Cameras aren't detected by argus but v4l2-ctl works
Argus can’t seem to record with the tegra mmapi samples, i’m not sure whats going wrong, any help will be great!
Media device information
driver          tegra-camrtc-ca
model           NVIDIA Tegra Video Input Device
serial
bus info
hw revision     0x3
driver version  5.10.104
Device topology
- entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev0
        pad0: Sink
                <- "ox08b40 0-0030":0 [ENABLED]
        pad1: Source
                -> "vi-output, ox08b40 0-0030":0 [ENABLED]
- entity 4: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
            device node name /dev/v4l-subdev1
        pad0: Sink
                <- "ox08b40 0-0031":0 [ENABLED]
        pad1: Source
                -> "vi-output, ox08b40 0-0031":0 [ENABLED]
- entity 91: ox08b40 0-0030 (1 pad, 1 link)
             type V4L2 subdev subtype Sensor flags 0
             device node name /dev/v4l-subdev2
        pad0: Source
                [fmt:SBGGR12_1X12/3840x2160 field:none colorspace:srgb]
                -> "13e40000.host1x:nvcsi@15a00000-":0 [ENABLED]
- entity 93: vi-output, ox08b40 0-0030 (1 pad, 1 link)
             type Node subtype V4L flags 0
             device node name /dev/video0
        pad0: Sink
                <- "13e40000.host1x:nvcsi@15a00000-":1 [ENABLED]
- entity 107: ox08b40 0-0031 (1 pad, 1 link)
              device node name /dev/v4l-subdev3
        pad0: Source
- entity 109: vi-output, ox08b40 0-0031 (1 pad, 1 link)
              device node name /dev/video1
        pad0: Sink
Argus
p2-compute-orin:~$ sudo nvargus-daemon
=== NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections...=== argus_camera_recording[4890]: Connection established (FFFFAAC5B840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 689)
SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 453)
SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 333)
SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 505)
NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
=== argus_camera_recording[4890]: CameraProvider initialized (0xffffa46fa900)=== argus_camera_recording[4890]: CameraProvider destroyed (0xffffa46fa900)=== argus_camera_recording[4890]: Connection closed (FFFFAAC5B840)=== argus_camera_recording[4890]: Connection cleaned up (FFFFAAC5B840)
V4l2 Works:
p2-compute-orin:~$ sudo v4l2-ctl --list-devices --verbose
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
        /dev/media0
vi-output, ox08b40 0-0030 (platform:tegra-capture-vi:0):
        /dev/video0
vi-output, ox08b40 0-0031 (platform:tegra-capture-vi:2):
        /dev/video1
VIDIOC_QUERYCAP: ok
 39     tegra-camera-platform {
 38         compatible = "nvidia, tegra-camera-platform";
 37         num_csi_lanes = <8>; /* 3 cameras * 2 lanes each */
 36         max_lane_speed = <2500000>; /* MIPI lanes are set up for 2208 Mbps (field is in Kbps) */
 35         // TODO: Is this for one camera, or all 3? Probably all 3.
 34         // Overridden to a general value seen in other nvidia drivers for now
 33         max_pixel_rate = <7500000>; /* ((3840 * 2160 * 30) * 2) + (1920 * 1280 * 30) rounded up, in kpixels/s */
 32         min_bits_per_pixel = <12>;
 31         /* Don't really know what the rest of these do, and there is minimal/no documentation. */
 30         /* So we copy-pasta from the imx334 device tree for now. */
 29         vi_peak_byte_per_pixel = <5>;
 28         vi_bw_margin_pct = <25>;
 27         isp_peak_byte_per_pixel = <5>;
 26         isp_bw_margin_pct = <25>;
 25
 24         modules {
 23             module0 {
 22                 badge = "ox08b40_bottom_zipox08b40";
 21                 /* nvidia doesn't give many naming choices here, so we pick the closest thing we can to left/center/right */
 20                 /* https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html#module-properties */
 19                 position = "bottom";
 18                 orientation = "0";
 17                 drivernode0 {
 16                     pcl_id = "v4l2_sensor";
 15                     devname = "ox08b40 2-0030";
 14                     proc-device-tree = "/proc/device-tree/i2c@3160000/ox08b40_a@30";
 13                 };
 12             };
 11             module1 {
 10                 badge = "ox08b40_top_zipox08b40";
  9                 position = "top";
  7                 drivernode0 {
  5                     devname = "ox08b40 2-0031";
  4                     proc-device-tree = "/proc/device-tree/i2c@3160000/ox08b40_c@31";
  3                 };
  2             };
  1         };
516     };
  1 };
I think I see it
devnames become
ox08b40 0-0030
ox08b40 0-0031
when flashed, vs
ox08b40 2-0030
ox08b40 2-0031
in tegra-camera-platform dts
Why would the devname get reassigned?
For posterity, that fixed it
(I would still like to know what the right values are)
