It looks like dev_dbg() is working. I did the same thing for both files and it worked for csi2_fops.c. Also, the sensor driver dev_dbg() messages are also printed (ar0237 messages).
Hi Shane,
Is there anything else that we can check for any issues on csi/vi data streaming?
Hi Shane,
I went back to R28.2. Whether I apply the patches that you provided or not, I get the MW_ACK_DONE syncpoint error:
May 15 08:52:44 tegra-ubuntu kernel: [ 186.440376] ar0237 30-0010: ar0237_power_on: power on
May 15 08:52:44 tegra-ubuntu kernel: [ 186.447224] ar0237 30-0010: ar0237_s_stream++
May 15 08:52:44 tegra-ubuntu kernel: [ 186.452269] ar0237 30-0010: ar0237_s_stream mode[3]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.464518] ar0237 30-0010: post ar0237_s_stream mode[3]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.470511] ar0237 30-0010: ar0237_s_stream mode[0]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.543318] ar0237 30-0010: post ar0237_s_stream mode[0]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.549299] ar0237 30-0010: ar0237_s_stream++
May 15 08:52:44 tegra-ubuntu kernel: [ 186.553751] ar0237 30-0010: ar0237_s_stream mode[3]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.562453] ar0237 30-0010: post ar0237_s_stream mode[3]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.568068] ar0237 30-0010: ar0237_power_off: power off
May 15 08:52:44 tegra-ubuntu kernel: [ 186.573885] ar0237 30-0010: ar0237_power_on: power on
May 15 08:52:44 tegra-ubuntu kernel: [ 186.637525] ar0237 30-0010: ar0237_s_stream++
May 15 08:52:44 tegra-ubuntu kernel: [ 186.641902] ar0237 30-0010: ar0237_s_stream mode[3]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.649863] ar0237 30-0010: post ar0237_s_stream mode[3]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.655384] ar0237 30-0010: ar0237_s_stream mode[0]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.717316] ar0237 30-0010: post ar0237_s_stream mode[0]
May 15 08:52:44 tegra-ubuntu kernel: [ 186.828851] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:45 tegra-ubuntu kernel: [ 186.965401] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:45 tegra-ubuntu kernel: [ 187.102336] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:45 tegra-ubuntu kernel: [ 187.238971] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:45 tegra-ubuntu kernel: [ 187.375763] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:45 tegra-ubuntu kernel: [ 187.512555] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:45 tegra-ubuntu kernel: [ 187.539085] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 30
May 15 08:52:45 tegra-ubuntu kernel: [ 187.657361] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:45 tegra-ubuntu kernel: [ 187.834422] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:46 tegra-ubuntu kernel: [ 188.019283] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:46 tegra-ubuntu kernel: [ 188.073446] vi 54080000.vi: tegra_channel_error_status:error 4000 frame 39
May 15 08:52:46 tegra-ubuntu kernel: [ 188.276628] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:46 tegra-ubuntu kernel: [ 188.340990] video4linux video0: frame start syncpt timeout!0
May 15 08:52:46 tegra-ubuntu kernel: [ 188.347070] vi 54080000.vi: tegra_channel_error_status:error 4000 frame 43
May 15 08:52:46 tegra-ubuntu kernel: [ 188.722999] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:47 tegra-ubuntu kernel: [ 188.891651] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:47 tegra-ubuntu kernel: [ 189.020222] vi 54080000.vi: tegra_channel_error_status:error 4000 frame 50
May 15 08:52:47 tegra-ubuntu kernel: [ 189.070207] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 51
May 15 08:52:47 tegra-ubuntu kernel: [ 189.458213] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:47 tegra-ubuntu kernel: [ 189.504375] vi 54080000.vi: tegra_channel_error_status:error 4000 frame 54
May 15 08:52:47 tegra-ubuntu kernel: [ 189.707199] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:48 tegra-ubuntu kernel: [ 189.972475] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:48 tegra-ubuntu kernel: [ 190.041890] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 59
May 15 08:52:48 tegra-ubuntu kernel: [ 190.257473] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 08:52:49 tegra-ubuntu kernel: [ 191.420483] ar0237 30-0010: ar0237_s_stream++
May 15 08:52:49 tegra-ubuntu kernel: [ 191.425149] ar0237 30-0010: ar0237_s_stream mode[3]
May 15 08:52:49 tegra-ubuntu kernel: [ 191.436111] ar0237 30-0010: post ar0237_s_stream mode[3]
May 15 08:52:49 tegra-ubuntu kernel: [ 191.458377] ar0237 30-0010: ar0237_power_off: power off
Could you change the dev_dbg() to dev_err() in tegra_csi_status() in csi2_fops.c to print the status.
