Camera streams first two seconds
when i test gstreamer, camera streams first two seconds.
after that time, time out occurs.
and when I retry, it never stream on before reboot.
camera works well under Chpy, 3 lanes, 800Msps, 3840X2160.
Environment.
L4T 35.5.0
Camera: Chpy, 3 lanes, 1.6Gsps, 8064x6016
test command
gst-launch-1.0 -v --gst-debug-level=3 nvarguscamerasrc sensor-id=0 !  capsfilter caps="video/x-raw(memory:NVMM), width=(int)8064, height=(int)6016, format=(string)NV12, framerate=(fraction)15/1" ! queue ! nv3dsink
trace log
# tracer: nop
# entries-in-buffer/entries-written: 5696/5696   #P:12
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
     kworker/2:2-155     [002] ....    74.453483: rtcpu_string: tstamp:3085815998 id:0x04010000 str:"VM0 deactivating."
 gst-plugin-scan-2914    [003] ....    78.440456: tegra_channel_open: vi-output, imx858 2-001a
 gst-plugin-scan-2914    [003] ....    78.440473: tegra_channel_close: vi-output, imx858 2-001a
     kworker/2:2-155     [002] ....    78.665467: rtcpu_string: tstamp:3216813152 id:0x04010000 str:"VM0 activating."
  nvargus-daemon-2916    [010] ....    78.751345: tegra_channel_open: vi-output, imx858 2-001a
  nvargus-daemon-2916    [010] ....    78.751402: tegra_channel_close: vi-output, imx858 2-001a
  nvargus-daemon-2916    [010] ....    78.752056: tegra_channel_open: vi-output, imx858 2-001a
  nvargus-daemon-2916    [010] ....    78.752083: tegra_channel_close: vi-output, imx858 2-001a
  nvargus-daemon-2916    [005] ....    78.774954: tegra_channel_open: vi-output, imx858 2-001a
  nvargus-daemon-2916    [005] ....    78.774969: tegra_channel_close: vi-output, imx858 2-001a
  nvargus-daemon-2916    [005] ....    78.774978: tegra_channel_open: vi-output, imx858 2-001a
  nvargus-daemon-2916    [005] ....    78.775014: tegra_channel_close: vi-output, imx858 2-001a
  nvargus-daemon-2916    [005] ....    78.775029: tegra_channel_open: vi-output, imx858 2-001a
  nvargus-daemon-2916    [005] ....    78.775083: tegra_channel_close: vi-output, imx858 2-001a
 CaptureSchedule-2932    [009] ....    79.261757: tegra_channel_open: vi-output, imx858 2-001a
 CaptureSchedule-2932    [009] ....    79.261922: tegra_channel_set_power: imx858 2-001a : 0x1
 CaptureSchedule-2932    [009] ....    79.261925: camera_common_s_power: status : 0x1
 CaptureSchedule-2932    [009] ....    79.279622: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
 CaptureSchedule-2932    [009] ....    79.279624: csi_s_power: enable : 0x1
 CaptureSchedule-2932    [009] ....    79.280249: tegra_channel_set_stream: enable : 0x1
 CaptureSchedule-2932    [009] ....    79.292524: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
 CaptureSchedule-2932    [009] ....    79.292526: csi_s_stream: enable : 0x1
 CaptureSchedule-2932    [009] ....    79.292526: tegra_channel_set_stream: imx858 2-001a : 0x1
     kworker/2:2-155     [002] ....    79.409483: rtcpu_nvcsi_intr: tstamp:3241085390 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x60000000
     kworker/2:2-155     [002] ....    79.409487: rtcpu_nvcsi_intr: tstamp:3241085390 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x20000000
     kworker/2:2-155     [002] ....    79.469464: rtcpu_vinotify_error: tstamp:3242435263 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:103757869440 data:0x0000000000000001
     kworker/2:2-155     [002] ....    79.469466: rtcpu_vinotify_event: tstamp:3242449068 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:103757869440 data:0x0000000000000001
     kworker/2:2-155     [002] ....    79.469466: rtcpu_vinotify_event: tstamp:3242449205 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103757937536 data:0x359cc80010000000
     kworker/2:2-155     [002] ....    79.469466: rtcpu_vinotify_event: tstamp:3242449358 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103757953632 data:0x0000000031000001
     kworker/2:2-155     [002] ....    79.469467: rtcpu_vinotify_event: tstamp:3243200236 cch:1 vi:0 tag:FS channel:0x00 frame:2 vi_tstamp:103780468576 data:0x0000000200000010
     kworker/2:2-155     [002] ....    79.469467: rtcpu_vinotify_event: tstamp:3243200390 cch:1 vi:0 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:103780468608 data:0x0000000000000800
     kworker/2:2-155     [002] ....    79.469467: rtcpu_vinotify_event: tstamp:3243200522 cch:1 vi:0 tag:CHANSEL_EMBED_SOF channel:0x0b frame:2 vi_tstamp:103780469248 data:0x0000000000000004
     kworker/2:2-155     [002] ....    79.469468: rtcpu_vinotify_event: tstamp:3243200673 cch:1 vi:0 tag:CHANSEL_EMBED_EOF channel:0x0b frame:2 vi_tstamp:103780486208 data:0x0000000000010008
     kworker/2:2-155     [002] ....    79.469468: rtcpu_vinotify_event: tstamp:3243200805 cch:1 vi:0 tag:ATOMP_EMB_DATA_DONE channel:0x0b frame:2 vi_tstamp:103780486880 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.469469: rtcpu_vinotify_event: tstamp:3243200954 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103780493536 data:0x0000000003020001
     kworker/2:2-155     [002] ....    79.469469: rtcpu_vinotify_event: tstamp:3243201084 cch:1 vi:0 tag:CHANSEL_PXL_SOF channel:0x0b frame:2 vi_tstamp:103781307520 data:0x0000000000000001
     kworker/2:2-155     [002] ....    79.469469: rtcpu_vinotify_event: tstamp:3243201230 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103781311264 data:0x0000000008020001
     kworker/2:2-155     [002] ....    79.525480: rtcpu_vinotify_event: tstamp:3243575845 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103786788992 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.525482: rtcpu_vinotify_event: tstamp:3243576010 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103786792512 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.525483: rtcpu_vinotify_event: tstamp:3243576141 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103792272736 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.525483: rtcpu_vinotify_event: tstamp:3243576290 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103792276288 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.525484: rtcpu_vinotify_event: tstamp:3243681035 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103797746144 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.525484: rtcpu_vinotify_event: tstamp:3244026636 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103797752544 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.525485: rtcpu_vinotify_event: