Isaac Sim Version
[√] 4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
[√] Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: NVIDIA GeForce RTX 3090
- Driver Version: 550.127.08
“cameraFisheyePolynomial” generated by Replicator is incorrect with default “fisheyePolynomial” cameraModel parameters
Detailed Description
When using the Replicator to generate a cameraFisheyePolynomial sensor with the camera parameters below:
camera_kwargs = {
"position": (0, 0, 0),
"rotation": (0, 0, 0),
"projection_type": "fisheyePolynomial",
camera_prim = rep.create.camera(**camera_kwargs)
The generated camera_params are:
"cameraAperture": [20.954999923706055, 15.290800094604492],
"cameraApertureOffset": [0.0, 0.0],
"cameraFisheyeLensP": [-0.0003699999942909926, -0.0007399999885819852],
"cameraFisheyeLensS": [-0.0005799999926239252, -0.00022000000171829015, 0.0001900000061141327, -0.00019999999494757503],
"cameraFisheyeMaxFOV": 200.0,
"cameraFisheyeNominalHeight": 1216,
"cameraFisheyeNominalWidth": 1936,
"cameraFisheyeOpticalCentre": [970.9424438476562, 600.3748168945312],
"cameraFisheyePolynomial": [0.0, 0.0024500000290572643, 0.0, 0.0, 0.0, 0.0],
"cameraFocalLength": 24.0,
"cameraFocusDistance": 400.0,
"cameraFStop": 0.0,
"cameraModel": "fisheyePolynomial",
"cameraNearFar": [1.0, 1000000.0],
"cameraProjection": [2.2906228624246854, 0.0, 0.0, 0.0, 0.0, 4.072218422088329, 0.0, 0.0, 0.0, 0.0, 1.000001000001e-06, -1.0, 0.0, 0.0, 1.000001000001, 0.0],
"cameraViewTransform": [0.7068997241792948, -1.5705520830089987e-16, 0.7073137775805283, 0.0, 0.7073137775805283, 1.5696326997700512e-16, -0.7068997241792948, 0.0, 0.0, 1.0, 2.220446049250313e-16, -0.0, 137.56944419975406, -1.9699923326162707, -3.7603040814074267, 1.0],
"metersPerSceneUnit": 1.0,
"renderProductResolution": [1280, 720]
I attempted to project the distance_to_camera depth data into the camera coordinate system using the parameters of cameraFisheyePolynomial, but the projection results are incorrect. The main projection function is as follows. I have referenced the following document, which is the white paper of the ftheta model:
ftheta.pdf (87.0 KB)
def unproject_poly_depth(depth: torch.Tensor, intrinsics: torch.Tensor, poly: torch.Tensor) -> torch.Tensor:
depth_batch = depth.clone()
# check if inputs are batched
is_batched = depth_batch.dim() == 4 or (depth_batch.dim() == 3 and depth_batch.shape[-1] != 1)
# make sure inputs are batched
if depth_batch.dim() == 3 and depth_batch.shape[-1] == 1:
depth_batch = depth_batch.squeeze(dim=2) # (H, W, 1) -> (H, W)
if depth_batch.dim() == 2:
depth_batch = depth_batch[None] # (H, W) -> (1, H, W)
if depth_batch.dim() == 4 and depth_batch.shape[-1] == 1:
depth_batch = depth_batch.squeeze(dim=3) # (N, H, W, 1) -> (N, H, W)
if intrinsics_batch.dim() == 2:
intrinsics_batch = intrinsics_batch[None] # (3, 3) -> (1, 3, 3)
# get image height and width
im_height, im_width = depth_batch.shape[1:]
# create image points in homogeneous coordinates (3, H x W)
indices_u = torch.arange(im_width, device=depth.device, dtype=depth.dtype)
indices_v = torch.arange(im_height, device=depth.device, dtype=depth.dtype)
img_indices = torch.stack(torch.meshgrid([indices_u, indices_v], indexing="ij"), dim=0).reshape(2, -1)
# Get principal point
cx = intrinsics_batch[..., 0, 2]
cy = intrinsics_batch[..., 1, 2]
px = img_indices[0] - cx
py = img_indices[1] - cy
pd = torch.sqrt(px ** 2 + py ** 2)
theta = torch.zeros_like(pd)
for i in range(poly.shape[0]):
theta += poly[i] * pd ** i
phi = torch.atan2(py, px)
rx = torch.sin(theta) * torch.cos(phi)
ry = torch.sin(theta) * torch.sin(phi)
rz = torch.cos(theta)
ray = torch.stack([rx, ry, rz], dim=0) # (3, H*W)
ray = ray / ray.norm(p=2, dim=0, keepdim=True) # ray on unit sphere
ray = ray.unsqueeze(0) # (3, H x W) -> (1, 3, H x W)
# flatten depth image (N, H, W) -> (N, H x W)
depth_batch = depth_batch.transpose_(1, 2).reshape(depth_batch.shape[0], -1).unsqueeze(2)
depth_batch = depth_batch.expand(-1, -1, 3)
points_xyz = ray.transpose_(1, 2) * depth_batch # (N, H x W, 3)
# return points in same shape as input
if not is_batched:
points_xyz = points_xyz.squeeze(0)
return points_xyz
The wrong projection results are shown in the following image:
I have tried using tartancalib to calibrate the same camera above with the generated RGB image containing an AprilGrid in the scene by Replicator. The calibration results with the omni-radtan model are as follows:
camera_model: omni
distortion_coeffs: [-0.10831953608105305, 0.43397974712468684, 3.765144569337964e-05, -3.0867713944010906e-05]
distortion_model: radtan
intrinsics: [1.8020312187152925, 756.1810601165237, 755.9053645818727, 641.4577349626691, 354.3992190535659]
resolution: [1280, 720]
Then I have tried to aproximate the cameraFisheyePolynomial parameters with the omni-radtan model parameters, the results are as follows:
[0.00000000e+00, 3.71387357e-03, -2.27210914e-07, 1.56039459e-09, -8.32343570e-12, 1.49184713e-14]
In the end, I used the above parameters to project the distance_to_camera depth data into the camera coordinate system, and the projection results are correct. The correct projection results are shown in the following image:
Therefore, I believe the cameraFisheyePolynomial generated by Replicator is incorrect with the default fisheyePolynomial camera model parameters. Could you please explain why this issue occurs or if there is a problem with my usage? Thank you!