Hi Shane,
I enabled dev_dbg yesterday for both vi2_fops.c and csi2_fops.c. Below is the log result:
May 15 23:39:01 tegra-ubuntu kernel: [ 52.180325] ar0237 30-0010: ar0237_power_on: power on
May 15 23:39:01 tegra-ubuntu kernel: [ 52.187152] ar0237 30-0010: ar0237_s_stream++
May 15 23:39:01 tegra-ubuntu kernel: [ 52.191663] ar0237 30-0010: ar0237_s_stream mode[3]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.200488] ar0237 30-0010: post ar0237_s_stream mode[3]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.206196] ar0237 30-0010: ar0237_s_stream mode[0]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.271199] ar0237 30-0010: post ar0237_s_stream mode[0]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.276593] vi 54080000.vi: Calibrate csi port 0
May 15 23:39:01 tegra-ubuntu kernel: [ 52.281850] ar0237 30-0010: ar0237_s_stream++
May 15 23:39:01 tegra-ubuntu kernel: [ 52.286572] ar0237 30-0010: ar0237_s_stream mode[3]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.295131] ar0237 30-0010: post ar0237_s_stream mode[3]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.300532] ar0237 30-0010: ar0237_power_off: power off
May 15 23:39:01 tegra-ubuntu kernel: [ 52.306354] ar0237 30-0010: ar0237_power_on: power on
May 15 23:39:01 tegra-ubuntu kernel: [ 52.365650] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.372032] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.379052] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.384636] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.390869] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:01 tegra-ubuntu kernel: [ 52.397095] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:01 tegra-ubuntu kernel: [ 52.403532] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:01 tegra-ubuntu kernel: [ 52.410446] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:01 tegra-ubuntu kernel: [ 52.416667] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:01 tegra-ubuntu kernel: [ 52.422538] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:01 tegra-ubuntu kernel: [ 52.429427] ar0237 30-0010: ar0237_s_stream++
May 15 23:39:01 tegra-ubuntu kernel: [ 52.433796] ar0237 30-0010: ar0237_s_stream mode[3]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.442131] ar0237 30-0010: post ar0237_s_stream mode[3]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.447449] ar0237 30-0010: ar0237_s_stream mode[0]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.512545] ar0237 30-0010: post ar0237_s_stream mode[0]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.517875] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6f400]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.527167] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6f400]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.541390] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d400]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.575830] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6c400]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.610088] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6e000]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.627281] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:01 tegra-ubuntu kernel: [ 52.633293] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6d400]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.644244] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d000]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.653575] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.660321] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.666700] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.672500] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.678274] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:01 tegra-ubuntu kernel: [ 52.685080] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:01 tegra-ubuntu kernel: [ 52.691329] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:01 tegra-ubuntu kernel: [ 52.698265] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030253000]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.708127] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc030253000]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.712808] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030252800]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.747108] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6f400]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.781389] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d400]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.803654] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:01 tegra-ubuntu kernel: [ 52.809664] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc030252800]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.815666] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6c400]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.849956] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6e000]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.859327] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.866516] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.873423] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.879385] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:01 tegra-ubuntu kernel: [ 52.885802] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:01 tegra-ubuntu kernel: [ 52.892200] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:01 tegra-ubuntu kernel: [ 52.898299] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:01 tegra-ubuntu kernel: [ 52.905673] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d000]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.915292] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6d000]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.918516] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030253000]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.952977] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030252800]
May 15 23:39:01 tegra-ubuntu kernel: [ 52.987233] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6f400]
May 15 23:39:01 tegra-ubuntu kernel: [ 53.016000] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:01 tegra-ubuntu kernel: [ 53.022031] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc030253000]
May 15 23:39:01 tegra-ubuntu kernel: [ 53.022081] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.055844] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6c400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.065182] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.071620] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.078026] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.083813] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.089558] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:02 tegra-ubuntu kernel: [ 53.095681] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:02 tegra-ubuntu kernel: [ 53.101537] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:02 tegra-ubuntu kernel: [ 53.108446] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6e000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.117968] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6e000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.127333] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.158534] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030253000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.196285] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030252800]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.216407] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:02 tegra-ubuntu kernel: [ 53.222427] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6d000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.231740] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6f400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.240969] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.247327] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.253686] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.259290] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.265014] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:02 tegra-ubuntu kernel: [ 53.271152] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:02 tegra-ubuntu kernel: [ 53.277184] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:02 tegra-ubuntu kernel: [ 53.284126] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.293413] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6d400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.302698] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6c400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.329995] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6e000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.364354] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.392705] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:02 tegra-ubuntu kernel: [ 53.398789] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030253000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.398935] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6c400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.417263] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.423850] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.430237] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.435819] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.441539] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:02 tegra-ubuntu kernel: [ 53.447670] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:02 tegra-ubuntu kernel: [ 53.453530] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:02 tegra-ubuntu kernel: [ 