tstamp:3244026767 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103803219648 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.525485: rtcpu_vinotify_event: tstamp:3244026918 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103803223232 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.525485: rtcpu_vinotify_event: tstamp:3244027047 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103808703520 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.525486: rtcpu_vinotify_event: tstamp:3244027198 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103808707264 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.525486: rtcpu_vinotify_event: tstamp:3244402252 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103814187200 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.525487: rtcpu_vinotify_event: tstamp:3244402403 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103814190752 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.525487: rtcpu_vinotify_event: tstamp:3244402536 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103819670944 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.525487: rtcpu_vinotify_event: tstamp:3244402685 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103819674496 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.525488: rtcpu_vinotify_event: tstamp:3244777654 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103825144512 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.525488: rtcpu_vinotify_event: tstamp:3244777811 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103825148032 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.525488: rtcpu_vinotify_event: tstamp:3244777943 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103829465312 data:0x359cc50010000000
     kworker/2:2-155     [002] ....    79.525489: rtcpu_vinotify_event: tstamp:3244778096 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103829481632 data:0x0000000031000002
     kworker/2:2-155     [002] ....    79.525489: rtcpu_vinotify_event: tstamp:3244778227 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103830628128 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.525490: rtcpu_vinotify_event: tstamp:3244778375 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103830631680 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.525490: rtcpu_vinotify_event: tstamp:3244879652 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103836101728 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581479: rtcpu_vinotify_event: tstamp:3245228568 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103836108128 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.581481: rtcpu_vinotify_event: tstamp:3245228711 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:2 vi_tstamp:103841575136 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581481: rtcpu_vinotify_event: tstamp:3245228865 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103841578688 data:0x0000000002020001
     kworker/2:2-155     [002] ....    79.581482: rtcpu_vinotify_event: tstamp:3245229000 cch:1 vi:0 tag:FE channel:0x00 frame:2 vi_tstamp:103842971136 data:0x0000000200000020
     kworker/2:2-155     [002] ....    79.581483: rtcpu_vinotify_event: tstamp:3245229153 cch:1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:2 vi_tstamp:103842971136 data:0x177a000001000800
     kworker/2:2-155     [002] ....    79.581483: rtcpu_vinotify_event: tstamp:3245229287 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:2 vi_tstamp:103842990560 data:0x0000000001020001
     kworker/2:2-155     [002] ....    79.581484: rtcpu_vinotify_event: tstamp:3245229442 cch:1 vi:0 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:103842971168 data:0x0000000000000800
     kworker/2:2-155     [002] ....    79.581485: rtcpu_vinotify_event: tstamp:3245229577 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103843106080 data:0x359cc80010000000
     kworker/2:2-155     [002] ....    79.581485: rtcpu_vinotify_event: tstamp:3245229730 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103843122432 data:0x0000000031000003
     kworker/2:2-155     [002] ....    79.581486: rtcpu_vinotify_event: tstamp:3245229859 cch:1 vi:0 tag:FS channel:0x00 frame:3 vi_tstamp:103847134592 data:0x0000000300000010
     kworker/2:2-155     [002] ....    79.581486: rtcpu_vinotify_event: tstamp:3245230014 cch:1 vi:0 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:103847134624 data:0x0000000000000800
     kworker/2:2-155     [002] ....    79.581487: rtcpu_vinotify_event: tstamp:3245230146 cch:1 vi:0 tag:CHANSEL_EMBED_SOF channel:0x0b frame:3 vi_tstamp:103847135264 data:0x0000000000000004
     kworker/2:2-155     [002] ....    79.581488: rtcpu_vinotify_event: tstamp:3245230299 cch:1 vi:0 tag:CHANSEL_EMBED_EOF channel:0x0b frame:3 vi_tstamp:103847152192 data:0x0000000000010008
     kworker/2:2-155     [002] ....    79.581488: rtcpu_vinotify_event: tstamp:3245230433 cch:1 vi:0 tag:ATOMP_EMB_DATA_DONE channel:0x0b frame:3 vi_tstamp:103847152864 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581489: rtcpu_vinotify_event: tstamp:3245230583 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103847159520 data:0x0000000003020002
     kworker/2:2-155     [002] ....    79.581490: rtcpu_vinotify_event: tstamp:3245251731 cch:1 vi:0 tag:CHANSEL_PXL_SOF channel:0x0b frame:3 vi_tstamp:103847973504 data:0x0000000000000001
     kworker/2:2-155     [002] ....    79.581491: rtcpu_vinotify_event: tstamp:3245604236 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103847980128 data:0x0000000008020002
