IsaacSim
5.1.0
Topic Description
Detailed Description
In this file source/extensions/isaacsim.sensors.camera/isaacsim/sensors/camera/camera_view.py
The CameraView class has a member called camera_resolution , and in the doc of the arguments, it’s a tuple of int and with order width height.
But in the get_data function, it uses the height width order :
height, width = self.camera_resolution
And at the calling of the omniverse layer:
def _setup_tiled_sensor(self):
"""Set up the tiled sensor, compute resolutions, attach annotators, and initiate the render process."""
self._clean_up_tiled_sensor()
self.tiled_resolution = self._get_tiled_resolution(len(self.prims), self.camera_resolution)
self._tiled_render_product = rep.create.render_product_tiled(
cameras=self.prim_paths,
tile_resolution=self.camera_resolution,
name=f"{self.name}_tiled_sensor",
The function rep.create.render_product_tiled is not documented in the omniverse doc. But i found the doc for omni.replicator.core.create.render_product
They use width-height order.
So as long as you use a non-square image size, the program crashes.
And I also wonder do you have any plan to open source the omni layer ? It’s very inconvenient to debug code with a close-sourced engine.
