1717.254367: rtcpu_string: tstamp:54384867481 id:0x04010000 str:"VI5: completion_actions[3] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.254368: rtcpu_string: tstamp:54384867584 id:0x04010000 str:"t = 417
kworker/5:1-2349 [005] .... 1717.254369: rtcpu_string: tstamp:54384867882 id:0x04010000 str:"VI5: completion_actions[5] size = 2, next offset"
kworker/5:1-2349 [005] .... 1717.254369: rtcpu_string: tstamp:54384867985 id:0x04010000 str:" = 419
kworker/5:1-2349 [005] .... 1717.254370: rtcpu_string: tstamp:54384868362 id:0x04010000 str:"VI5: vi5_update_streams: ch=35 stream_mask=0x01
kworker/5:1-2349 [005] .... 1717.254371: rtcpu_string: tstamp:54384964582 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.254372: rtcpu_string: tstamp:54384964686 id:0x04010000 str:"_INT_STATUS = 0x1
kworker/5:1-2349 [005] .... 1717.254373: rtcpu_string: tstamp:54384964940 id:0x04010000 str:"VI5: vi5_handle_sof(35)
kworker/5:1-2349 [005] .... 1717.314329: rtcpu_vinotify_event: tstamp:54385133309 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740315809280 data:0x375cfc0010000000
kworker/5:1-2349 [005] .... 1717.314330: rtcpu_vinotify_event: tstamp:54385133467 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740315815872 data:0x0000000031000004
kworker/5:1-2349 [005] .... 1717.314330: rtcpu_vinotify_event: tstamp:54385133600 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740318711200 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.314330: rtcpu_vinotify_event: tstamp:54385133749 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740318712064 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.314330: rtcpu_vinotify_event: tstamp:54385133884 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1740318712064 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.314331: rtcpu_vinotify_event: tstamp:54385134035 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1740318836544 data:0x0000000000000001
kworker/5:1-2349 [005] .... 1717.314331: rtcpu_vinotify_event: tstamp:54385134166 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740318837824 data:0x0000000008020004
kworker/5:1-2349 [005] .... 1717.314331: rtcpu_string: tstamp:54385483135 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.314331: rtcpu_string: tstamp:54385483243 id:0x04010000 str:"_INT_STATUS = 0x2
kworker/5:1-2349 [005] .... 1717.314334: rtcpu_string: tstamp:54385483523 id:0x04010000 str:"VI5: vi5_handle_eof(35)
kworker/5:1-2349 [005] .... 1717.314336: rtcpu_vinotify_event: tstamp:54385484476 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:1740335351808 data:0x0000000002cf0002
kworker/5:1-2349 [005] .... 1717.314336: rtcpu_vinotify_event: tstamp:54385484612 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1740335352384 data:0x0000000000000000
kworker/5:1-2349 [005] .... 1717.314336: rtcpu_vinotify_event: tstamp:54385484765 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740335354176 data:0x0000000002020004
kworker/5:1-2349 [005] .... 1717.314336: rtcpu_vinotify_event: tstamp:54385484896 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740335420800 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.314336: rtcpu_vinotify_event: tstamp:54385485048 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1740335420832 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.314336: rtcpu_vinotify_event: tstamp:54385485179 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740335425280 data:0x0000000000020004
kworker/5:1-2349 [005] .... 1717.314337: rtcpu_vinotify_error: tstamp:54385486539 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740335546144 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.314337: rtcpu_string: tstamp:54385487051 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.314337: rtcpu_string: tstamp:54385487158 id:0x04010000 str:"=0 ts=1740335546144 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.314337: rtcpu_string: tstamp:54385487261 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.314339: rtcpu_string: tstamp:54385487597 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.314339: rtcpu_string: tstamp:54385487698 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.314340: rtcpu_string: tstamp:54385488030 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.314341: rtcpu_string: tstamp:54385488130 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.314342: rtcpu_vinotify_event: tstamp:54385809507 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740335421632 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.314343: rtcpu_vinotify_event: tstamp:54385809643 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740335546144 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.314343: rtcpu_vinotify_error: tstamp:54386008710 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740352255680 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.314343: rtcpu_string: tstamp:54386009222 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.314343: rtcpu_string: tstamp:54386009324 id:0x04010000 str:"=0 ts=1740352255680 