53.460599] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030252800]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.469910] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6f400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.470015] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc030252800]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.501493] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.535844] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6c400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.564994] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:02 tegra-ubuntu kernel: [ 53.569962] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6e000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.580544] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6f400]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.661351] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 15 23:39:02 tegra-ubuntu kernel: [ 53.667801] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 15 23:39:02 tegra-ubuntu kernel: [ 53.674164] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.679745] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:02 tegra-ubuntu kernel: [ 53.685453] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:02 tegra-ubuntu kernel: [ 53.691578] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:02 tegra-ubuntu kernel: [ 53.697439] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:02 tegra-ubuntu kernel: [ 53.704362] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.713729] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6d000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.741439] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030253000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.810006] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030252800]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.829374] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:02 tegra-ubuntu kernel: [ 53.835617] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc030253000]
May 15 23:39:02 tegra-ubuntu kernel: [ 53.844229] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6f400]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.198337] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 15 23:39:03 tegra-ubuntu kernel: [ 54.210910] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 15 23:39:03 tegra-ubuntu kernel: [ 54.217601] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:03 tegra-ubuntu kernel: [ 54.223188] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:03 tegra-ubuntu kernel: [ 54.229376] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:03 tegra-ubuntu kernel: [ 54.235497] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:03 tegra-ubuntu kernel: [ 54.241399] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:03 tegra-ubuntu kernel: [ 54.248413] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d400]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.257719] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6d400]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.290073] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6c400]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.324420] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6e000]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.358747] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d000]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.378338] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:03 tegra-ubuntu kernel: [ 54.384347] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6c400]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.482614] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 15 23:39:03 tegra-ubuntu kernel: [ 54.488975] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 15 23:39:03 tegra-ubuntu kernel: [ 54.496020] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:03 tegra-ubuntu kernel: [ 54.501809] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:03 tegra-ubuntu kernel: [ 54.507692] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:03 tegra-ubuntu kernel: [ 54.514371] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:03 tegra-ubuntu kernel: [ 54.520346] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:03 tegra-ubuntu kernel: [ 54.528645] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030253000]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.538024] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc030253000]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.564449] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030252800]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.650694] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:03 tegra-ubuntu kernel: [ 54.656704] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc030252800]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.787654] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 15 23:39:03 tegra-ubuntu kernel: [ 54.794495] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 15 23:39:03 tegra-ubuntu kernel: [ 54.800891] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:03 tegra-ubuntu kernel: [ 54.806826] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:03 tegra-ubuntu kernel: [ 54.812971] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:03 tegra-ubuntu kernel: [ 54.820065] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:03 tegra-ubuntu kernel: [ 54.825985] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:03 tegra-ubuntu kernel: [ 54.832880] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6f400]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.842799] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6f400]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.873056] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6d400]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.907165] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6c400]
May 15 23:39:03 tegra-ubuntu kernel: [ 54.959194] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:03 tegra-ubuntu kernel: [ 54.965214] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6d400]
May 15 23:39:04 tegra-ubuntu kernel: [ 55.098970] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 15 23:39:04 tegra-ubuntu kernel: [ 55.107165] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 15 23:39:04 tegra-ubuntu kernel: [ 55.113659] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.119270] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.125181] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:04 tegra-ubuntu kernel: [ 55.131303] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:04 tegra-ubuntu kernel: [ 55.137166] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:04 tegra-ubuntu kernel: [ 55.144548] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6e000]
May 15 23:39:04 tegra-ubuntu kernel: [ 55.153853] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6e000]
May 15 23:39:04 tegra-ubuntu kernel: [ 55.311672] video4linux video0: frame start syncpt timeout!0
May 15 23:39:04 tegra-ubuntu kernel: [ 55.317376] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.324869] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.331463] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.339601] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.345578] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:04 tegra-ubuntu kernel: [ 55.352800] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:04 tegra-ubuntu kernel: [ 55.359203] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:04 tegra-ubuntu kernel: [ 55.367073] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.373467] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.379903] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.386033] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.392165] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:04 tegra-ubuntu kernel: [ 55.398285] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:04 tegra-ubuntu kernel: [ 55.404304] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:04 tegra-ubuntu kernel: [ 55.411266] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030253000]
May 15 23:39:04 tegra-ubuntu kernel: [ 55.420678] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc030253000]
May 15 23:39:04 tegra-ubuntu kernel: [ 55.428666] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc030252800]
May 15 23:39:04 tegra-ubuntu kernel: [ 55.515942] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 15 23:39:04 tegra-ubuntu kernel: [ 55.521969] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc030252800]
May 15 23:39:04 tegra-ubuntu kernel: [ 55.564358] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 15 23:39:04 tegra-ubuntu kernel: [ 55.583672] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 15 23:39:04 tegra-ubuntu kernel: [ 55.590911] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.598138] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 15 23:39:04 tegra-ubuntu kernel: [ 55.604462] vi 54080000.vi: cil_settingtime is pulled from device
May 15 23:39:04 tegra-ubuntu kernel: [ 55.611228] vi 54080000.vi: cil_settingtime was autocalculated
May 15 23:39:04 tegra-ubuntu kernel: [ 55.617418] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 15 23:39:04 tegra-ubuntu kernel: [ 55.624509] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc079c6f400]
May 15 23:39:04 tegra-ubuntu kernel: [ 55.633805] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc079c6f400]
May 15 23:39:05 tegra-ubuntu kernel: [ 56.616700] video4linux video0: tegra_channel_capture_done: no buffers in queue
May 15 23:39:05 tegra-ubuntu kernel: [ 56.624508] ar0237 30-0010: ar0237_s_stream++
May 15 23:39:05 tegra-ubuntu kernel: [ 56.629448] ar0237 30-0010: ar0237_s_stream mode[3]
May 15 23:39:05 tegra-ubuntu kernel: [ 56.640004] ar0237 30-0010: post ar0237_s_stream mode[3]
May 15 23:39:05 tegra-ubuntu kernel: [ 56.668417] ar0237 30-0010: ar0237_power_off: power off
At beginning looks like CSI didn’t get any validate frame data try some delay after the sensor driver write the initial table.