     kworker/2:2-155     [002] ....    79.581492: rtcpu_vinotify_event: tstamp:3245604368 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103853454976 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581492: rtcpu_vinotify_event: tstamp:3245604520 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103853458528 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.581493: rtcpu_vinotify_event: tstamp:3245604648 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103858938752 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581494: rtcpu_vinotify_event: tstamp:3245604796 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103858942304 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.581494: rtcpu_vinotify_event: tstamp:3245979567 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103864432640 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581495: rtcpu_vinotify_event: tstamp:3245979730 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103864436192 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.581495: rtcpu_vinotify_event: tstamp:3245979861 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103869906176 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581496: rtcpu_vinotify_event: tstamp:3245980009 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103869909728 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.581497: rtcpu_vinotify_event: tstamp:3246355286 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103875379680 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581497: rtcpu_vinotify_event: tstamp:3246355437 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103875383264 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.581498: rtcpu_vinotify_event: tstamp:3246355565 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103880863520 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581499: rtcpu_vinotify_event: tstamp:3246355713 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103880867104 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.581499: rtcpu_vinotify_event: tstamp:3246620865 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103886347136 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.581500: rtcpu_vinotify_event: tstamp:3246621016 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103886350688 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.581501: rtcpu_vinotify_event: tstamp:3246621146 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103891820672 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637476: rtcpu_vinotify_event: tstamp:3246993829 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103891827072 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.637478: rtcpu_vinotify_event: tstamp:3246993961 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103897294144 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637479: rtcpu_vinotify_event: tstamp:3246994114 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103897297696 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.637479: rtcpu_vinotify_event: tstamp:3246994248 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103902778048 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637480: rtcpu_vinotify_event: tstamp:3246994398 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103902781600 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.637480: rtcpu_vinotify_event: tstamp:3247308388 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:3 vi_tstamp:103908251488 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637481: rtcpu_vinotify_event: tstamp:3247308544 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103908255040 data:0x0000000002020002
     kworker/2:2-155     [002] ....    79.637482: rtcpu_vinotify_event: tstamp:3247308680 cch:1 vi:0 tag:FE channel:0x00 frame:3 vi_tstamp:103909637120 data:0x0000000300000020
     kworker/2:2-155     [002] ....    79.637484: rtcpu_vinotify_event: tstamp:3247308832 cch:1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:3 vi_tstamp:103909637120 data:0x1779000001000800
     kworker/2:2-155     [002] ....    79.637485: rtcpu_vinotify_event: tstamp:3247308965 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:3 vi_tstamp:103909656544 data:0x0000000001020002
     kworker/2:2-155     [002] ....    79.637486: rtcpu_vinotify_event: tstamp:3247309118 cch:1 vi:0 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:103909637152 data:0x0000000000000800
     kworker/2:2-155     [002] ....    79.637486: rtcpu_vinotify_event: tstamp:3247309249 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103909778688 data:0x359cc50010000000
     kworker/2:2-155     [002] ....    79.637487: rtcpu_vinotify_event: tstamp:3247309398 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103909795040 data:0x0000000031000004
     kworker/2:2-155     [002] ....    79.637487: rtcpu_vinotify_event: tstamp:3247309528 cch:1 vi:0 tag:FS channel:0x00 frame:4 vi_tstamp:103913800608 data:0x0000000400000010
     kworker/2:2-155     [002] ....    79.637488: rtcpu_vinotify_event: tstamp:3247309682 cch:1 vi:0 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:103913800608 data:0x0000000000000800
     kworker/2:2-155     [002] ....    79.637488: rtcpu_vinotify_event: tstamp:3247309813 cch:1 vi:0 tag:CHANSEL_EMBED_SOF channel:0x0b frame:4 vi_tstamp:103913801248 data:0x0000000000000004
     kworker/2:2-155     [002] ....    79.637490: rtcpu_vinotify_event: tstamp:3247669813 cch:1 vi:0 tag:CHANSEL_EMBED_EOF channel:0x0b frame:4 vi_tstamp:103913818208 data:0x0000000000010008
     kworker/2:2-155     [002] ....    79.637490: rtcpu_vinotify_event: tstamp:3247669948 cch:1 vi:0 tag:ATOMP_EMB_DATA_DONE channel:0x0b frame:4 vi_tstamp:103913818848 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637491: rtcpu_vinotify_event: tstamp:3247670100 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103913830272 data:0x0000000003020003
     kworker/2:2-155     [002] ....    79.637491: rtcpu_vinotify_event: tstamp:3247670232 cch:1 vi:0 tag:CHANSEL_PXL_SOF channel:0x0b frame:4 vi_tstamp:103914639488 data:0x0000000000000001
     kworker/2:2-155     [002] ....    79.637491: rtcpu_vinotify_event: tstamp:3247670382 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103914643296 data:0x0000000008020003
