@zhengwang thanks for your kind hint, indeed that solves setting camera intrinsics, but it introduces another problem: expanded resolution:
header:
stamp:
sec: 0
nanosec: 583333363
frame_id: camera_color_optical_frame
height: 1024
width: 2048
distortion_model: plumb_bob
d:
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
k:
- 607.1807250976562
- 0.0
- 322.3876647949219
- 0.0
- 605.66943359375
- 244.37399291992188
- 0.0
- 0.0
- 1.0
r:
- 1.0
- 0.0
- 0.0
- 0.0
- 1.0
- 0.0
- 0.0
- 0.0
- 1.0
p:
- 607.1807250976562
- 0.0
- 322.3876647949219
- 0.0
- 0.0
- 605.66943359375
- 0.0
- 0.0
- 0.0
- 1.0
- 0.0
binning_x: 0
binning_y: 0
roi:
x_offset: 0
y_offset: 0
height: 0
width: 0
do_rectify: false
This is the code I use:
class RealSense(Camera):
def __init__(
self,
cam_prim_path: str,
cam_link_name: str,
height: int,
width: int,
cam_info_topic: str,
cam_color_topic: str,
cam_depth_topic: str,
cam_pointcloud_topic: str,
camera_matrix=None,
distortion_coefficients=None,
pixel_size: float = 3.0,
f_stop: float = 1.8,
focus_distance: float = 1.5,
*args,
**kwargs,
) -> None:
self._cam_prim_path = cam_prim_path
self._cam_link_name = cam_link_name
self._height = height
self._width = width
self._cam_info_topic = cam_info_topic
self._cam_color_topic = cam_color_topic
self._cam_depth_topic = cam_depth_topic
self._cam_pointcloud_topic = cam_pointcloud_topic
# Defaults if not passed
self._camera_matrix = camera_matrix or [
[607.1807250976562, 0.0, 322.3876647949219],
[0.0, 605.66943359375, 244.37399291992188],
[0.0, 0.0, 1.0],
self._distortion_coefficients = distortion_coefficients or [0.0, 0.0, 0.0, 0.0]
self._pixel_size = pixel_size
self._f_stop = f_stop
self._focus_distance = focus_distance
# Init parent Camera
super().__init__(
prim_path=self._cam_prim_path,
frequency=30,
resolution=(height, width),
*args,
**kwargs,
self.initialize()
# Apply intrinsics + optical config
self._configure_intrinsics()
# Build OmniGraph for streaming topics
self._create_realsense_omnigraph()
def _create_realsense_omnigraph(self):
config_dir = os.path.dirname(graph_config.__file__)
graph_name = "realsense_camera_graph.yml"
config_path_ = os.path.join(config_dir, graph_name)
neura_graph = Graph(
config_path=config_path_,
height=self._height,
width=self._width,
cam_info_topic=self._cam_info_topic,
cam_color_topic=self._cam_color_topic,
cam_depth_topic=self._cam_depth_topic,
cam_pointcloud_topic=self._cam_pointcloud_topic,
og_key_create_node, og_keys_connect, og_keys_set_values = neura_graph.get_graph()
keys = og.Controller.Keys
graph_path = f"{self._cam_prim_path}/CameraActionGraph"
(graph_handle, _, _, _) = og.Controller.edit(
"graph_path": graph_path,
"evaluator_name": "execution",
"pipeline_stage": og.GraphPipelineStage.GRAPH_PIPELINE_STAGE_SIMULATION,
keys.CREATE_NODES: og_key_create_node,
keys.SET_VALUES: og_keys_set_values,
keys.CONNECT: og_keys_connect,
return graph_handle
def _configure_intrinsics(self):
Configure the camera intrinsics and optical properties from
camera matrix and distortion coefficients.
((fx, _, cx), (_, fy, cy), (_, _, _)) = self._camera_matrix
# apertures in meters (pixel_size is microns -> convert to meters)
horizontal_aperture = self._pixel_size * self._width * 1e-6
vertical_aperture = self._pixel_size * self._height * 1e-6
# focal lengths in meters
focal_length_x = self._pixel_size * fx * 1e-6
focal_length_y = self._pixel_size * fy * 1e-6
focal_length = (focal_length_x + focal_length_y) / 2
# Apply params to Isaac Sim Camera API
self.set_focal_length(focal_length)
self.set_focus_distance(self._focus_distance)
self.set_lens_aperture(self._f_stop)
self.set_horizontal_aperture(horizontal_aperture)
self.set_vertical_aperture(vertical_aperture)
self.set_clipping_range(0.2, 1.0e5)
self.set_opencv_pinhole_properties(
cx=cx,
cy=cy,
fx=fx,
fy=fy,
pinhole=self._distortion_coefficients
Can you please guide me on how to set resolution to VGA resolution as well, when I pass 640 x 480 I get 2048 x 1024 ! that issue was not there before setting intrinsics.
