hi,
目前我们相机部分占用CPU和GPU资源较高,所以想使用非CUDA方式进行转化,想请教一下几个问题,是否有相关的示例代码?
硬件为:Jetson Orin 64GB,software: JetPack5.1.3
1、YUV422转YUV420是否可以用非CUDA方式实现,如VIC?
2、YUV420缩放及去畸变是否可以用非CUDA方式实现,如VIC?
3、YUV422是否可以直接转换RGB格式?用非CUDA方式
谢谢
hi,
谢谢
Based on the provided context, I will answer the question by comparing the supported output formats for VIC-based nvvidconv and CUDA-based nvvidconv on Jetson AGX Orin.
VIC-based nvvidconv
The VIC-based nvvidconv on Jetson AGX Orin supports the following RAW-YUV output formats:
I420
UYVY
YUY2
YVYU
NV12
NV16
NV24
GRAY8
BGRx
RGBA
Y42B
The CUDA-based nvvidconv on GPU supports the following RAW-YUV output formats:
I420
NV12
P010_10LE
I420_10LE
GRAY8
BGRx
RGBA
Comparison
Comparing the two lists, we can see that:
Both VIC-based and CUDA-based nvvidconv support I420, NV12, GRAY8, BGRx, and RGBA output formats.
VIC-based nvvidconv supports additional output formats, including UYVY, YUY2, YVYU, NV16, NV24, and Y42B.
CUDA-based nvvidconv supports P010_10LE and I420_10LE output formats, which are not supported by VIC-based nvvidconv.
Answer to the question
Based on the comparison, we can conclude that:
YUV422 is supported by VIC-based nvvidconv (UYVY, YUY2, and YVYU) but not by CUDA-based nvvidconv.
YUV420 is supported by both VIC-based and CUDA-based nvvidconv (I420 and NV12).
RGB is supported by both VIC-based and CUDA-based nvvidconv (BGRx and RGBA).
Therefore, the correct answer is:
YUV422: VIC
YUV420: Both VIC and CUDA
RGB: Both VIC and CUDA
hi,
可以提供VIC的相关示例代码吗?
抱歉刚刚描述有点问题,我们的设计是从YUV422最终转成BGR格式
We don’t public the source but provide API.
hi
请问那我们应该如何用起来呢??
没有参考代码吗
You can check the MMAPI sample code.