     kworker/2:2-155     [002] ....    79.637492: rtcpu_vinotify_event: tstamp:3247670515 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103920120960 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637493: rtcpu_vinotify_event: tstamp:3247670666 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103920124512 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.637493: rtcpu_vinotify_event: tstamp:3248045459 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103925594592 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637494: rtcpu_vinotify_event: tstamp:3248045609 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103925598112 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.637494: rtcpu_vinotify_event: tstamp:3248045739 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103931068000 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637494: rtcpu_vinotify_event: tstamp:3248045888 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103931071552 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.637495: rtcpu_vinotify_event: tstamp:3248046016 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103936561984 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637495: rtcpu_vinotify_event: tstamp:3248046164 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103936565536 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.637496: rtcpu_vinotify_event: tstamp:3248361444 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103942045664 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.637496: rtcpu_vinotify_event: tstamp:3248361596 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103942049216 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.637497: rtcpu_vinotify_event: tstamp:3248361727 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103947519168 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693510: rtcpu_vinotify_event: tstamp:3248721491 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103947525600 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.693513: rtcpu_vinotify_event: tstamp:3248721630 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103953002976 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693513: rtcpu_vinotify_event: tstamp:3248721785 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103953006528 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.693514: rtcpu_vinotify_event: tstamp:3248721920 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103958476512 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693514: rtcpu_vinotify_event: tstamp:3248722075 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103958480064 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.693514: rtcpu_vinotify_event: tstamp:3249097213 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103963949952 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693515: rtcpu_vinotify_event: tstamp:3249097370 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103963953536 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.693515: rtcpu_vinotify_event: tstamp:3249097505 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103969423552 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693516: rtcpu_vinotify_event: tstamp:3249097658 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103969427104 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.693516: rtcpu_vinotify_event: tstamp:3249264753 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:4 vi_tstamp:103974907136 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693516: rtcpu_vinotify_event: tstamp:3249264910 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103974910688 data:0x0000000002020003
     kworker/2:2-155     [002] ....    79.693516: rtcpu_vinotify_event: tstamp:3249265044 cch:1 vi:0 tag:FE channel:0x00 frame:4 vi_tstamp:103976303104 data:0x0000000400000020
     kworker/2:2-155     [002] ....    79.693517: rtcpu_vinotify_event: tstamp:3249265197 cch:1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:4 vi_tstamp:103976303104 data:0x177a000001000800
     kworker/2:2-155     [002] ....    79.693517: rtcpu_vinotify_event: tstamp:3249265333 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:4 vi_tstamp:103976322528 data:0x0000000001020003
     kworker/2:2-155     [002] ....    79.693518: rtcpu_vinotify_event: tstamp:3249265490 cch:1 vi:0 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:103976303136 data:0x0000000000000800
     kworker/2:2-155     [002] ....    79.693518: rtcpu_vinotify_event: tstamp:3249265625 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103976431232 data:0x359cc80010000000
     kworker/2:2-155     [002] ....    79.693519: rtcpu_vinotify_event: tstamp:3249623243 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:103976488576 data:0x0000000031000005
     kworker/2:2-155     [002] ....    79.693519: rtcpu_vinotify_event: tstamp:3249623375 cch:1 vi:0 tag:FS channel:0x00 frame:5 vi_tstamp:103980466592 data:0x0000000500000010
     kworker/2:2-155     [002] ....    79.693519: rtcpu_vinotify_event: tstamp:3249623533 cch:1 vi:0 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:103980466624 data:0x0000000000000800
     kworker/2:2-155     [002] ....    79.693520: rtcpu_vinotify_event: tstamp:3249623666 cch:1 vi:0 tag:CHANSEL_EMBED_SOF channel:0x0b frame:5 vi_tstamp:103980467232 data:0x0000000000000004
     kworker/2:2-155     [002] ....    79.693520: rtcpu_vinotify_event: tstamp:3249623821 cch:1 vi:0 tag:CHANSEL_EMBED_EOF channel:0x0b frame:5 vi_tstamp:103980484224 data:0x0000000000010008
     kworker/2:2-155     [002] ....    79.693520: rtcpu_vinotify_event: tstamp:3249623952 cch:1 vi:0 tag:ATOMP_EMB_DATA_DONE channel:0x0b frame:5 vi_tstamp:103980484864 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693520: rtcpu_vinotify_event: tstamp:3249624106 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:5 vi_tstamp:103980491520 data:0x0000000003020004
     kworker/2:2-155     [002] ....    79.693521: rtcpu_vinotify_event: tstamp:3249624237 cch:1 vi:0 tag:CHANSEL_PXL_SOF channel:0x0b frame:5 vi_tstamp:103981305504 data:0x0000000000000001
     kworker/2:2-155     [002] ....    79.693521: rtcpu_vinotify_event: tstamp:3249624389 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:5 vi_tstamp:103981309280 data:0x0000000008020004
     kworker/2:2-155     [002] ....    79.693521: rtcpu_vinotify_event: tstamp:3249624520 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:5 vi_tstamp:103986797120 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693522: rtcpu_vinotify_event: tstamp:3249624669 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:5 vi_tstamp:103986800704 data:0x0000000002020004
     kworker/2:2-155     [002] ....    79.693523: rtcpu_isp_falcon_task_start: tstamp:3249891867 ch:0 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    79.693525: rtcpu_isp_falcon_task_end: tstamp:3249891883 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    79.693526: rtcpu_isp_falcon_task_start: tstamp:3249891901 ch:0 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    79.693526: rtcpu_isp_falcon_task_end: tstamp:3249891914 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    79.693526: rtcpu_isp_falcon_task_start: tstamp:3249891932 ch:0 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    79.693526: rtcpu_isp_falcon_task_end: tstamp:3249891946 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    79.693527: rtcpu_isp_falcon_task_start: tstamp:3249891964 ch:0 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    79.693527: rtcpu_isp_falcon_task_end: tstamp:3249891990 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    79.693528: rtcpu_isp_falcon: tag:0xa tstamp:3249892042 ch:0 seq:0 data:0x10000000 ext_data:0x3427f000