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.314343: rtcpu_string: tstamp:54386009428 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.314345: rtcpu_string: tstamp:54386009764 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.314345: rtcpu_string: tstamp:54386009864 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.314346: rtcpu_string: tstamp:54386010197 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.314346: rtcpu_string: tstamp:54386010296 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.314348: rtcpu_vinotify_event: tstamp:54386147540 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740352130368 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.314348: rtcpu_vinotify_event: tstamp:54386147740 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740352131200 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.314348: rtcpu_vinotify_event: tstamp:54386147960 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740352255680 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.314348: rtcpu_vinotify_error: tstamp:54386530886 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740368965280 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.314348: rtcpu_string: tstamp:54386531395 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.314348: rtcpu_string: tstamp:54386531496 id:0x04010000 str:"=0 ts=1740368965280 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.314349: rtcpu_string: tstamp:54386531599 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.314350: rtcpu_string: tstamp:54386531933 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.314350: rtcpu_string: tstamp:54386532033 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.314352: rtcpu_string: tstamp:54386532364 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.314352: rtcpu_string: tstamp:54386532464 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.314353: rtcpu_string: tstamp:54386633113 id:0x04010000 str:"VI5: PFSD enabled for channel: NO, expected_coun"
kworker/5:1-2349 [005] .... 1717.314353: rtcpu_string: tstamp:54386633213 id:0x04010000 str:"t. 0
kworker/5:1-2349 [005] .... 1717.314354: rtcpu_string: tstamp:54386633445 id:0x04010000 str:"VI5: channel_submit(35, bfebf000)
kworker/5:1-2349 [005] .... 1717.314356: rtcpu_string: tstamp:54386633846 id:0x04010000 str:"VI5: completion_actions[8] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.314356: rtcpu_string: tstamp:54386633947 id:0x04010000 str:"t = 314
kworker/5:1-2349 [005] .... 1717.314357: rtcpu_string: tstamp:54386634253 id:0x04010000 str:"VI5: completion_actions[0] size = 31, next offse"
kworker/5:1-2349 [005] .... 1717.314357: rtcpu_string: tstamp:54386634356 id:0x04010000 str:"t = 345
kworker/5:1-2349 [005] .... 1717.314359: rtcpu_string: tstamp:54386634655 id:0x04010000 str:"VI5: completion_actions[2] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.314359: rtcpu_string: tstamp:54386634755 id:0x04010000 str:"t = 359
kworker/5:1-2349 [005] .... 1717.314360: rtcpu_string: tstamp:54386635053 id:0x04010000 str:"VI5: completion_actions[1] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.314360: rtcpu_string: tstamp:54386635154 id:0x04010000 str:"t = 389
kworker/5:1-2349 [005] .... 1717.314362: rtcpu_string: tstamp:54386635451 id:0x04010000 str:"VI5: completion_actions[4] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.314362: rtcpu_string: tstamp:54386635552 id:0x04010000 str:"t = 403
kworker/5:1-2349 [005] .... 1717.314363: rtcpu_string: tstamp:54386635849 id:0x04010000 str:"VI5: completion_actions[3] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.314363: rtcpu_string: tstamp:54386635949 id:0x04010000 str:"t = 417
kworker/5:1-2349 [005] .... 1717.314365: rtcpu_string: tstamp:54386636243 id:0x04010000 str:"VI5: completion_actions[5] size = 2, next offset"
kworker/5:1-2349 [005] .... 1717.314365: rtcpu_string: tstamp:54386636346 id:0x04010000 str:" = 419
kworker/5:1-2349 [005] .... 1717.314366: rtcpu_string: tstamp:54386636714 id:0x04010000 str:"VI5: vi5_update_streams: ch=35 stream_mask=0x01
kworker/5:1-2349 [005] .... 1717.314367: rtcpu_vinotify_event: tstamp:54386823579 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740368839968 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.314367: rtcpu_vinotify_event: tstamp:54386823733 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740368840800 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.314367: rtcpu_vinotify_event: tstamp:54386823863 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740368965280 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.314368: rtcpu_vinotify_event: tstamp:54386824017 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740372394336 data:0x375cff0010000000
kworker/5:1-2349 [005] .... 1717.314368: rtcpu_vinotify_event: tstamp:54386824148 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740372400928 data:0x0000000031000005
kworker/5:1-2349 [005] .... 1717.370334: rtcpu_string: tstamp:54387053279 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.370336: rtcpu_string: tstamp:54387053383 id:0x04010000 str:"_INT_STATUS = 0x1
