RTX4090, RTX4080 or others.
The 40 series RTX products are based on new NVIDIA Ada Lovelace architecture.
Current TAO22.05 is not verified on them.
So, not sure the status yet.
Thanks for answering, I tried it on RTX4090 and it doesn’t work now. Hope to support it later.
Thanks. Could you share some logs?
Information about the mask_rcnn trained with the RTX4090:
2022-11-23 18:11:23,753 [INFO] root: Registry: ['nvcr.io']
2022-11-23 18:11:23,793 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.5-py3
2022-11-23 18:11:23,798 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/nxin/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
[INFO] Loading specification from /workspace/tao-experiments/mask_rcnn/specs/maskrcnn_train_resnet50.txt
[MaskRCNN] INFO : Loading weights from /workspace/tao-experiments/mask_rcnn/experiment_dir_unpruned/model.step-0.tlt
[INFO] Log file already exists at /workspace/tao-experiments/mask_rcnn/experiment_dir_unpruned/status.json
[INFO] Starting MaskRCNN training.
INFO:tensorflow:Using config: {'_model_dir': '/tmp/tmpg5v92omu', '_tf_random_seed': 123, '_save_summary_steps': None, '_save_checkpoints_steps': None, '_save_checkpoints_secs': None, '_session_config': intra_op_parallelism_threads: 1
inter_op_parallelism_threads: 4
gpu_options {
allow_growth: true
force_gpu_compatible: true
allow_soft_placement: true
graph_options {
rewrite_options {
meta_optimizer_iterations: TWO
, '_keep_checkpoint_max': 20, '_keep_checkpoint_every_n_hours': None, '_log_step_count_steps': None, '_train_distribute': None, '_device_fn': None, '_protocol': None, '_eval_distribute': None, '_experimental_distribute': None, '_experimental_max_worker_delay_secs': None, '_session_creation_timeout_secs': 7200, '_service': None, '_cluster_spec': <tensorflow.python.training.server_lib.ClusterSpec object at 0x7fcf06a727f0>, '_task_type': 'worker', '_task_id': 0, '_global_id_in_cluster': 0, '_master': '', '_evaluation_master': '', '_is_chief': True, '_num_ps_replicas': 0, '_num_worker_replicas': 1}
[MaskRCNN] INFO : Create EncryptCheckpointSaverHook.
[MaskRCNN] INFO : =================================
[MaskRCNN] INFO : Start training cycle 01
WARNING:tensorflow:Entity <function InputReader.__call__.<locals>._prefetch_dataset at 0x7fcf06a74950> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <function InputReader.__call__.<locals>._prefetch_dataset at 0x7fcf06a74950>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:349: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <function dataset_parser at 0x7fcf123ad730> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <function dataset_parser at 0x7fcf123ad730>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:The operation `tf.image.convert_image_dtype` will be skipped since the input and output dtypes are identical.
INFO:tensorflow:Calling model_fn.
[MaskRCNN] INFO : ***********************
[MaskRCNN] INFO : Building model graph...
WARNING:tensorflow:Entity <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7fcffa76e9e8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7fcffa76e9e8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7fcff48d1320>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7fcff48d1320>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_2/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_3/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_4/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_5/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_6/
WARNING:tensorflow:Entity <bound method ProposalAssignment.call of <iva.mask_rcnn.layers.proposal_assignment_layer.ProposalAssignment object at 0x7fcff48d1748>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ProposalAssignment.call of <iva.mask_rcnn.layers.proposal_assignment_layer.ProposalAssignment object at 0x7fcff48d1748>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7fcff47a7748>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7fcff47a7748>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7fcff4550eb8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7fcff4550eb8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7fcff47b20f0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7fcff47b20f0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7fcff458b208>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7fcff458b208>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method BoxTargetEncoder.call of <iva.mask_rcnn.layers.box_target_encoder.BoxTargetEncoder object at 0x7fcff4513780>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method BoxTargetEncoder.call of <iva.mask_rcnn.layers.box_target_encoder.BoxTargetEncoder object at 0x7fcff4513780>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ForegroundSelectorForMask.call of <iva.mask_rcnn.layers.foreground_selector_for_mask.ForegroundSelectorForMask object at 0x7fcff4550f98>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ForegroundSelectorForMask.call of <iva.mask_rcnn.layers.foreground_selector_for_mask.ForegroundSelectorForMask object at 0x7fcff4550f98>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7fcff4550f60>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7fcff4550f60>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7fcff43c1a90>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7fcff43c1a90>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7fcff3adfd68>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7fcff3adfd68>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
4 ops no flops stats due to incomplete shapes.
Parsing Inputs...
[MaskRCNN] INFO : [Training Compute Statistics] 793.9 GFLOPS/image
WARNING:tensorflow:Entity <bound method MaskTargetsLayer.call of <iva.mask_rcnn.layers.mask_targets_layer.MaskTargetsLayer object at 0x7fcedc091438>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MaskTargetsLayer.call of <iva.mask_rcnn.layers.mask_targets_layer.MaskTargetsLayer object at 0x7fcedc091438>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:
The TensorFlow contrib module will not be included in TensorFlow 2.0.