     kworker/2:2-155     [002] ....    79.693529: rtcpu_isp_falcon: tag:0xa tstamp:3249892199 ch:0 seq:1 data:0x21000001 ext_data:0x34286c80
     kworker/2:2-155     [002] ....    79.693529: rtcpu_isp_falcon: tag:0xa tstamp:3249892378 ch:0 seq:1 data:0x32000001 ext_data:0x00000000
     kworker/2:2-155     [002] ....    79.693530: rtcpu_isp_falcon_tile_start: tstamp:3249892549 ch:0 seq:1 tile_x:0 tile_y:0 tile_w:894 tile_h:534
     kworker/2:2-155     [002] ....    79.693531: rtcpu_isp_falcon_tile_end: tstamp:3249900560 ch:0 seq:1 tile_x:0 tile_y:0
     kworker/2:2-155     [002] ....    79.693531: rtcpu_isp_falcon_task_start: tstamp:3249900575 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693532: rtcpu_isp_falcon_tile_start: tstamp:3249900654 ch:0 seq:1 tile_x:1 tile_y:0 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693532: rtcpu_isp_falcon_task_end: tstamp:3249900668 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693532: rtcpu_isp_falcon_tile_end: tstamp:3249908642 ch:0 seq:1 tile_x:1 tile_y:0
     kworker/2:2-155     [002] ....    79.693533: rtcpu_isp_falcon_task_start: tstamp:3249908657 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693533: rtcpu_isp_falcon_tile_start: tstamp:3249908737 ch:0 seq:1 tile_x:2 tile_y:0 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693533: rtcpu_isp_falcon_task_end: tstamp:3249908750 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693534: rtcpu_isp_falcon_tile_end: tstamp:3249916731 ch:0 seq:1 tile_x:2 tile_y:0
     kworker/2:2-155     [002] ....    79.693534: rtcpu_isp_falcon_task_start: tstamp:3249916745 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693534: rtcpu_isp_falcon_tile_start: tstamp:3249916825 ch:0 seq:1 tile_x:3 tile_y:0 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693534: rtcpu_isp_falcon_task_end: tstamp:3249916838 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693535: rtcpu_isp_falcon_tile_end: tstamp:3249924809 ch:0 seq:1 tile_x:3 tile_y:0
     kworker/2:2-155     [002] ....    79.693535: rtcpu_isp_falcon_task_start: tstamp:3249924823 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693535: rtcpu_isp_falcon_tile_start: tstamp:3249924903 ch:0 seq:1 tile_x:4 tile_y:0 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693536: rtcpu_isp_falcon_task_end: tstamp:3249924916 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693536: rtcpu_isp_falcon_tile_end: tstamp:3249932890 ch:0 seq:1 tile_x:4 tile_y:0
     kworker/2:2-155     [002] ....    79.693536: rtcpu_isp_falcon_task_start: tstamp:3249932906 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693536: rtcpu_isp_falcon_tile_start: tstamp:3249932985 ch:0 seq:1 tile_x:5 tile_y:0 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693537: rtcpu_isp_falcon_task_end: tstamp:3249932998 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693537: rtcpu_isp_falcon_tile_end: tstamp:3249940972 ch:0 seq:1 tile_x:5 tile_y:0
     kworker/2:2-155     [002] ....    79.693537: rtcpu_isp_falcon_task_start: tstamp:3249940988 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693538: rtcpu_isp_falcon_tile_start: tstamp:3249941067 ch:0 seq:1 tile_x:6 tile_y:0 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693538: rtcpu_isp_falcon_task_end: tstamp:3249941080 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693538: rtcpu_isp_falcon_tile_end: tstamp:3249949050 ch:0 seq:1 tile_x:6 tile_y:0
     kworker/2:2-155     [002] ....    79.693539: rtcpu_isp_falcon_task_start: tstamp:3249949066 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693539: rtcpu_isp_falcon_tile_start: tstamp:3249949144 ch:0 seq:1 tile_x:7 tile_y:0 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693539: rtcpu_isp_falcon_task_end: tstamp:3249949158 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693539: rtcpu_isp_falcon_tile_end: tstamp:3249957131 ch:0 seq:1 tile_x:7 tile_y:0
     kworker/2:2-155     [002] ....    79.693540: rtcpu_isp_falcon_task_start: tstamp:3249957147 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693540: rtcpu_isp_falcon_tile_start: tstamp:3249957226 ch:0 seq:1 tile_x:8 tile_y:0 tile_w:898 tile_h:534
     kworker/2:2-155     [002] ....    79.693540: rtcpu_isp_falcon_task_end: tstamp:3249957239 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693541: rtcpu_isp_falcon_tile_end: tstamp:3249965099 ch:0 seq:1 tile_x:8 tile_y:0
     kworker/2:2-155     [002] ....    79.693541: rtcpu_isp_falcon_task_start: tstamp:3249965114 ch:0 task:SCHED_FINISH_SLICE
     kworker/2:2-155     [002] ....    79.693541: rtcpu_isp_falcon_tile_start: tstamp:3249965305 ch:0 seq:1 tile_x:0 tile_y:1 tile_w:894 tile_h:534
     kworker/2:2-155     [002] ....    79.693541: rtcpu_isp_falcon_task_end: tstamp:3249965318 task:SCHED_FINISH_SLICE
     kworker/2:2-155     [002] ....    79.693542: rtcpu_isp_falcon_tile_end: tstamp:3249973400 ch:0 seq:1 tile_x:0 tile_y:1
     kworker/2:2-155     [002] ....    79.693542: rtcpu_isp_falcon_task_start: tstamp:3249973415 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693542: rtcpu_isp_falcon_tile_start: tstamp:3249973502 ch:0 seq:1 tile_x:1 tile_y:1 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693542: rtcpu_isp_falcon_task_end: tstamp:3249973515 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693543: rtcpu_isp_falcon_tile_end: tstamp:3249981734 ch:0 seq:1 tile_x:1 tile_y:1
     kworker/2:2-155     [002] ....    79.693543: rtcpu_isp_falcon_task_start: tstamp:3249981749 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693543: rtcpu_isp_falcon_tile_start: tstamp:3249981836 ch:0 seq:1 tile_x:2 tile_y:1 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693544: rtcpu_isp_falcon_task_end: tstamp:3249981850 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693544: rtcpu_isp_falcon_task_start: tstamp:3249989560 ch:0 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    79.693544: rtcpu_isp_falcon_task_end: tstamp:3249989694 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    79.693545: rtcpu_isp_falcon_tile_end: tstamp:3249990074 ch:0 seq:1 tile_x:2 tile_y:1
