I have a camera similar to this one Amazon.com
If I connect it to an USB hub, it won’t work at all, not even appear in /dev/video1 (video0 is the TX2 camera module)
I connected the camera directly to the TX2 USB port and I’m controlling the TX2 via TeamViewer. Now I’m getting the following problem when trying to use the camera with OpenCV in Python.
select timeout
VIDIOC_DQBUF: Resource temporarily unavailable
No more frames
Tried to use cheese, but the camera won’t appear. Tried successfully to use the camera in the web browser.
Is this problem specific to the TX2? I can use use the camera successfully with the same Python+OpenCV program in my Ubuntu desktop and in the Jetson Nano.
I have the following information available.
dmesg --follow, when I disconnect the camera
[ 9368.040636] tegra-xusb 3530000.xhci: exiting ELPG
[ 9368.048077] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-10-31 05:52:15 UTC, Version: 55.17 release
[ 9368.049100] tegra-xusb 3530000.xhci: exiting ELPG done
[ 9371.002938] usb 1-2: USB disconnect, device number 28
[ 9371.957806] usb usb1: usb_suspend_both: status 0
[ 9371.957875] tegra-xusb 3530000.xhci: entering ELPG
[ 9371.972243] tegra-xusb 3530000.xhci: entering ELPG done
dmesg --follow, when I connect the camera
[ 9378.796815] tegra-xusb 3530000.xhci: exiting ELPG
[ 9378.804167] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-10-31 05:52:15 UTC, Version: 55.17 release
[ 9378.805214] tegra-xusb 3530000.xhci: exiting ELPG done
[ 9379.033548] usb 1-2: new high-speed USB device number 30 using tegra-xusb
[ 9379.059083] usb 1-2: New USB device found, idVendor=05a3, idProduct=9750
[ 9379.059096] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9379.059103] usb 1-2: Product: 3D USB Camera
[ 9379.059109] usb 1-2: Manufacturer: 3D USB Camera
[ 9379.066932] uvcvideo: Found UVC 1.00 device 3D USB Camera (05a3:9750)
[ 9379.074389] uvcvideo 1-2:1.0: Entity type for entity Extension 4 was not initialized!
[ 9379.082502] uvcvideo 1-2:1.0: Entity type for entity Extension 3 was not initialized!
[ 9379.090870] uvcvideo 1-2:1.0: Entity type for entity Processing 2 was not initialized!
[ 9379.099010] uvcvideo 1-2:1.0: Entity type for entity Camera 1 was not initialized!
[ 9379.107527] input: 3D USB Camera as /devices/3530000.xhci/usb1/1-2/1-2:1.0/input/input19
[ 9381.701681] usb 1-2: usb_suspend_both: status 0
[ 9381.701880] usb usb1: usb_suspend_both: status 0
[ 9381.701936] tegra-xusb 3530000.xhci: entering ELPG
[ 9381.708057] tegra-xusb 3530000.xhci: entering ELPG done
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 030: ID 05a3:9750 ARC International
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsusb -s 001:030 -v
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x05a3 ARC International
idProduct 0x9750
bcdDevice 21.03
iManufacturer 1
iProduct 2
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 525
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 14 Video
bFunctionSubClass 3 Video Interface Collection
bFunctionProtocol 0
iFunction 4
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 14 Video
bInterfaceSubClass 1 Video Control
bInterfaceProtocol 0
iInterface 4
VideoControl Interface Descriptor:
bLength 13
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdUVC 1.00
wTotalLength 109
dwClockFrequency 48.000000MHz
bInCollection 1
baInterfaceNr( 0) 1
bLength 18
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0201 Camera Sensor
bAssocTerminal 0
iTerminal 0
wObjectiveFocalLengthMin 0
wObjectiveFocalLengthMax 0
wOcularFocalLength 0
bControlSize 3
bmControls 0x0002202a
Auto-Exposure Mode
Exposure Time (Absolute)
Focus (Absolute)
Roll (Absolute)
Focus, Auto
bLength 11
bDescriptorType 36
bDescriptorSubtype 5 (PROCESSING_UNIT)
Warning: Descriptor too short
bUnitID 2
bSourceID 1
wMaxMultiplier 16384
bControlSize 2
bmControls 0x0000177f
Brightness
Contrast
Hue
Saturation
Sharpness
Gamma
White Balance Temperature
