Camera-rtcpu-t234-rce.img debug firmware for ORIN NX l4t-r36.4.3 needed
Hi, I encountered a problem while debugging MIPI cameras for Orin NX l4t-r36.4.3. When connecting 4 GMSL cameras, the screen will flicker, but when connecting any 3 cameras, the screen will be normal; Suspected that MIPI’s DPHY rate is locked at 1500M. Could you provide a debug version of rtcpu and the flashing method?
Boost the clocks to try. If that help to review the device tree like pix_clk_hz num-channels ..
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
Thanks for your replay.Issue resolved: Changed the MIPI DPHY Rate to 2000M and changed a better mipi FPC.