     kworker/2:2-155     [002] ....    79.693546: rtcpu_isp_falcon_task_start: tstamp:3249990089 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693547: rtcpu_isp_falcon_tile_start: tstamp:3249990176 ch:0 seq:1 tile_x:3 tile_y:1 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693547: rtcpu_isp_falcon_task_end: tstamp:3249990189 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693547: rtcpu_isp_falcon_tile_end: tstamp:3249998411 ch:0 seq:1 tile_x:3 tile_y:1
     kworker/2:2-155     [002] ....    79.693548: rtcpu_isp_falcon_task_start: tstamp:3249998427 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693548: rtcpu_vinotify_event: tstamp:3250000722 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:5 vi_tstamp:103992281024 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693548: rtcpu_vinotify_event: tstamp:3250000878 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:5 vi_tstamp:103992284576 data:0x0000000002020004
     kworker/2:2-155     [002] ....    79.693549: rtcpu_vinotify_event: tstamp:3250001011 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:5 vi_tstamp:103997754432 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693549: rtcpu_vinotify_event: tstamp:3250001164 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:5 vi_tstamp:103997757984 data:0x0000000002020004
     kworker/2:2-155     [002] ....    79.693549: rtcpu_isp_falcon_tile_start: tstamp:3249998554 ch:0 seq:1 tile_x:4 tile_y:1 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693550: rtcpu_isp_falcon_task_end: tstamp:3249998602 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693550: rtcpu_isp_falcon_task_start: tstamp:3250006278 ch:0 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    79.693550: rtcpu_isp_falcon_task_end: tstamp:3250006413 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    79.693551: rtcpu_isp_falcon_tile_end: tstamp:3250006789 ch:0 seq:1 tile_x:4 tile_y:1
     kworker/2:2-155     [002] ....    79.693551: rtcpu_isp_falcon_task_start: tstamp:3250006804 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693551: rtcpu_isp_falcon_tile_start: tstamp:3250006891 ch:0 seq:1 tile_x:5 tile_y:1 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693552: rtcpu_isp_falcon_task_end: tstamp:3250006904 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693552: rtcpu_isp_falcon_tile_end: tstamp:3250015127 ch:0 seq:1 tile_x:5 tile_y:1
     kworker/2:2-155     [002] ....    79.693552: rtcpu_isp_falcon_task_start: tstamp:3250015141 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693552: rtcpu_isp_falcon_tile_start: tstamp:3250015229 ch:0 seq:1 tile_x:6 tile_y:1 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693553: rtcpu_isp_falcon_task_end: tstamp:3250015242 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693553: rtcpu_isp_falcon_tile_end: tstamp:3250023462 ch:0 seq:1 tile_x:6 tile_y:1
     kworker/2:2-155     [002] ....    79.693553: rtcpu_isp_falcon_task_start: tstamp:3250023476 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693554: rtcpu_isp_falcon_tile_start: tstamp:3250023564 ch:0 seq:1 tile_x:7 tile_y:1 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693554: rtcpu_isp_falcon_task_end: tstamp:3250023578 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693554: rtcpu_isp_falcon_tile_end: tstamp:3250031797 ch:0 seq:1 tile_x:7 tile_y:1
     kworker/2:2-155     [002] ....    79.693554: rtcpu_isp_falcon_task_start: tstamp:3250031812 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693555: rtcpu_isp_falcon_tile_start: tstamp:3250031900 ch:0 seq:1 tile_x:8 tile_y:1 tile_w:898 tile_h:534
     kworker/2:2-155     [002] ....    79.693555: rtcpu_isp_falcon_task_end: tstamp:3250031913 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693555: rtcpu_isp_falcon_tile_end: tstamp:3250040016 ch:0 seq:1 tile_x:8 tile_y:1
     kworker/2:2-155     [002] ....    79.693556: rtcpu_isp_falcon_task_start: tstamp:3250040032 ch:0 task:SCHED_FINISH_SLICE
     kworker/2:2-155     [002] ....    79.693556: rtcpu_isp_falcon_tile_start: tstamp:3250040222 ch:0 seq:1 tile_x:0 tile_y:2 tile_w:894 tile_h:534
     kworker/2:2-155     [002] ....    79.693556: rtcpu_isp_falcon_task_end: tstamp:3250040236 task:SCHED_FINISH_SLICE
     kworker/2:2-155     [002] ....    79.693556: rtcpu_isp_falcon_tile_end: tstamp:3250048314 ch:0 seq:1 tile_x:0 tile_y:2
     kworker/2:2-155     [002] ....    79.693557: rtcpu_isp_falcon_task_start: tstamp:3250048329 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693557: rtcpu_isp_falcon_tile_start: tstamp:3250048416 ch:0 seq:1 tile_x:1 tile_y:2 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693557: rtcpu_isp_falcon_task_end: tstamp:3250048430 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693558: rtcpu_isp_falcon_tile_end: tstamp:3250056656 ch:0 seq:1 tile_x:1 tile_y:2
     kworker/2:2-155     [002] ....    79.693558: rtcpu_isp_falcon_task_start: tstamp:3250056671 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693558: rtcpu_isp_falcon_tile_start: tstamp:3250056758 ch:0 seq:1 tile_x:2 tile_y:2 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693558: rtcpu_isp_falcon_task_end: tstamp:3250056771 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693559: rtcpu_isp_falcon_tile_end: tstamp:3250064991 ch:0 seq:1 tile_x:2 tile_y:2
     kworker/2:2-155     [002] ....    79.693559: rtcpu_isp_falcon_task_start: tstamp:3250065006 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693559: rtcpu_isp_falcon_tile_start: tstamp:3250065093 ch:0 seq:1 tile_x:3 tile_y:2 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693560: rtcpu_isp_falcon_task_end: tstamp:3250065106 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693560: rtcpu_isp_falcon_tile_end: tstamp:3250073326 ch:0 seq:1 tile_x:3 tile_y:2
     kworker/2:2-155     [002] ....    79.693560: rtcpu_isp_falcon_task_start: tstamp:3250073340 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693560: rtcpu_isp_falcon_tile_start: tstamp:3250073428 ch:0 seq:1 tile_x:4 tile_y:2 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693561: rtcpu_isp_falcon_task_end: tstamp:3250073441 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693561: rtcpu_isp_falcon_tile_end: tstamp:3250081663 ch:0 seq:1 tile_x:4 tile_y:2
