Board
: AGX Orin
L4T
: 36.4.0
Hello, I have an issue, where the camera start of frame timestamp is in the future.
First, I get the camera SOF timestamp like so:
IArgusCaptureMetadata *iArgusCaptureMetadata =
interface_cast<IArgusCaptureMetadata>(frame);
CaptureMetadata *metadata = iArgusCaptureMetadata->getMetadata();
const Ext::ISensorTimestampTsc *iSensorTimestampTsc =
interface_cast<const Ext::ISensorTimestampTsc>(metadata);
uint64_t SENSOR_SOF_WITH_OFFSET = iSensorTimestampTsc->getSensorSofTimestampTsc()
Then I get the TSC offset like so:
(From: How to get the clock source offset_ns on Jetpack 6 - #4 by ShaneCCC)
uint64_t getTscOffsetNs() {
unsigned long raw_nsec, tsc_ns;
unsigned long cycles, frq;
struct timespec tp;
asm volatile("mrs %0, cntfrq_el0" : "=r"(frq));
asm volatile("mrs %0, cntvct_el0" : "=r"(cycles));
clock_gettime(CLOCK_MONOTONIC_RAW, &tp);
tsc_ns = (cycles / frq) * 1000000000;
raw_nsec = tp.tv_sec * 1000000000 + tp.tv_nsec;
uint64_t offset_ns = llabs(tsc_ns-raw_nsec);
return offset_ns;
Then I get the CLOCK_MONOTONIC_RAW
& CLOCK_REALTIME
and timestamps in ns:
timespec t0;
clock_gettime(CLOCK_MONOTONIC_RAW, &t0);
uint64_t CLOCK_MONOTONIC_RAW = t0.tv_sec * 1e9l + t0.tv_nsec;
timespec t1;
clock_gettime(CLOCK_REALTIME, &t1);
uint64_t CLOCK_REALTIME = t1.tv_sec * 1e9l + t1.tv_nsec;
Here are example values I got once:
Name | Value |
TSC_OFFSET |
21000334912 |
SENSOR_SOF_WITH_OFFSET |
996834000000 |
CLOCK_MONOTONIC_RAW |
974999629152 |
CLOCK_REALTIME |
1743608425941978927 |
I can then calculate the sensor SOF timestamp without offset:
SENSOR_SOF_MONO_RAW = SENSOR_SOF_WITH_OFFSET - TSC_OFFSET
= 996834000000 - 21000334912
= 975833665088
But there’s a big problem now. The sensor SOF timestamp without the offset is bigger than the current time in CLOCK_MONOTONIC_RAW clock !
What is the issue? thanks!