kworker/5:1-2349 [005] .... 1717.370341: rtcpu_string: tstamp:54387053640 id:0x04010000 str:"VI5: vi5_handle_sof(35)
kworker/5:1-2349 [005] .... 1717.370343: rtcpu_vinotify_event: tstamp:54387161578 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740385549600 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.370343: rtcpu_vinotify_event: tstamp:54387161708 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740385550432 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.370343: rtcpu_vinotify_event: tstamp:54387161865 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1740385550464 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.370343: rtcpu_vinotify_event: tstamp:54387161997 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1740385674912 data:0x0000000000000001
kworker/5:1-2349 [005] .... 1717.370343: rtcpu_vinotify_event: tstamp:54387162146 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740385676192 data:0x0000000008020005
kworker/5:1-2349 [005] .... 1717.370344: rtcpu_vinotify_event: tstamp:54387569053 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:1740402190176 data:0x0000000002cf0002
kworker/5:1-2349 [005] .... 1717.370344: rtcpu_string: tstamp:54387571636 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.370344: rtcpu_string: tstamp:54387571738 id:0x04010000 str:"_INT_STATUS = 0x2
kworker/5:1-2349 [005] .... 1717.370345: rtcpu_string: tstamp:54387572011 id:0x04010000 str:"VI5: vi5_handle_eof(35)
kworker/5:1-2349 [005] .... 1717.370347: rtcpu_vinotify_error: tstamp:54387575236 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740402384480 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.370347: rtcpu_string: tstamp:54387575765 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.370348: rtcpu_string: tstamp:54387575866 id:0x04010000 str:"=0 ts=1740402384480 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.370348: rtcpu_string: tstamp:54387575969 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.370349: rtcpu_string: tstamp:54387576304 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.370350: rtcpu_string: tstamp:54387576404 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.370351: rtcpu_string: tstamp:54387576735 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.370351: rtcpu_string: tstamp:54387576836 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.370352: rtcpu_vinotify_event: tstamp:54387905320 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1740402190720 data:0x0000000000000000
kworker/5:1-2349 [005] .... 1717.370352: rtcpu_vinotify_event: tstamp:54387905455 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740402193728 data:0x0000000002020005
kworker/5:1-2349 [005] .... 1717.370352: rtcpu_vinotify_event: tstamp:54387905604 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740402259168 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.370352: rtcpu_vinotify_event: tstamp:54387905742 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1740402259168 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.370353: rtcpu_vinotify_event: tstamp:54387905897 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740402263648 data:0x0000000000020005
kworker/5:1-2349 [005] .... 1717.370353: rtcpu_vinotify_event: tstamp:54387906028 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740402260032 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.370353: rtcpu_vinotify_event: tstamp:54387906179 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740402384480 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.370353: rtcpu_vinotify_error: tstamp:54388097411 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740419094080 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.370353: rtcpu_string: tstamp:54388097929 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.370354: rtcpu_string: tstamp:54388098032 id:0x04010000 str:"=0 ts=1740419094080 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.370354: rtcpu_string: tstamp:54388098135 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.370355: rtcpu_string: tstamp:54388098471 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.370355: rtcpu_string: tstamp:54388098571 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.370356: rtcpu_string: tstamp:54388098903 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.370357: rtcpu_string: tstamp:54388099004 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.370358: rtcpu_vinotify_event: tstamp:54388243318 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740418968736 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.370358: rtcpu_vinotify_event: tstamp:54388243471 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740418969600 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.370358: rtcpu_vinotify_event: tstamp:54388243602 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740419094080 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.370358: rtcpu_string: tstamp:54388378261 id:0x04010000 str:"VI5: PFSD enabled for channel: NO, expected_coun"