     kworker/2:2-155     [002] ....    79.693561: rtcpu_isp_falcon_task_start: tstamp:3250081679 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693562: rtcpu_isp_falcon_tile_start: tstamp:3250081766 ch:0 seq:1 tile_x:5 tile_y:2 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693562: rtcpu_isp_falcon_task_end: tstamp:3250081780 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693562: rtcpu_isp_falcon_tile_end: tstamp:3250090001 ch:0 seq:1 tile_x:5 tile_y:2
     kworker/2:2-155     [002] ....    79.693562: rtcpu_isp_falcon_task_start: tstamp:3250090017 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693563: rtcpu_isp_falcon_tile_start: tstamp:3250090104 ch:0 seq:1 tile_x:6 tile_y:2 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693563: rtcpu_isp_falcon_task_end: tstamp:3250090118 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693563: rtcpu_vinotify_event: tstamp:3250102349 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:5 vi_tstamp:104003228000 data:0x0000000000000000
     kworker/2:2-155     [002] ....    79.693564: rtcpu_isp_falcon_tile_end: tstamp:3250098338 ch:0 seq:1 tile_x:6 tile_y:2
     kworker/2:2-155     [002] ....    79.693564: rtcpu_isp_falcon_task_start: tstamp:3250098353 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693564: rtcpu_isp_falcon_tile_start: tstamp:3250098441 ch:0 seq:1 tile_x:7 tile_y:2 tile_w:896 tile_h:534
     kworker/2:2-155     [002] ....    79.693564: rtcpu_isp_falcon_task_end: tstamp:3250098454 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    79.693565: rtcpu_isp_falcon_tile_end: tstamp:3250106676 ch:0 seq:1 tile_x:7 tile_y:2
     kworker/2:2-155     [002] ....    79.693565: rtcpu_isp_falcon_task_start: tstamp:3250106692 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385651: rtcpu_isp_falcon_task_start: tstamp:3270974845 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385651: rtcpu_isp_falcon_tile_start: tstamp:3270974927 ch:0 seq:11 tile_x:2 tile_y:11 tile_w:896 tile_h:142
     kworker/2:2-155     [002] ....    80.385652: rtcpu_isp_falcon_task_end: tstamp:3270974940 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385652: rtcpu_isp_falcon_tile_end: tstamp:3270977499 ch:0 seq:11 tile_x:2 tile_y:11
     kworker/2:2-155     [002] ....    80.385652: rtcpu_isp_falcon_task_start: tstamp:3270977514 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385653: rtcpu_isp_falcon_tile_start: tstamp:3270977595 ch:0 seq:11 tile_x:3 tile_y:11 tile_w:896 tile_h:142
     kworker/2:2-155     [002] ....    80.385653: rtcpu_isp_falcon_task_end: tstamp:3270977609 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385653: rtcpu_isp_falcon_tile_end: tstamp:3270980167 ch:0 seq:11 tile_x:3 tile_y:11
     kworker/2:2-155     [002] ....    80.385654: rtcpu_isp_falcon_task_start: tstamp:3270980182 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385654: rtcpu_isp_falcon_tile_start: tstamp:3270980263 ch:0 seq:11 tile_x:4 tile_y:11 tile_w:896 tile_h:142
     kworker/2:2-155     [002] ....    80.385655: rtcpu_isp_falcon_task_end: tstamp:3270980276 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385655: rtcpu_isp_falcon_task_start: tstamp:3270982139 ch:0 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385656: rtcpu_isp_falcon_task_end: tstamp:3270982273 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385656: rtcpu_isp_falcon_tile_end: tstamp:3270982840 ch:0 seq:11 tile_x:4 tile_y:11
     kworker/2:2-155     [002] ....    80.385656: rtcpu_isp_falcon_task_start: tstamp:3270982855 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385657: rtcpu_isp_falcon_tile_start: tstamp:3270983011 ch:0 seq:11 tile_x:5 tile_y:11 tile_w:896 tile_h:142
     kworker/2:2-155     [002] ....    80.385657: rtcpu_isp_falcon_task_end: tstamp:3270983061 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385658: rtcpu_isp_falcon_tile_end: tstamp:3270985583 ch:0 seq:11 tile_x:5 tile_y:11
     kworker/2:2-155     [002] ....    80.385658: rtcpu_isp_falcon_task_start: tstamp:3270985599 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385658: rtcpu_isp_falcon_tile_start: tstamp:3270985679 ch:0 seq:11 tile_x:6 tile_y:11 tile_w:896 tile_h:142
     kworker/2:2-155     [002] ....    80.385659: rtcpu_isp_falcon_task_end: tstamp:3270985693 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385659: rtcpu_isp_falcon_tile_end: tstamp:3270988252 ch:0 seq:11 tile_x:6 tile_y:11
     kworker/2:2-155     [002] ....    80.385659: rtcpu_isp_falcon_task_start: tstamp:3270988266 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385660: rtcpu_isp_falcon_tile_start: tstamp:3270988348 ch:0 seq:11 tile_x:7 tile_y:11 tile_w:896 tile_h:142
     kworker/2:2-155     [002] ....    80.385660: rtcpu_isp_falcon_task_end: tstamp:3270988362 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385660: rtcpu_isp_falcon_tile_end: tstamp:3270990923 ch:0 seq:11 tile_x:7 tile_y:11
     kworker/2:2-155     [002] ....    80.385661: rtcpu_isp_falcon_task_start: tstamp:3270990938 ch:0 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385661: rtcpu_isp_falcon_tile_start: tstamp:3270991019 ch:0 seq:11 tile_x:8 tile_y:11 tile_w:898 tile_h:142
     kworker/2:2-155     [002] ....    80.385662: rtcpu_isp_falcon_task_end: tstamp:3270991033 task:SCHED_FINISH_TILE
     kworker/2:2-155     [002] ....    80.385662: rtcpu_isp_falcon_task_start: tstamp:3270992865 ch:0 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385662: rtcpu_isp_falcon_task_end: tstamp:3270993007 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385663: rtcpu_vinotify_event: tstamp:3270996680 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:15 vi_tstamp:104664404128 data:0x0000000000000000
     kworker/2:2-155     [002] ....    80.385663: rtcpu_vinotify_event: tstamp:3270996833 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:15 vi_tstamp:104664407712 data:0x000000000202000e
     kworker/2:2-155     [002] ....    80.385664: rtcpu_vinotify_event: tstamp:3270996967 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:15 vi_tstamp:104669877664 data:0x0000000000000000
     kworker/2:2-155     [002] ....    80.385664: rtcpu_vinotify_event: tstamp:3270997116 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:15 vi_tstamp:104669881248 data:0x000000000202000e