After that error show PPA_SHORT_FRAME that could be the sensor output resolution height not as expect.
Hi Shane,
Should the delay be added only during start of streaming or every capture of frame?
Can I apply this delay at the user application level?
Only can add to the sensor kernel driver after the write table in the _s_stream()
Hi Shane,
I still get the same errors after applying the delay:
May 16 06:32:20 tegra-ubuntu kernel: [ 45.807850] ar0237 30-0010: ar0237_power_on: power on
May 16 06:32:20 tegra-ubuntu kernel: [ 45.813634] ar0237 30-0010: ar0237_s_stream++
May 16 06:32:20 tegra-ubuntu kernel: [ 45.818333] ar0237 30-0010: ar0237_s_stream mode[3]
May 16 06:32:20 tegra-ubuntu kernel: [ 45.826850] ar0237 30-0010: post ar0237_s_stream mode[3]
May 16 06:32:20 tegra-ubuntu kernel: [ 45.832242] ar0237 30-0010: ar0237_s_stream mode[0]
May 16 06:32:20 tegra-ubuntu kernel: [ 45.896293] ar0237 30-0010: post ar0237_s_stream mode[0]
May 16 06:32:20 tegra-ubuntu kernel: [ 46.101708] vi 54080000.vi: Calibrate csi port 0
May 16 06:32:20 tegra-ubuntu kernel: [ 46.106600] ar0237 30-0010: ar0237_s_stream++
May 16 06:32:20 tegra-ubuntu kernel: [ 46.111014] ar0237 30-0010: ar0237_s_stream mode[3]
May 16 06:32:20 tegra-ubuntu kernel: [ 46.119489] ar0237 30-0010: post ar0237_s_stream mode[3]
May 16 06:32:20 tegra-ubuntu kernel: [ 46.124806] ar0237 30-0010: ar0237_power_off: power off
May 16 06:32:20 tegra-ubuntu kernel: [ 46.130398] ar0237 30-0010: ar0237_power_on: power on
May 16 06:32:20 tegra-ubuntu kernel: [ 46.171046] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 06:32:20 tegra-ubuntu kernel: [ 46.177407] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 06:32:20 tegra-ubuntu kernel: [ 46.183924] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:20 tegra-ubuntu kernel: [ 46.189721] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:20 tegra-ubuntu kernel: [ 46.196250] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:20 tegra-ubuntu kernel: [ 46.202402] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:20 tegra-ubuntu kernel: [ 46.208829] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:20 tegra-ubuntu kernel: [ 46.216019] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:20 tegra-ubuntu kernel: [ 46.222410] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:20 tegra-ubuntu kernel: [ 46.228363] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:20 tegra-ubuntu kernel: [ 46.235252] ar0237 30-0010: ar0237_s_stream++
May 16 06:32:20 tegra-ubuntu kernel: [ 46.239608] ar0237 30-0010: ar0237_s_stream mode[3]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.248035] ar0237 30-0010: post ar0237_s_stream mode[3]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.253357] ar0237 30-0010: ar0237_s_stream mode[0]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.321011] ar0237 30-0010: post ar0237_s_stream mode[0]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.526450] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d000]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.535673] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d000]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.559509] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48f000]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.593834] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d800]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.628117] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48e000]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.648331] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:21 tegra-ubuntu kernel: [ 46.654335] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48f000]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.663560] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.672794] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 46.679153] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 46.685508] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 46.691380] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 46.697099] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:21 tegra-ubuntu kernel: [ 46.703326] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:21 tegra-ubuntu kernel: [ 46.709283] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:21 tegra-ubuntu kernel: [ 46.716182] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d400]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.725409] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d400]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.732158] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48c400]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.765191] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d000]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.799508] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48f000]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.824197] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:21 tegra-ubuntu kernel: [ 46.830203] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48c400]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.833652] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d800]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.867914] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48e000]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.877832] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 46.888173] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 46.895438] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 46.905410] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 46.911466] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:21 tegra-ubuntu kernel: [ 46.918135] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:21 tegra-ubuntu kernel: [ 46.924120] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:21 tegra-ubuntu kernel: [ 46.931440] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.940897] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d400]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.940942] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:21 tegra-ubuntu kernel: [ 46.970761] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48c400]
May 16 06:32:21 tegra-ubuntu kernel: [ 47.008210] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d000]
May 16 06:32:21 tegra-ubuntu kernel: [ 47.036334] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:21 tegra-ubuntu kernel: [ 47.039431] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48f000]
May 16 06:32:21 tegra-ubuntu kernel: [ 47.051556] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d400]
May 16 06:32:21 tegra-ubuntu kernel: [ 47.073668] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d800]
May 16 06:32:21 tegra-ubuntu kernel: [ 47.083980] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 47.090995] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 47.097741] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 47.103544] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:21 tegra-ubuntu kernel: [ 47.109557] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:21 tegra-ubuntu kernel: [ 47.115958] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:21 tegra-ubuntu kernel: [ 47.121946] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:21 tegra-ubuntu kernel: [ 47.129236] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48e000]
May 16 06:32:21 tegra-ubuntu kernel: [ 47.139137] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48e000]
May 16 06:32:21 tegra-ubuntu kernel: [ 47.142206] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:21 tegra-ubuntu kernel: [ 47.176654] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d400]