For more information, please see:
* https://github.com/tensorflow/community/blob/master/rfcs/20180907-contrib-sunset.md
* https://github.com/tensorflow/addons
* https://github.com/tensorflow/io (for I/O related ops)
If you depend on functionality not listed there, please file an issue.
INFO:tensorflow:Done calling model_fn.
INFO:tensorflow:Graph was finalized.
INFO:tensorflow:Restoring parameters from /tmp/tmpg5v92omu/model.ckpt-0
INFO:tensorflow:Running local_init_op.
INFO:tensorflow:Done running local_init_op.
[GPU 00] Restoring pretrained weights (307 Tensors)
[MaskRCNN] INFO : Pretrained weights loaded with success...
[MaskRCNN] INFO : Saving checkpoints for 0 into /workspace/tao-experiments/mask_rcnn/experiment_dir_unpruned/model.step-0.tlt.
[INFO] 2 root error(s) found.
(0) Resource exhausted: OOM when allocating tensor with shape[47,448,800] and type float on /job:localhost/replica:0/task:0/device:CPU:0 by allocator gpu_host_bfc
[[{{node parser/cond/then/_9/map/TensorArrayV2Stack/TensorListStack}}]]
[[IteratorGetNext]]
Hint: If you want to see a list of allocated tensors when OOM happens, add report_tensor_allocations_upon_oom to RunOptions for current allocation info.
[[IteratorGetNext/_4707]]
(1) Resource exhausted: OOM when allocating tensor with shape[47,448,800] and type float on /job:localhost/replica:0/task:0/device:CPU:0 by allocator gpu_host_bfc
[[IteratorGetNext]]
0 successful operations.
0 derived errors ignored.
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1365, in _do_call
return fn(*args)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1350, in _run_fn
target_list, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1443, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.ResourceExhaustedError: 2 root error(s) found.
(0) Resource exhausted: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_1138}} OOM when allocating tensor with shape[47,448,800] and type float on /job:localhost/replica:0/task:0/device:CPU:0 by allocator gpu_host_bfc
[[IteratorGetNext]]
(1) Resource exhausted: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_1138}} OOM when allocating tensor with shape[47,448,800] and type float on /job:localhost/replica:0/task:0/device:CPU:0 by allocator gpu_host_bfc
[[IteratorGetNext]]
During handling of the above exception, another exception occurred:
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 254, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 250, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 237, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 88, in run_executer
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py", line 418, in train_and_eval
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 370, in train
loss = self._train_model(input_fn, hooks, saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1161, in _train_model
return self._train_model_default(input_fn, hooks, saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1195, in _train_model_default
saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1494, in _train_with_estimator_spec
_, loss = mon_sess.run([estimator_spec.train_op, estimator_spec.loss])
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 754, in run
run_metadata=run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1259, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1360, in run
raise six.reraise(*original_exc_info)
File "/usr/local/lib/python3.6/dist-packages/six.py", line 696, in reraise
raise value
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1345, in run
return self._sess.run(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1418, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1176, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 956, in run
run_metadata_ptr)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1180, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1359, in _do_run
run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1384, in _do_call
raise type(e)(node_def, op, message)
[[IteratorGetNext]]
[[IteratorGetNext]]
2022-11-23 18:52:22,670 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
The memory usage is probably up by 2G, but the GPU doesn’t seem to be working.
The same dataset and configuration I trained successfully on the RTX3090, the video memory is occupied at 18G.
The error seems to be OOM. Can you use less tfrecord files and set lower batch-size?
More, can you run nvidia-smi successfully?
I run nvidia-smi successfully.
I’ve tried setting a lower batch doesn’t work.
At the same time, there is a problem, RTX3090 and RTX4090 have 24G video memory. RTX3090 does not have OOM but RTX4090 OOM is unreasonable. So I think it’s the RTX4090 that isn’t working.
For 3090, does it run in WSL or linux machine?
How about 4090 as well?
BTW, if you have time, please try other network. For example, LPRnet.
3090 run in linux machine and 4090 run in WSL2. I’m not sure if this will make a difference.
I’ll try other network later with 4090.
LPRnet can be trained normally with 4090.
Thanks for the info. So, seems that the 40 series products can work with TAO.
For OOM issue in Maskrcnn, please try to use:
- less tfrecords. For example, only use one tfrecord file.
I also find some topics which are talking about Maskrcnn OOM under WSL .
For example, Issue while converting maskrcnn model to trt from etlt on Laptops - #23 by alaapdhall79 , its solution is temporarily increasing the “SWAP” Memory .
Thank you very much, I think you are right.
I tried everything under wsl and it didn’t work. So I installed linux and everything worked fine after that.
WSL may not be a good option.
