We were experiencing a camera streaming stability issue when running 7 cameras streaming simultaneously. This is happening in every several hours. Notice that we have already boosted by running sudo jetson_clocks
. The following are the detailed logs:
SCF: Error InvalidState: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 593)
SCF: Error InvalidState: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error InvalidState: Worker thread ViCsiHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function startCaptureInternal(), line 809)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function doCSItoMemCapture(), line 530)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 477)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1291)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1122)
SCF: Error ResourceAlreadyInUse: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error ResourceAlreadyInUse: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
[Thread 0xfffe11f9f900 (LWP 2135888) exited]
[Thread 0xfffe19f9f900 (LWP 2135881) exited]
[ARGUS] camera 0 had error[STATUS_CANCELLED]
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 643)
SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 373)
SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 906)
SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 395)
SCF: Error InvalidState: (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequest(), line 137)
SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error InvalidState: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 979)
SCF: Error InvalidState: (propagating from src/components/stages/SensorCaptureStage.cpp, function doHandleRequest(), line 86)
[ARGUS] camera 4 had error[STATUS_UNAVAILABLE]
[ARGUS] camera 2 had error[STATUS_UNAVAILABLE]
[ARGUS] camera 6 had error[STATUS_UNAVAILABLE]
[ARGUS] camera 7 had error[STATUS_UNAVAILABLE]
[ARGUS] camera 5 had error[STATUS_UNAVAILABLE]
[ARGUS] camera 1 had error[STATUS_UNAVAILABLE]
version info:
NVIDIA Jetson AGX Orin
L4T 35.1.0 [ JetPack 5.0.2 ]
Ubuntu 20.04.4 LTS
Kernel Version: 5.10.104-tegra
CUDA 11.4.239
CUDA Architecture: NONE
OpenCV version: 4.5.4
OpenCV Cuda: NO
CUDNN: 8.4.1.50
TensorRT: 8.4.1.5
Vision Works: NOT_INSTALLED
VPI: 2.1.6
Vulcan: 1.3.203