May 16 06:32:21 tegra-ubuntu kernel: [ 47.210900] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48c400]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.236328] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:22 tegra-ubuntu kernel: [ 47.242353] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.245138] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.279414] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48f000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.288679] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.295073] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.301507] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.307134] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.312896] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:22 tegra-ubuntu kernel: [ 47.319017] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:22 tegra-ubuntu kernel: [ 47.324875] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:22 tegra-ubuntu kernel: [ 47.331840] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d800]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.341582] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d800]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.347955] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48e000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.382200] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.416520] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d400]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.436325] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:22 tegra-ubuntu kernel: [ 47.442351] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48e000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.450838] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48c400]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.485094] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.494388] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.500844] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.507422] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.513045] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.518755] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:22 tegra-ubuntu kernel: [ 47.524877] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:22 tegra-ubuntu kernel: [ 47.530736] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:22 tegra-ubuntu kernel: [ 47.537651] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48f000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.547406] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48f000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.553654] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d800]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.588159] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48e000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.622375] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.648295] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:22 tegra-ubuntu kernel: [ 47.654302] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d800]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.663557] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d400]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.672833] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.679207] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.685698] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.691287] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.697056] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:22 tegra-ubuntu kernel: [ 47.703277] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:22 tegra-ubuntu kernel: [ 47.709135] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:22 tegra-ubuntu kernel: [ 47.716257] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48c400]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.725517] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48c400]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.734802] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.759389] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48f000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.793653] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d800]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.820333] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:22 tegra-ubuntu kernel: [ 47.826347] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.835576] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48e000]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.844807] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.851170] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.857533] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.863111] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 47.868822] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:22 tegra-ubuntu kernel: [ 47.874960] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:22 tegra-ubuntu kernel: [ 47.880839] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:22 tegra-ubuntu kernel: [ 47.887786] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.897034] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.906277] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d400]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.930946] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48c400]
May 16 06:32:22 tegra-ubuntu kernel: [ 47.992195] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:22 tegra-ubuntu kernel: [ 47.992547] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d000]
May 16 06:32:22 tegra-ubuntu kernel: [ 48.006078] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48f000]
May 16 06:32:22 tegra-ubuntu kernel: [ 48.016658] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d400]
May 16 06:32:22 tegra-ubuntu kernel: [ 48.119734] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 06:32:22 tegra-ubuntu kernel: [ 48.126233] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 06:32:22 tegra-ubuntu kernel: [ 48.133035] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 48.139652] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:22 tegra-ubuntu kernel: [ 48.145590] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:22 tegra-ubuntu kernel: [ 48.151879] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:22 tegra-ubuntu kernel: [ 48.157892] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:22 tegra-ubuntu kernel: [ 48.165373] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d800]
May 16 06:32:22 tegra-ubuntu kernel: [ 48.175159] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d800]
May 16 06:32:22 tegra-ubuntu kernel: [ 48.205111] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48e000]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.292230] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:23 tegra-ubuntu kernel: [ 48.298469] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48e000]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.312922] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.334359] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 48.340874] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 48.348153] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 48.353792] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 48.360169] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:23 tegra-ubuntu kernel: [ 48.366533] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:23 tegra-ubuntu kernel: [ 48.372932] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:23 tegra-ubuntu kernel: [ 48.380145] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d400]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.389369] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d400]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.410979] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48c400]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.479507] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d000]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.500290] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:23 tegra-ubuntu kernel: [ 48.506374] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48c400]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.539800] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 06:32:23 tegra-ubuntu kernel: [ 48.546257] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 06:32:23 tegra-ubuntu kernel: [ 48.552633] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 48.558570] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 48.564273] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:23 tegra-ubuntu kernel: [ 48.570705] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:23 tegra-ubuntu kernel: [ 48.576748] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:23 tegra-ubuntu kernel: [ 48.584179] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48f000]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.593486] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48f000]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.616698] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d800]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.704792] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:23 tegra-ubuntu kernel: [ 48.711068] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d800]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.720794] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48e000]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.778587] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 06:32:23 tegra-ubuntu kernel: [ 48.785593] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 06:32:23 tegra-ubuntu kernel: [ 48.792036] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 48.798336] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 48.804196] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:23 tegra-ubuntu kernel: [ 48.810347] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:23 tegra-ubuntu kernel: [ 48.816273] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:23 tegra-ubuntu kernel: [ 48.823635] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.833057] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.856729] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d400]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.944212] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:23 tegra-ubuntu kernel: [ 48.950781] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d400]
