I have connected two cameras via a USB hub, and this setup works fine on all my other Jetson Nano devices. However, with one specific Nano (deployed in a truck), I am facing the issue shown in the attached logs.
From the dmesg logs, I can see some errors, but I am unsure whether the problem is due to the driver removing the cameras or if it’s caused by a faulty cable. Any guidance would be appreciated. 8304.txt (33.3 KB)
[ 458.421036] uvcvideo: Failed to set UVC probe control : -71 (exp. 26).
[ 459.966806] uvcvideo: Failed to set UVC commit control : -71 (exp. 26).
[ 460.007014] uvcvideo: Failed to set UVC commit control : -71 (exp. 26).
[ 460.066279] uvcvideo: Failed to set UVC probe control : -71 (exp. 26).
[ 460.072983] uvcvideo: Failed to set UVC probe control : -71 (exp. 26).
And -71 mostly means there is usb signal issue. That is all this log is doing. Rest of things is just lots of -71 error repeating print.