     kworker/2:2-155     [002] ....    80.385664: rtcpu_isp_falcon_task_start: tstamp:3270993073 ch:0 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385665: rtcpu_isp_falcon_task_end: tstamp:3270993288 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385665: rtcpu_isp_falcon_task_start: tstamp:3270993336 ch:0 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385666: rtcpu_isp_falcon_task_end: tstamp:3270993637 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385666: rtcpu_isp_falcon_task_start: tstamp:3270993662 ch:0 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385667: rtcpu_isp_falcon_task_end: tstamp:3270993795 task:SCHED_HANDLE_STAT
     kworker/2:2-155     [002] ....    80.385667: rtcpu_isp_falcon_tile_end: tstamp:3270993884 ch:0 seq:11 tile_x:8 tile_y:11
     kworker/2:2-155     [002] ....    80.385667: rtcpu_isp_falcon_task_start: tstamp:3270993900 ch:0 task:SCHED_FINISH_SLICE
     kworker/2:2-155     [002] ....    80.385668: rtcpu_isp_falcon: tag:0x12 tstamp:3270993964 ch:0 seq:0 data:0x00000000 ext_data:0x00000000
     kworker/2:2-155     [002] ....    80.385668: rtcpu_isp_falcon_task_end: tstamp:3270994251 task:SCHED_FINISH_SLICE
     kworker/2:2-155     [002] ....    80.385669: rtcpu_isp_falcon_task_start: tstamp:3270994269 ch:0 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    80.385669: rtcpu_isp_falcon_task_end: tstamp:3270994301 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    80.385670: rtcpu_vinotify_event: tstamp:3271370692 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:15 vi_tstamp:104675371680 data:0x0000000000000000
     kworker/2:2-155     [002] ....    80.385670: rtcpu_vinotify_event: tstamp:3271370843 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:15 vi_tstamp:104675375232 data:0x000000000202000e
     kworker/2:2-155     [002] ....    80.385670: rtcpu_vinotify_event: tstamp:3271370975 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:15 vi_tstamp:104680845184 data:0x0000000000000000
     kworker/2:2-155     [002] ....    80.385671: rtcpu_vinotify_event: tstamp:3271371125 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:15 vi_tstamp:104680848736 data:0x000000000202000e
     kworker/2:2-155     [002] ....    80.385671: rtcpu_vinotify_event: tstamp:3271619980 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:15 vi_tstamp:104686318624 data:0x0000000000000000
     kworker/2:2-155     [002] ....    80.385672: rtcpu_vinotify_event: tstamp:3271620132 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:15 vi_tstamp:104686322176 data:0x000000000202000e
     kworker/2:2-155     [002] ....    80.385672: rtcpu_vinotify_event: tstamp:3271620262 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:15 vi_tstamp:104691792160 data:0x0000000000000000
     kworker/2:2-155     [002] ....    80.441473: rtcpu_vinotify_event: tstamp:3271971420 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:15 vi_tstamp:104691798528 data:0x000000000202000e
     kworker/2:2-155     [002] ....    80.441475: rtcpu_vinotify_event: tstamp:3271971558 cch:1 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x0b frame:15 vi_tstamp:104697265632 data:0x0000000000000000
     kworker/2:2-155     [002] ....    80.441476: rtcpu_vinotify_event: tstamp:3271971711 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:15 vi_tstamp:104697269184 data:0x000000000202000e
 CaptureSchedule-2932    [003] ....    82.888076: tegra_channel_set_stream: enable : 0x0
 CaptureSchedule-2932    [003] ....    82.888080: tegra_channel_set_stream: imx858 2-001a : 0x0
     kworker/2:2-155     [002] ....    82.961462: rtcpu_nvcsi_intr: tstamp:3351342697 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000125
     kworker/2:2-155     [002] ....    82.961463: rtcpu_nvcsi_intr: tstamp:3351342697 class:GLOBAL type:PHY_INTR1 phy:0 cil:1 st:0 vc:0 status:0x00000021
     kworker/2:2-155     [002] ....    82.961463: rtcpu_nvcsi_intr: tstamp:3351342697 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/2:2-155     [002] ....    82.961463: rtcpu_nvcsi_intr: tstamp:3351342697 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000010
 CaptureSchedule-2932    [001] ....    82.988801: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
 CaptureSchedule-2932    [001] ....    82.988807: csi_s_stream: enable : 0x0
 CaptureSchedule-2932    [000] ....    82.991408: tegra_channel_set_power: imx858 2-001a : 0x0
 CaptureSchedule-2932    [000] ....    82.991428: camera_common_s_power: status : 0x0
 CaptureSchedule-2932    [000] ....    82.991496: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
 CaptureSchedule-2932    [000] ....    82.991499: csi_s_power: enable : 0x0
     kworker/2:2-155     [002] ....    83.021506: rtcpu_nvcsi_intr: tstamp:3353367863 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00180000
     kworker/2:2-155     [002] ....    83.021510: rtcpu_nvcsi_intr: tstamp:3353367863 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00006000
     kworker/2:2-155     [002] ....    83.021511: rtcpu_nvcsi_intr: tstamp:3353367863 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00002000
     kworker/2:2-155     [002] ....    83.021512: rtcpu_nvcsi_intr: tstamp:3353368524 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00080000
     kworker/2:2-155     [002] ....    83.749471: rtcpu_vinotify_event: tstamp:3375783367 cch:-1 vi:0 tag:FE channel:0x00 frame:15 vi_tstamp:108021599616 data:0x0000000000000020
     kworker/2:2-155     [002] ....    83.749475: rtcpu_vinotify_event: tstamp:3375783561 cch:-1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:15 vi_tstamp:108021599616 data:0x142a000001000800
     kworker/2:2-155     [002] ....    83.749475: rtcpu_vinotify_event: tstamp:3375783729 cch:-1 vi:0 tag:ATOMP_FE channel:0x00 frame:15 vi_tstamp:108021599616 data:0x0000000000000800
  nvargus-daemon-2916    [008] ....    85.675469: tegra_channel_close: vi-output, imx858 2-001a
     kworker/2:2-155     [002] ....    85.721490: rtcpu_isp_falcon_task_start: tstamp:3437205634 ch:0 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    85.721495: rtcpu_isp_falcon_task_end: tstamp:3437205674 task:HANDLE_EVENT
     kworker/2:2-155     [002] ....    91.637491: rtcpu_string: tstamp:3623203104 id:0x04010000 str:"VM0 deactivating."
hello paekaaa.paek,
let me have quick summarize…
work: CPHY, 3 lanes, 800Msps, 3840X2160.
not working: CPHY, 3 lanes, 1.6Gsps, 8064x6016
by checking your logs…
these two indicate that CPHY clock calibration has done.
but… there’s only CHANSEL_PXL_SOF in the tracing logs, it should have a pair of CHANSEL_PXL_SOF and CHANSEL_PXL_EOF to indicate a good fame.
please double check your sensor configuration, please check it’s outputting EOF (end-of-frame) correctly.
thank you, I will check it