May 16 06:32:23 tegra-ubuntu kernel: [ 48.961231] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48c400]
May 16 06:32:23 tegra-ubuntu kernel: [ 49.014365] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 06:32:23 tegra-ubuntu kernel: [ 49.020948] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 06:32:23 tegra-ubuntu kernel: [ 49.028831] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 49.035309] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:23 tegra-ubuntu kernel: [ 49.041833] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:23 tegra-ubuntu kernel: [ 49.048507] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:23 tegra-ubuntu kernel: [ 49.055046] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:23 tegra-ubuntu kernel: [ 49.062666] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d000]
May 16 06:32:23 tegra-ubuntu kernel: [ 49.072224] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48d000]
May 16 06:32:23 tegra-ubuntu kernel: [ 49.130805] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48f000]
May 16 06:32:23 tegra-ubuntu kernel: [ 49.165218] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d800]
May 16 06:32:23 tegra-ubuntu kernel: [ 49.220376] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:23 tegra-ubuntu kernel: [ 49.226696] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48f000]
May 16 06:32:24 tegra-ubuntu kernel: [ 49.248326] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 06:32:24 tegra-ubuntu kernel: [ 49.254783] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 06:32:24 tegra-ubuntu kernel: [ 49.261208] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 06:32:24 tegra-ubuntu kernel: [ 49.267363] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 06:32:24 tegra-ubuntu kernel: [ 49.273118] vi 54080000.vi: cil_settingtime is pulled from device
May 16 06:32:24 tegra-ubuntu kernel: [ 49.279282] vi 54080000.vi: cil_settingtime was autocalculated
May 16 06:32:24 tegra-ubuntu kernel: [ 49.285332] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 06:32:24 tegra-ubuntu kernel: [ 49.292270] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48e000]
May 16 06:32:24 tegra-ubuntu kernel: [ 49.301710] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48e000]
May 16 06:32:24 tegra-ubuntu kernel: [ 49.336612] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:24 tegra-ubuntu kernel: [ 49.370876] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc05f48d400]
May 16 06:32:24 tegra-ubuntu kernel: [ 49.424366] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 06:32:24 tegra-ubuntu kernel: [ 49.430399] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc05f48cc00]
May 16 06:32:25 tegra-ubuntu kernel: [ 50.396399] video4linux video0: tegra_channel_capture_done: no buffers in queue
May 16 06:32:25 tegra-ubuntu kernel: [ 50.404036] ar0237 30-0010: ar0237_s_stream++
May 16 06:32:25 tegra-ubuntu kernel: [ 50.413404] ar0237 30-0010: ar0237_s_stream mode[3]
May 16 06:32:25 tegra-ubuntu kernel: [ 50.427006] ar0237 30-0010: post ar0237_s_stream mode[3]
May 16 06:32:25 tegra-ubuntu kernel: [ 50.445782] ar0237 30-0010: ar0237_power_off: power off
Can you upload your driver here.
Could you try the delay after START_STREAM
err = ar0237_write_table(priv, mode_table[AR0237_MODE_START_STREAM]);
Hi Shane,
I still get the same result even after moving the delay:
May 16 08:27:57 tegra-ubuntu kernel: [ 38.779342] ar0237 30-0010: ar0237_power_on: power on
May 16 08:27:57 tegra-ubuntu kernel: [ 38.787376] ar0237 30-0010: ar0237_s_stream++
May 16 08:27:57 tegra-ubuntu kernel: [ 38.792109] ar0237 30-0010: ar0237_s_stream mode[3]
May 16 08:27:57 tegra-ubuntu kernel: [ 38.801277] ar0237 30-0010: post ar0237_s_stream mode[3]
May 16 08:27:57 tegra-ubuntu kernel: [ 38.806745] ar0237 30-0010: ar0237_s_stream mode[0]
May 16 08:27:57 tegra-ubuntu kernel: [ 38.871186] ar0237 30-0010: post ar0237_s_stream mode[0]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.076672] vi 54080000.vi: Calibrate csi port 0
May 16 08:27:58 tegra-ubuntu kernel: [ 39.081562] ar0237 30-0010: ar0237_s_stream++
May 16 08:27:58 tegra-ubuntu kernel: [ 39.085930] ar0237 30-0010: ar0237_s_stream mode[3]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.094209] ar0237 30-0010: post ar0237_s_stream mode[3]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.099524] ar0237 30-0010: ar0237_power_off: power off
May 16 08:27:58 tegra-ubuntu kernel: [ 39.105124] ar0237 30-0010: ar0237_power_on: power on
May 16 08:27:58 tegra-ubuntu kernel: [ 39.144142] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 39.150853] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 39.157424] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 39.163934] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 39.169709] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:58 tegra-ubuntu kernel: [ 39.175928] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:57 tegra-ubuntu kernel: [ 39.181906] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:57 tegra-ubuntu kernel: [ 39.188891] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:57 tegra-ubuntu kernel: [ 39.196323] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:57 tegra-ubuntu kernel: [ 39.204179] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:57 tegra-ubuntu kernel: [ 39.211497] ar0237 30-0010: ar0237_s_stream++
May 16 08:27:57 tegra-ubuntu kernel: [ 39.215928] ar0237 30-0010: ar0237_s_stream mode[3]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.223757] ar0237 30-0010: post ar0237_s_stream mode[3]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.229137] ar0237 30-0010: ar0237_s_stream mode[0]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.280201] ar0237 30-0010: post ar0237_s_stream mode[0]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.485567] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.494837] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496400]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.518929] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495800]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.553346] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496000]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.587633] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495c00]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.608345] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:57 tegra-ubuntu kernel: [ 39.614396] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076495800]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.623634] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494000]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.632873] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 08:27:57 tegra-ubuntu kernel: [ 39.639242] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 08:27:57 tegra-ubuntu kernel: [ 39.645648] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:57 tegra-ubuntu kernel: [ 39.651230] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:57 tegra-ubuntu kernel: [ 39.656947] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:57 tegra-ubuntu kernel: [ 39.663348] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:57 tegra-ubuntu kernel: [ 39.669200] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:57 tegra-ubuntu kernel: [ 39.676663] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494c00]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.686339] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494c00]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.692223] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496c00]