Backlight Compensation
Gain
Power Line Frequency
White Balance Temperature, Auto
iProcessing 0
bmVideoStandards 0x1d
None
PAL - 625/50
SECAM - 625/50
NTSC - 625/50
bLength 29
bDescriptorType 36
bDescriptorSubtype 6 (EXTENSION_UNIT)
bUnitID 3
guidExtensionCode {c385b80f-c268-4745-90f7-8f47579d95fc}
bNumControl 5
bNrPins 1
baSourceID( 0) 2
bControlSize 4
bmControls( 0) 0x1f
bmControls( 1) 0x00
bmControls( 2) 0x00
bmControls( 3) 0x00
iExtension 0
bLength 29
bDescriptorType 36
bUnitID 4
guidExtensionCode {991d5a7d-325b-8b42-8cad-671b8a65f37a}
bNumControl 24
bNrPins 1
baSourceID( 0) 3
bControlSize 4
bmControls( 0) 0xff
bmControls( 1) 0xff
bmControls( 2) 0xfe
bmControls( 3) 0x01
iExtension 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 5
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 4
iTerminal 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 8
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Video Streaming
iInterface 0
VideoStreaming Interface Descriptor:
bLength 14
bDescriptorType 36
bDescriptorSubtype 1 (INPUT_HEADER)
bNumFormats 1
wTotalLength 193
bEndPointAddress 129
bmInfo 0
bTerminalLink 5
bStillCaptureMethod 2
bTriggerSupport 0
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 11
bLength 11
bDescriptorType 36
bDescriptorSubtype 6 (FORMAT_MJPEG)
bFormatIndex 1
bNumFrameDescriptors 4
bFlags 1
Fixed-size samples: Yes
bDefaultFrameIndex 1
bAspectRatioX 0
bAspectRatioY 0
bmInterlaceFlags 0x00
Interlaced stream or variable: No
Fields per frame: 1 fields
Field 1 first: No
Field pattern: Field 1 only
bCopyProtect 0
bLength 34
bDescriptorType 36
bDescriptorSubtype 7 (FRAME_MJPEG)
bFrameIndex 1
bmCapabilities 0x00
Still image unsupported
wWidth 2560
wHeight 960
dwMinBitRate 1179648000
dwMaxBitRate 2359296000
dwMaxVideoFrameBufferSize 4915200
dwDefaultFrameInterval 166666
bFrameIntervalType 2
dwFrameInterval( 0) 166666
dwFrameInterval( 1) 333333
bLength 34
bDescriptorType 36
bFrameIndex 2
bmCapabilities 0x00
wWidth 2560
wHeight 720
dwMinBitRate 884736000
dwMaxBitRate 1769472000
dwMaxVideoFrameBufferSize 3686400
bLength 34
bDescriptorType 36
bFrameIndex 3
bmCapabilities 0x00
wWidth 1280
wHeight 480
dwMinBitRate 294912000
dwMaxBitRate 589824000
dwMaxVideoFrameBufferSize 1228800
bLength 34
bDescriptorType 36
bFrameIndex 4
bmCapabilities 0x00
wWidth 640
wHeight 240
dwMinBitRate 73728000
dwMaxBitRate 147456000
dwMaxVideoFrameBufferSize 307200
bLength 26
bDescriptorType 36
bDescriptorSubtype 3 (STILL_IMAGE_FRAME)
bEndpointAddress 0
bNumImageSizePatterns 4
wWidth( 0) 2560
wHeight( 0) 960
wWidth( 1) 2560
wHeight( 1) 720
wWidth( 2) 1280
wHeight( 2) 480
wWidth( 3) 640
wHeight( 3) 240
bNumCompressionPatterns 4
bCompression( 0) 1
bCompression( 1) 5
bCompression( 2) 10
bCompression( 3) 20
bLength 6
bDescriptorType 36
bDescriptorSubtype 13 (COLORFORMAT)
bColorPrimaries 1 (BT.709,sRGB)
bTransferCharacteristics 1 (BT.709)
bMatrixCoefficients 4 (SMPTE 170M (BT.601))
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x00c0 1x 192 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0180 1x 384 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0280 1x 640 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0320 1x 800 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 6
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x03b0 1x 944 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 7
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0a80 2x 640 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 8
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0b20 2x 800 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 9
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0be0 2x 992 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 10
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x13c0 3x 960 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 11
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x1400 3x 1024 bytes
bInterval 1
