I used xaiver to connect a camera with 1920x1280 resolution and 30fps. The mipi signal looks normal but there is no image when previewing the camera. So here’s the trace log.
When I change pixelformat I get a chansel_nomatch error, so pixelformat should be correct, but no matter how I change width, height, the error is the same.
may I know what’s the sensor format dumps… $ v4l2-ctl -d /dev/video0 --list-formats-ext
you should assign the exactly sensor support formats to the pipeline.