May 16 08:27:57 tegra-ubuntu kernel: [ 39.724836] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.759029] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495800]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.784217] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:58 tegra-ubuntu kernel: [ 39.790565] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.800050] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496000]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.809723] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 39.816196] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 39.822578] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 39.828399] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 39.834142] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:58 tegra-ubuntu kernel: [ 39.840458] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:58 tegra-ubuntu kernel: [ 39.846724] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:58 tegra-ubuntu kernel: [ 39.853956] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.863415] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494000]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.863422] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076495c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.896096] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.930553] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.960210] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:58 tegra-ubuntu kernel: [ 39.966370] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494000]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.966409] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:27:58 tegra-ubuntu kernel: [ 39.998972] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495800]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.008217] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.014584] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.020939] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.026518] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.032246] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:58 tegra-ubuntu kernel: [ 40.038344] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:58 tegra-ubuntu kernel: [ 40.044179] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:58 tegra-ubuntu kernel: [ 40.051067] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496000]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.060316] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496000]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.069553] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.101848] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494000]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.136245] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.156359] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:58 tegra-ubuntu kernel: [ 40.162388] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076495c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.171703] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.180949] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.187325] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.194489] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.200087] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.205798] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:58 tegra-ubuntu kernel: [ 40.211917] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:58 tegra-ubuntu kernel: [ 40.218311] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:58 tegra-ubuntu kernel: [ 40.225287] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.234731] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496400]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.238978] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495800]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.273255] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496000]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.307551] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.332353] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:58 tegra-ubuntu kernel: [ 40.338366] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076495800]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.341815] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494000]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.376120] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.385740] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.392122] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.399033] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.404945] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.410960] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:58 tegra-ubuntu kernel: [ 40.417323] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:58 tegra-ubuntu kernel: [ 40.427734] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:58 tegra-ubuntu kernel: [ 40.434947] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.445336] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.445396] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.478984] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495800]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.513256] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496000]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.540212] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:58 tegra-ubuntu kernel: [ 40.546235] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496400]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.547503] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.581936] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494000]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.591609] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.598064] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.604453] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.610233] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:58 tegra-ubuntu kernel: [ 40.615954] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:58 tegra-ubuntu kernel: [ 40.622145] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:58 tegra-ubuntu kernel: [ 40.632072] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:58 tegra-ubuntu kernel: [ 40.638981] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.648232] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.650399] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496c00]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.684729] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:27:58 tegra-ubuntu kernel: [ 40.718974] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495800]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.744179] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:59 tegra-ubuntu kernel: [ 40.750223] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.753241] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496000]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.787499] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.796961] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 40.803841] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 40.810279] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 40.815873] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 40.821589] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:59 tegra-ubuntu kernel: [ 40.827694] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:59 tegra-ubuntu kernel: [ 40.837472] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:59 tegra-ubuntu kernel: [ 40.844510] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494000]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.853857] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494000]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.856336] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.890515] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.924834] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.952182] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:59 tegra-ubuntu kernel: [ 40.958193] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 40.988713] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 08:27:59 tegra-ubuntu kernel: [ 40.995095] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 08:27:59 tegra-ubuntu kernel: [ 41.001463] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 41.007051] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 41.012762] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:59 tegra-ubuntu kernel: [ 41.018894] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:59 