kworker/5:1-2349 [005] .... 1717.370358: rtcpu_string: tstamp:54388378366 id:0x04010000 str:"t. 0
kworker/5:1-2349 [005] .... 1717.370360: rtcpu_string: tstamp:54388378602 id:0x04010000 str:"VI5: channel_submit(35, bfebf180)
kworker/5:1-2349 [005] .... 1717.370361: rtcpu_string: tstamp:54388379000 id:0x04010000 str:"VI5: completion_actions[8] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.370361: rtcpu_string: tstamp:54388379105 id:0x04010000 str:"t = 314
kworker/5:1-2349 [005] .... 1717.370362: rtcpu_string: tstamp:54388379414 id:0x04010000 str:"VI5: completion_actions[0] size = 31, next offse"
kworker/5:1-2349 [005] .... 1717.370363: rtcpu_string: tstamp:54388379518 id:0x04010000 str:"t = 345
kworker/5:1-2349 [005] .... 1717.370364: rtcpu_string: tstamp:54388379820 id:0x04010000 str:"VI5: completion_actions[2] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.370364: rtcpu_string: tstamp:54388379922 id:0x04010000 str:"t = 359
kworker/5:1-2349 [005] .... 1717.370365: rtcpu_string: tstamp:54388380223 id:0x04010000 str:"VI5: completion_actions[1] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.370365: rtcpu_string: tstamp:54388380325 id:0x04010000 str:"t = 389
kworker/5:1-2349 [005] .... 1717.370366: rtcpu_string: tstamp:54388380625 id:0x04010000 str:"VI5: completion_actions[4] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.370367: rtcpu_string: tstamp:54388380726 id:0x04010000 str:"t = 403
kworker/5:1-2349 [005] .... 1717.370368: rtcpu_string: tstamp:54388381023 id:0x04010000 str:"VI5: completion_actions[3] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.370368: rtcpu_string: tstamp:54388381124 id:0x04010000 str:"t = 417
kworker/5:1-2349 [005] .... 1717.370369: rtcpu_string: tstamp:54388381420 id:0x04010000 str:"VI5: completion_actions[5] size = 2, next offset"
kworker/5:1-2349 [005] .... 1717.370369: rtcpu_string: tstamp:54388381522 id:0x04010000 str:" = 419
kworker/5:1-2349 [005] .... 1717.370371: rtcpu_string: tstamp:54388381893 id:0x04010000 str:"VI5: vi5_update_streams: ch=35 stream_mask=0x01
kworker/5:1-2349 [005] .... 1717.370372: rtcpu_vinotify_event: tstamp:54388581452 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740428242176 data:0x375cfc0010000000
kworker/5:1-2349 [005] .... 1717.370372: rtcpu_vinotify_event: tstamp:54388581591 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1740428248768 data:0x0000000031000006
kworker/5:1-2349 [005] .... 1717.370372: rtcpu_string: tstamp:54388619956 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.370372: rtcpu_string: tstamp:54388620058 id:0x04010000 str:"_INT_STATUS = 0x1
kworker/5:1-2349 [005] .... 1717.370373: rtcpu_string: tstamp:54388620315 id:0x04010000 str:"VI5: vi5_handle_sof(35)
kworker/5:1-2349 [005] .... 1717.370374: rtcpu_vinotify_event: tstamp:54388621072 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740435678336 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.370374: rtcpu_vinotify_event: tstamp:54388621206 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740435679168 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.370375: rtcpu_vinotify_event: tstamp:54388621360 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1740435679168 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.370375: rtcpu_vinotify_event: tstamp:54388621494 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1740435803648 data:0x0000000000000001
kworker/5:1-2349 [005] .... 1717.426333: rtcpu_vinotify_event: tstamp:54388953226 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740435806080 data:0x0000000008020006
kworker/5:1-2349 [005] .... 1717.426334: rtcpu_string: tstamp:54389138164 id:0x04010000 str:"VI5: vi5_irq_process_channel_event invoked: CH35"
kworker/5:1-2349 [005] .... 1717.426335: rtcpu_string: tstamp:54389138268 id:0x04010000 str:"_INT_STATUS = 0x2
kworker/5:1-2349 [005] .... 1717.426340: rtcpu_string: tstamp:54389138543 id:0x04010000 str:"VI5: vi5_handle_eof(35)
kworker/5:1-2349 [005] .... 1717.426342: rtcpu_vinotify_error: tstamp:54389141758 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740452513216 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.426342: rtcpu_string: tstamp:54389142269 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.426342: rtcpu_string: tstamp:54389142372 id:0x04010000 str:"=0 ts=1740452513216 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.426343: rtcpu_string: tstamp:54389142479 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.426345: rtcpu_string: tstamp:54389142819 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.426345: rtcpu_string: tstamp:54389142920 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.426346: rtcpu_string: tstamp:54389143252 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.426347: rtcpu_string: tstamp:54389143353 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.426348: rtcpu_vinotify_event: tstamp:54389291272 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:1740452318944 data:0x0000000002cf0002
