• Hardware Platform (Jetson / GPU) Jetson TX2 • DeepStream Version 6.0 • JetPack Version (valid for Jetson only) 4.6 • TensorRT Version 8.0.1 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) bugs • How to reproduce the issue? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for the new requirement. Including the module name-for which plugin or for which sample application, the function description)
I tried deepstream 6.0 in jetson TX2 board for USB camera with config file /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt with below modification.
I had cross-checked with v4l2-ctl --list-formats-ext. I changed the camera mode to 640x360 with 60 fps. Still, I faced the same issue.
Even the mode 640x480 with 60fps configuration works for Deepstream 4.0 but facing issues only in the Deepstream version 6.0
Below are supported formats by my USB camera. I tried all the below formats and modes but can’t get the stream.