tegra-ubuntu kernel: [ 41.024748] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:59 tegra-ubuntu kernel: [ 41.031668] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495800]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.045078] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076495800]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.061991] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496000]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.118759] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.148226] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:59 tegra-ubuntu kernel: [ 41.154241] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496000]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.212030] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 08:27:59 tegra-ubuntu kernel: [ 41.218492] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 08:27:59 tegra-ubuntu kernel: [ 41.225444] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 41.231088] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 41.236820] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:59 tegra-ubuntu kernel: [ 41.243011] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:59 tegra-ubuntu kernel: [ 41.249374] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:59 tegra-ubuntu kernel: [ 41.256270] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494000]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.265537] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494000]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.267497] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.336325] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.364198] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:59 tegra-ubuntu kernel: [ 41.370363] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.404692] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.452202] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 08:27:59 tegra-ubuntu kernel: [ 41.460382] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 08:27:59 tegra-ubuntu kernel: [ 41.466804] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 41.472583] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 41.478400] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:59 tegra-ubuntu kernel: [ 41.488731] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:59 tegra-ubuntu kernel: [ 41.495126] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:59 tegra-ubuntu kernel: [ 41.502042] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495800]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.511282] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076495800]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.541869] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496000]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.576081] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495c00]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.628312] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:27:59 tegra-ubuntu kernel: [ 41.634683] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496000]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.654509] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 08:27:59 tegra-ubuntu kernel: [ 41.660887] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 08:27:59 tegra-ubuntu kernel: [ 41.667303] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 41.672918] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:27:59 tegra-ubuntu kernel: [ 41.678653] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:27:59 tegra-ubuntu kernel: [ 41.684790] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:27:59 tegra-ubuntu kernel: [ 41.690642] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:27:59 tegra-ubuntu kernel: [ 41.697539] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494000]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.706803] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494000]
May 16 08:27:59 tegra-ubuntu kernel: [ 41.716031] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494c00]
May 16 08:28:00 tegra-ubuntu kernel: [ 41.791823] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496c00]
May 16 08:28:00 tegra-ubuntu kernel: [ 41.804230] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:28:00 tegra-ubuntu kernel: [ 41.810451] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494c00]
May 16 08:28:00 tegra-ubuntu kernel: [ 41.816082] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:28:00 tegra-ubuntu kernel: [ 41.933691] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 08:28:00 tegra-ubuntu kernel: [ 41.940063] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 08:28:00 tegra-ubuntu kernel: [ 41.946851] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:28:00 tegra-ubuntu kernel: [ 41.952663] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:28:00 tegra-ubuntu kernel: [ 41.959417] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:28:00 tegra-ubuntu kernel: [ 41.967223] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:28:00 tegra-ubuntu kernel: [ 41.973728] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:28:00 tegra-ubuntu kernel: [ 41.980916] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495800]
May 16 08:28:00 tegra-ubuntu kernel: [ 41.990490] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076495800]
May 16 08:28:00 tegra-ubuntu kernel: [ 42.021977] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496000]
May 16 08:28:00 tegra-ubuntu kernel: [ 42.090392] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076495c00]
May 16 08:28:00 tegra-ubuntu kernel: [ 42.108187] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:28:00 tegra-ubuntu kernel: [ 42.114434] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496000]
May 16 08:28:00 tegra-ubuntu kernel: [ 42.124657] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494000]
May 16 08:28:00 tegra-ubuntu kernel: [ 42.231715] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
May 16 08:28:00 tegra-ubuntu kernel: [ 42.238423] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
May 16 08:28:00 tegra-ubuntu kernel: [ 42.244864] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
May 16 08:28:00 tegra-ubuntu kernel: [ 42.250914] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
May 16 08:28:00 tegra-ubuntu kernel: [ 42.256737] vi 54080000.vi: cil_settingtime is pulled from device
May 16 08:28:00 tegra-ubuntu kernel: [ 42.263032] vi 54080000.vi: cil_settingtime was autocalculated
May 16 08:28:00 tegra-ubuntu kernel: [ 42.269026] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
May 16 08:28:00 tegra-ubuntu kernel: [ 42.276466] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076494c00]
May 16 08:28:00 tegra-ubuntu kernel: [ 42.285774] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076494c00]
May 16 08:28:00 tegra-ubuntu kernel: [ 42.296096] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496c00]
May 16 08:28:00 tegra-ubuntu kernel: [ 42.383346] video4linux video0: tegra_channel_capture_frame: vi2 got SOF syncpt buf[ffffffc076496400]
May 16 08:28:00 tegra-ubuntu kernel: [ 42.392605] video4linux video0: MW_ACK_DONE syncpoint time out!0
May 16 08:28:00 tegra-ubuntu kernel: [ 42.399497] video4linux video0: tegra_channel_release_frame: vi2 got EOF syncpt buf[ffffffc076496c00]
May 16 08:28:01 tegra-ubuntu kernel: [ 43.427130] video4linux video0: tegra_channel_capture_done: no buffers in queue
May 16 08:28:01 tegra-ubuntu kernel: [ 43.434602] ar0237 30-0010: ar0237_s_stream++
May 16 08:28:01 tegra-ubuntu kernel: [ 43.439102] ar0237 30-0010: ar0237_s_stream mode[3]
May 16 08:28:01 tegra-ubuntu kernel: [ 43.448263] ar0237 30-0010: post ar0237_s_stream mode[3]
May 16 08:28:01 tegra-ubuntu kernel: [ 43.466023] ar0237 30-0010: ar0237_power_off: power off
Hi Shane,
I tried changing the image stream settings from our hardware but I’m still not getting any improvements.
Are there other things we can check?
I think you can try to fixed the short frame first.
Hi Shane,
We focused on fixing the short frame and we were finally able to solve this issue.
Thanks a lot for your help.
Hello 3dimi
We faced the same problem as you, could you kindly share some information of how you fixed this issue? PPA_SHORT_FRAME
Thanks ahead!
Hi yawei.yang,
We checked the total number of lines coming from the sensor at hardware level and it was giving fewer lines than our setting in the driver. We just configured the sensor and deserializer settings properly to output the correct number of lines.
Hi Shane,
Hello 3dimi
Thanks ahead!
Hi yawei.yang,
Thanks 3dimi for sharing the information.