kworker/5:1-2349 [005] .... 1717.426348: rtcpu_vinotify_event: tstamp:54389291432 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1740452319552 data:0x0000000000000000
kworker/5:1-2349 [005] .... 1717.426348: rtcpu_vinotify_event: tstamp:54389291570 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740452321344 data:0x0000000002020006
kworker/5:1-2349 [005] .... 1717.426348: rtcpu_vinotify_event: tstamp:54389291725 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740452387872 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.426348: rtcpu_vinotify_event: tstamp:54389291861 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1740452387904 data:0x0000000800000000
kworker/5:1-2349 [005] .... 1717.426349: rtcpu_vinotify_event: tstamp:54389292016 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1740452392352 data:0x0000000000020006
kworker/5:1-2349 [005] .... 1717.426349: rtcpu_vinotify_event: tstamp:54389292151 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740452388736 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.426349: rtcpu_vinotify_event: tstamp:54389292303 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740452513216 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.426349: rtcpu_vinotify_error: tstamp:54389663935 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740469222848 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.426349: rtcpu_string: tstamp:54389664451 id:0x04010000 str:"VI5: vi5_process_error_fifo: tag=0x0b ch=1 frame"
kworker/5:1-2349 [005] .... 1717.426349: rtcpu_string: tstamp:54389664559 id:0x04010000 str:"=0 ts=1740469222848 data=0x000003c9 ext_data=0x0"
kworker/5:1-2349 [005] .... 1717.426350: rtcpu_string: tstamp:54389664667 id:0x04010000 str:"0000000
kworker/5:1-2349 [005] .... 1717.426351: rtcpu_string: tstamp:54389665005 id:0x04010000 str:"VI5: error_to_notify_bits CHANSEL_NOMATCH identi"
kworker/5:1-2349 [005] .... 1717.426351: rtcpu_string: tstamp:54389665106 id:0x04010000 str:"fied
kworker/5:1-2349 [005] .... 1717.426352: rtcpu_string: tstamp:54389665442 id:0x04010000 str:"VI5: vi5_notify_error(35) status 0xf tag 0xb, da"
kworker/5:1-2349 [005] .... 1717.426353: rtcpu_string: tstamp:54389665547 id:0x04010000 str:"ta 0x3c9
kworker/5:1-2349 [005] .... 1717.426354: rtcpu_vinotify_event: tstamp:54389967387 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1740469097536 data:0x0000000000000020
kworker/5:1-2349 [005] .... 1717.426354: rtcpu_vinotify_event: tstamp:54389967540 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1740469098368 data:0x0000000000000010
kworker/5:1-2349 [005] .... 1717.426354: rtcpu_vinotify_event: tstamp:54389967672 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1740469222848 data:0x00000000000003c9
kworker/5:1-2349 [005] .... 1717.426354: rtcpu_string: tstamp:54390109747 id:0x04010000 str:"VI5: PFSD enabled for channel: NO, expected_coun"
kworker/5:1-2349 [005] .... 1717.426354: rtcpu_string: tstamp:54390109852 id:0x04010000 str:"t. 0
kworker/5:1-2349 [005] .... 1717.426355: rtcpu_string: tstamp:54390110089 id:0x04010000 str:"VI5: channel_submit(35, bfebf000)
kworker/5:1-2349 [005] .... 1717.426357: rtcpu_string: tstamp:54390110490 id:0x04010000 str:"VI5: completion_actions[8] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.426357: rtcpu_string: tstamp:54390110594 id:0x04010000 str:"t = 314
kworker/5:1-2349 [005] .... 1717.426358: rtcpu_string: tstamp:54390110902 id:0x04010000 str:"VI5: completion_actions[0] size = 31, next offse"
kworker/5:1-2349 [005] .... 1717.426358: rtcpu_string: tstamp:54390111006 id:0x04010000 str:"t = 345
kworker/5:1-2349 [005] .... 1717.426359: rtcpu_string: tstamp:54390111307 id:0x04010000 str:"VI5: completion_actions[2] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.426359: rtcpu_string: tstamp:54390111411 id:0x04010000 str:"t = 359
kworker/5:1-2349 [005] .... 1717.426360: rtcpu_string: tstamp:54390111709 id:0x04010000 str:"VI5: completion_actions[1] size = 30, next offse"
kworker/5:1-2349 [005] .... 1717.426361: rtcpu_string: tstamp:54390111810 id:0x04010000 str:"t = 389
kworker/5:1-2349 [005] .... 1717.426362: rtcpu_string: tstamp:54390112108 id:0x04010000 str:"VI5: completion_actions[4] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.426362: rtcpu_string: tstamp:54390112210 id:0x04010000 str:"t = 403
kworker/5:1-2349 [005] .... 1717.426363: rtcpu_string: tstamp:54390112508 id:0x04010000 str:"VI5: completion_actions[3] size = 14, next offse"
kworker/5:1-2349 [005] .... 1717.426363: rtcpu_string: tstamp:54390112609 id:0x04010000 str:"t = 417
kworker/5:1-2349 [005] .... 1717.426364: rtcpu_string: tstamp:54390112903 id:0x04010000 str:"VI5: completion_actions[5] size = 2, next offset"
kworker/5:1-2349 [005] .... 1717.426365: rtcpu_string: tstamp:54390113004 id:0x04010000 str:" = 419
kworker/5:1-2349 [005] .... 1717.426366: rtcpu_string: tstamp:54390113374 id:0x04010000 str:"VI5: vi5_update_streams: ch=35 stream_mask=0x01
When I did the same work on Jetson TX2, 1924x720 works well .
What should I do to solve this?
Thank you.
