camera porting error.
Hello~
Sorry for not being good at English.
linux kernel 16.04 -> 18.04
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-322/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fcamera_sensor_prog.html
Changes to Device Tree Properties
Release 31 and later support both the I2C and SPI buses, as well as the CPHY and DPHY interfaces. To avoid confusion, make the following changes in the current sensor driver device tree files:
•Rename csi-port to port-index for VI and CSI endpoints.
•Add a new phy_mode property to each sensor mode. The value can be DPHY or CPHY, depending on the sensor type.
16.04 source -> !!! good working. !!!
dtb -> csi-port = <3>; /* Enable TX0 and TX1 */
device driver code -> property = of_get_property(node, “csi_port”, NULL);
18.04 source
hello kirabbitrwte9
I believe this should be ubuntu version, you should check linux kernel version with $ uname -a
BTW, had you check Camera Sensor Drivers Porting Guide for driver porting guidance.
please also share the kernel message about the failures. $ dmesg
thanks
